Go to solution Solved by 1ch_h4lt,
AlwinHummels
What's the best way to use path substitution when my local path on Emby is as follow:
 /volume1/music
 /volume1/movie etc...
Now I use this /volume1/music --> \\IP from server\music
 /volume1/movie --> \\IP from server\movie and so on.
Is this the correct way? Or should I use smb://IP from server/music
or maybe even better nfs://IP from server/music
I use Kodi on windows 10 and on 2 raspberry Pi2 systems.
Thanks for all help
AlwinHummels
Ok can some moderator replace this topic to the kodi section? Thanks
Edited by AlwinHummels
  • 3 weeks later...
  • Solution
Hi AlwinHummels
I am using following Pathsubstitution with success:
/media/Serien -> \\server.fritz.box\video\Serien
/media/Filme -> \\server.firtz.box\video\Filme
i am using the DNS Server of my fritz.box (Internet Router) but you can also use the ip address
/media/Serien -> \\192.168.x.x\video\Serien
remember to safe your user and password in the emby for kodi plugin.
have fun!
  • Like 1
AlwinHummels
Hi AlwinHummels
have fun!
Thanks a lot
