Android - Forward and reverse
Hello,
I have a Nexus 7 and a Minix neo x7.  My server is Win 7 x64.  I can load movies and resume from my stopping place.  But I can't (about a 1% success rate) fast forward or reverse via the seek bar.  It just drops the movie and goes back to the menu system.  Any cure for this?
Thank you.
Redshirt
I'm not sure what's going on there. I've just tested numerous media files, with several seek attempts per file, and only had one manual seek fail. I'd like to see a log from both the client and the server during a seek attempt. There will likely be multiple log files in both the server log dir and the Android log dir so it's best if you delete them all and start with a clean slate.
Server logs are located in C:\Users\[your username]\AppData\Roaming\MediaBrowser-Server\logs
Android logs are located on the sdcard at \Mb3AndroidData\Logs
  • 2 weeks later...
The issue is on my Nexus.  I will get you some logs soon.
