Finding my TV Tuner IP address
TV Tuner IP addresses Diamond HD750 USB tuner
  • Please log in to reply
2 replies to this topic
#1 fjd0 OFFLINE
fjd0
    Newbie
  • Members
  • 2 posts
  • Local time: 12:27 AM
Posted 27 August 2015 - 10:58 AM
I have installed the latest Beta Server and am learning a lot.  Considering switching from Plex to Emby as Emby seems to have native support for TV Tuners so I can see Live (from Antenna) Local TV on all my devices from one tuner connected to the server. Questions:
1. Is the Diamond HD750 USB tuner supported?  Great tuner, have been using for years with MCE.
2. As I try to set this up the prompt is asking me for the IP Address of my tuner.  How do I discover that?
Looking forward to making this happen.  Wisdom from the forum is appreciated.
Thanks
Frank
#2 mellomade OFFLINE
mellomade
    Advanced Member
  • Members
  • 468 posts
  • Local time: 06:27 PM
  • LocationHouston, TX
Posted 27 August 2015 - 11:04 AM
1.  Only HDHomeRun DLNA tuners are support ATM. (CONNECT, EXTEND, and Prime)
2.  You cannot (in your case) because your tuner is not a network attached tuner.
#3 fjd0 OFFLINE
fjd0
    Newbie
  • Members
  • 2 posts
Posted 27 August 2015 - 11:39 PM
Thanks for the advice
Did some reading and bought the Connect 2 tuner on dale at newegg
Looking forward to setting it up
Also tagged with one or more of these keywords: TV Tuner, IP addresses, Diamond HD750 USB tuner
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
