HDHomerun keeps popping up
I'm using HDHomerun with NPVR and every time I restart Emby it keeps adding HDHomerun for EmbyTV. How can I block HDHomerun from appearing in Emby?
EDIT: It seems to pop up even if I don't restart server. This is very annoying.
Edited by Damstas
mellomade
Unfortunately Emby Server auto detects the tuner and there is no way to stop this. You just have to click on the tuner and uncheck 'enable this tuner' and save. Then EmbyTV will ignore this device.
bluemonkey07
Click on the device in the server dashboard and then unselect enable this tuner..... Not the trashcan
Edited by Vidman
Thank you both. I just clicked the trashcan. :P
mellomade
OK - but you got that the point was to 'not' just click the trash can right?  It will come back if you do that.
Yeah. I used to click the trashcan thinking it was the solution. :P
