EmbyTV artwork caching question
Hi.
How does EmbyTV handle the artwork caching, when SD updates their upstream and the result is newer/better artwork? Is there some kind of periodic checking etc? I'm asking this, so it could be done to the NPVR plugin aswell.
For example: Usually generic artworks will have proper images after upstream check from SD, so how will they be updated to Emby, since Emby already has the older artwork loaded.
- Damstas
Edited by Damstas
  • 2 weeks later...
Still waiting for an answer.. Basically just wondering what does Emby(TV) do when Schedules Direct has new artwork of the show (new season etc)?
I'm thinking of helping to develop this kind of function to NPVR, but does Emby support it? If it already has cached artwork of the show it won't download the newer artwork?
Edited by Damstas
