tired dad 28 Posted December 1, 2013 Share Posted December 1, 2013 Hello, I see the merit of letting each user customize the GUI, but is there a way of making them all the same once the theme is changed? I use the NEO theme and I like to enable the vertical scroll on the poster view. It's hard enough to have to do for each of ten or so movie collections, but to do it for each user it gets downright tedious (I have separate acconuts for the admin, parents, and kids). Any assistance would be appreciated. TD Link to comment Share on other sites More sharing options...
ebr 14912 Posted December 1, 2013 Share Posted December 1, 2013 Not at this time. 1 Link to comment Share on other sites More sharing options...
tired dad 28 Posted December 1, 2013 Author Share Posted December 1, 2013 OK thanks Link to comment Share on other sites More sharing options...
Solution tired dad 28 Posted December 7, 2013 Author Solution Share Posted December 7, 2013 Update: I found the folder C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations and the xml files within for the themes have a line <WrapVerticalLists>False</WrapVerticalLists> So I just set that to "True" and it worked across all profiles. I was also able to update the xml files so that each user XML used the same theme. Link to comment Share on other sites More sharing options...
