Setzer1994 Posted June 24, 2015 Share Posted June 24, 2015 I have been trying out Emby over a MySQL setup and so far so good. I'm ready to make a permanent switch if I can just figure out this one little issue I'm having. When the MySQL server was controlling the databases, Artist fan art (and extrafanart) was displaying in any folder/subfolder that was "below" the artist structure. Meaning, if I have fan art in /media/music/Van Halen/extrafanart, it would also display in Kodi when I'm at the album level ( media/music/Van Halen/1984 ). However, Kodi is no longer displaying the fanart when I'm browsing songs within an album. For example: But when I get to the song level, it displays the default backdrop instead: It's definitely something I'm missing with the Emby setup. When I delete the emby addon and re-add the MySQL references to my advancedsettings.xml file and restart, everything goes back to normal. I've also tried deleting .nfo files and that does not help. Any thoughts? Is there a simple setting that I'm missing? Link to comment Share on other sites More sharing options...
Setzer1994 Posted June 29, 2015 Author Share Posted June 29, 2015 I've tried re-running through some MP3s through MusicBrainz, no luck. Changed a bunch of settings in Emby, no luck there either. Went through Artist Slideshow settings in Kodi, didn't work. About out of options, anyone have any thoughts? Link to comment Share on other sites More sharing options...
Setzer1994 Posted July 15, 2015 Author Share Posted July 15, 2015 Ok so I think I discovered an issue - I went into my Kodi log and saw these lines: 10:15:00 T:4356 NOTICE: Thread BackgroundLoader start, auto delete: false10:15:02 T:3012 NOTICE: Previous line repeats 1 times.10:15:02 T:3012 ERROR: XFILE::CDirectory::GetDirectory - Error getting smb://192.168.1.12/M/Music/Van Halen/1984/extrafanart/10:15:10 T:3736 ERROR: Previous line repeats 1 times. Basically, Emby is looking for an extrafanart directory that doesn't exist. Is there a setting in the server that allows defaulting to the artist extrafanart folder instead of looking for one in each album? Link to comment Share on other sites More sharing options...
marcelveldt Posted July 15, 2015 Share Posted July 15, 2015 I am going to do some work on the music section of the addon next week, I will also fix this. BTW: It depends on the skin you're using if this works or not. Most skins do not support extrafanart. Link to comment Share on other sites More sharing options...
Setzer1994 Posted July 15, 2015 Author Share Posted July 15, 2015 marcelveldt - thank you so much for the reply. I am using a supported skin, specifically the MQ6 beta. It uses the Artwork Slideshow addon, which pulls down the images for display from the /extrafanart/ artist folders. Link to comment Share on other sites More sharing options...
Setzer1994 Posted August 5, 2015 Author Share Posted August 5, 2015 marcelveldt - I installed the latest Beta 1.1.25 and this has mostly been fixed, thanks again! Basically what it is doing now is now displaying the default fanart with the song view, but still searching for a non-existent extrafanart folder under the album (essentially same log snippet as before). Obviously the default art is much better than a blank screen, but just wanted to let you know that I tested it and got the same errors in the log. Thanks again! Link to comment Share on other sites More sharing options...
marcelveldt Posted August 5, 2015 Share Posted August 5, 2015 (edited) Extrafanart for music is not natively supported by Kodi. There are a few workarounds in some skins but most of the times they do not work properly. This is NOT an issue with the Emby addon but with the skin you're using. First, because at the album and artist level, Kodi has no clue about the actual file path (because that is only stored at file level). Some skins work aroud that by letting you supply the path to your musiccollection and they "try" to locate the artwork. In this case your skin tries to locate the artwork at the album level while it should look one level further up (artist level). BTW: I'm about to publish some helper scripts for Kodi skin devs to workaround these issues but it will take a little while before this will be available. The default (single) fanart images at the album and song level is stored in Kodi (and so by the Emby addon) and that was fixed a few days ago which you confirmed, right ? Edited August 5, 2015 by marcelveldt Link to comment Share on other sites More sharing options...
Setzer1994 Posted August 6, 2015 Author Share Posted August 6, 2015 Extrafanart for music is not natively supported by Kodi. There are a few workarounds in some skins but most of the times they do not work properly. This is NOT an issue with the Emby addon but with the skin you're using. First, because at the album and artist level, Kodi has no clue about the actual file path (because that is only stored at file level). Some skins work aroud that by letting you supply the path to your musiccollection and they "try" to locate the artwork. In this case your skin tries to locate the artwork at the album level while it should look one level further up (artist level). BTW: I'm about to publish some helper scripts for Kodi skin devs to workaround these issues but it will take a little while before this will be available. The default (single) fanart images at the album and song level is stored in Kodi (and so by the Emby addon) and that was fixed a few days ago which you confirmed, right ? Thank you very much for the additional clarification. Yes, I am confirming that the default fanart is displaying at the song level. I'll follow up with the skin developers to see if they can investigate further. Thanks again for all your help. Link to comment Share on other sites More sharing options...
