Manifest 0 Posted March 23, 2014 Share Posted March 23, 2014 Hi all, So I bought MediaBrowser3's android client app a month ago when I heard it would be getting Chromecast support. Since then I have been able to successfully stream things from my computer to the chromecast, and from my computer to the android app while I awaited the Chromecast android client update. I've just been trying it out now, and it doesn't seem to want to connect to my chromecast. I hit the icon in the top bar, it brings up the "Connect to Device" dialog and I select my device. The icon then turns blue in the top bar, before disappearing a second later. Anything I try to stream just streams to my android phone, and not my TV. Any ideas what might be causing this? I assume the disappearance of the icon means that the chromecast drops connection or something. Thanks in advance. Link to comment Share on other sites More sharing options...
Redshirt 1487 Posted March 23, 2014 Share Posted March 23, 2014 That's bizarre. The state of that icon is defined by a google library and not my code. Does the same thing happen with the youtube, netflix, plex apps? Link to comment Share on other sites More sharing options...
Manifest 0 Posted March 23, 2014 Author Share Posted March 23, 2014 Hmm, interesting. I've only tried the youtube one, and that works fine. Link to comment Share on other sites More sharing options...
Solution Manifest 0 Posted April 19, 2014 Author Solution Share Posted April 19, 2014 Just for reference, I tried it again this morning and it all seems to be working fine. Either a recent update has fixed things, or it was an issue with my Chromecast that resolved itself in the last month. Link to comment Share on other sites More sharing options...
