johnodon 18 Posted September 4, 2015 Posted September 4, 2015 I am using v3.0.5724.3 inside of a Docker container. I was able to connect the new Live TV to my HDHR and setup Schedules Direct. However, I am unable to pull any guide data or even view channels. Looking at the syslog (attached) I can see lots of exception errors. Log.txt
johnodon 18 Posted September 8, 2015 Author Posted September 8, 2015 OK...to rule out an existing configuration issue, I built a brand new docker container. The only thing I did was add my Live TV settings (no media folders were added or any other configuration changes made). I am still not able to get Live TV working. If I go to Scheduled Tasks and force a Refresh Guide Data, it runs for 0 seconds (as shown in the log). Latest log file attached... I don't know what else to try. My HDHR works fine with Myth, Kodi, HDHomerun View, etc. John Log-08sep2015.txt
johnodon 18 Posted September 9, 2015 Author Posted September 9, 2015 Working now. Apparently you need to add channels via the HDHR web interface (IP of the HDHR device) and not just via the HDHomerun Setup utility. It is refreshing Guide Data now. John
