MB Classic - Detail View - Chocolate
Go to solution Solved by lja,
On my HTPC, I have a few movies that the overview shows as intended on the list view. However on the details view there is no overview. The same movies are ok in Neo and MBTheater. I have also tested on another computer and all is well. The movies are stored on my server. Thanks for help to correct this. If required, what logs should I post?
I have had to adjust the MBCommonXml,config to fit the movie to my 2.37 screen and it appears this causes the problem where the overview is wide.
Edited by lja
  • Solution
Resetting MBCommonXml.config resolved the issue.
