Problem transcoding on a WD TV Live (WDBAAP000NBK01)
transcoding problem
  • Please log in to reply
No replies to this topic
#1 marc_al OFFLINE
marc_al
    Advanced Member
  • Members
  • 50 posts
  • Local time: 08:18 AM
Posted 29 August 2015 - 01:34 AM
Hello,
I am trying to play a video on a WD TV Live (by DLNA)
Some video work perfectly, but some not.
The video that doesn't play is a High profile level 5.0 (so Emby tries to re-encode it, that is correct).
When I start the video, I have a black screen 2-3 sec. then I have a message telling me that the file is not supported.
My problem is that I don't understand what is wrong. I guess that something is wrong in the encoding profile but I have no clue about what.
Can someone please tell me what is wrong?
When I launch the command line manually (in the transcoding long), there is no error.
Here is the information about the video (original with Plex)
VIDEO
  • codec H264
  • Bitrate 2627 kbps
  • Bit Depth 8
  • CABAC 1
  • Chroma Subsampling 4:2:0
  • Color Space yuv
  • Durée 25:10
  • Frame Rate 23.976 fps
  • Frame Rate Mode cfr
  • Has Scaling Matrix 0
  • Height 1080
  • Level 5.0
  • Profile high
  • Ref Frames 8
  • Scan Type progressive
  • Stream Identifier 1
  • Width 1920
Audio
  • Codec AAC
  • Chaînes Stéréo
  • Bitrate 162 kbps
  • Audio Channel Layout stereo
  • Bitrate Mode VBR
  • Durée 25:10
  • Profile lc
  • Sampling Rate 48000 Hz
  • Stream Identifier 2
EDIT : The same file plays fine in Plex (the transcode is right).
If I look at the transcode.log and I execute the command line (ffmpeg) then I copy the temp file in a USB key, the file reads, so it seems to be a DLNA problem when there is a transcode (as non transcoded video play fine).
EDIT2 : I have put a custom firmware on the WD TV Live and the WD reports that the bitrate of the video is 10000000 kbps  (10M). Is there a parameter to specify so the bitrate (seen by the DLNa clientà is a real one?
Can someone please help me?
Thank you
Marc
Edited by marc_al, 30 August 2015 - 08:13 AM.
Also tagged with one or more of these keywords: transcoding problem
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
