wiretap
I seem to be having a slight problem with the IPTV plugin. I don't believe it is the plugin's fault, but possibly the Emby Server side, transcoding, or even the web browser. Currently it is working under Emby Theater, Emby for Android and Emby for Kindle. When I go to the Emby web client under Google Chrome, it will not display video or audio, just a black screen.
I have the IPTV plugin installed with RTSP streams coming from my Ubiquiti UniFi Video Cameras.
Here is what a working log looks like from the clients I have currently working:
(see down below after this log for the web client which doesn't work)
http://192.168.1.113:8096/videos/d1bcb6de4124e31def037ec88f3ee35d/stream.mp4?DeviceId=f87efcc71d08a74180944a1ec1b9611c63b07af4&MediaSourceId=053122d1ec71cdbcffce1a2a7793f08e&VideoCodec=h264&AudioCodec=aac&VideoBitrate=1372000&AudioBitrate=128000&MaxAudioChannels=2&MaxWidth=1280&Level=41&ClientTime=635667906067009206&Profile=high&PlaySessionId=d2de185902184809b19e1f2b35368a7a&api_key=63f14aa82a9348cebb47dc47b37fd475
{"Protocol":"Rtmp","Id":"053122d1ec71cdbcffce1a2a7793f08e","Path":"rtsp://192.168.1.113:7447/67f22897-e419-3645-ab79-a1745ece7f02_1","Type":"Default","Name":"053122d1ec71cdbcffce1a2a7793f08e","ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":false,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":false,"MediaStreams":[],"PlayableStreamFileNames":[],"Formats":[],"RequiredHttpHeaders":{}}
C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\ffmpeg\20150331\ffmpeg.exe -fflags +genpts -i "rtsp://192.168.1.113:7447/67f22897-e419-3645-ab79-a1745ece7f02_1" -sn -codec:v:0 libx264 -force_key_frames expr:gte(t,n_forced*5) -vf "scale=min(iw\,1280):trunc(ow/dar/2)*2" -pix_fmt yuv420p -preset superfast -crf 18 -maxrate 1372000 -bufsize 2744000 -vsync vfr -profile:v high -level 41 -map_metadata -1 -threads 0 -codec:a:0 aac -strict experimental -ac 2 -ab 128000 -af "aresample=async=1" -f mp4 -movflags frag_keyframe+empty_moov -y "P:\~MediaBrowser\transcoding-temp\d94c1f3d453ac60e5211825e9d636193.mp4"
ffmpeg version N-71182-g5cba529 Copyright (c) 2000-2015 the FFmpeg developers
  built with gcc 4.9.2 (GCC)
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-lzma --enable-decklink --enable-zlib
  libavutil      54. 21.100 / 54. 21.100
  libavcodec     56. 32.100 / 56. 32.100
  libavformat    56. 27.100 / 56. 27.100
  libavdevice    56.  4.100 / 56.  4.100
  libavfilter     5. 13.101 /  5. 13.101
  libswscale      3.  1.101 /  3.  1.101
  libswresample   1.  1.100 /  1.  1.100
  libpostproc    53.  3.100 / 53.  3.100
Input #0, rtsp, from 'rtsp://192.168.1.113:7447/67f22897-e419-3645-ab79-a1745ece7f02_1':
  Metadata:
    title           : 0418D623CE8B_1
  Duration: N/A, start: 0.113107, bitrate: N/A
    Stream #0:0: Audio: aac (LC), 11025 Hz, mono, fltp
    Stream #0:1: Video: h264 (Main), yuvj420p(pc, bt709), 720x400 [SAR 80:81 DAR 16:9], 15 fps, 15 tbr, 90k tbn, 30 tbc
[swscaler @ 0000000002e5f200] deprecated pixel format used, make sure you did set range correctly
[libx264 @ 00000000059d00a0] using SAR=404/405
[libx264 @ 00000000059d00a0] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
[libx264 @ 00000000059d00a0] profile High, level 4.1
[libx264 @ 00000000059d00a0] 264 - core 146 r2538 121396c - H.264/MPEG-4 AVC codec - Copyleft 2003-2015 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x3:0x3 me=dia subme=1 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=6 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=15 scenecut=40 intra_refresh=0 rc_lookahead=0 rc=crf mbtree=0 crf=18.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=1372 vbv_bufsize=2744 crf_max=0.0 nal_hrd=none filler=0 ip_ratio=1.40 pb_ratio=1.30 aq=1:1.00
Output #0, mp4, to 'P:\~MediaBrowser\transcoding-temp\d94c1f3d453ac60e5211825e9d636193.mp4':
  Metadata:
    encoder         : Lavf56.27.100
    Stream #0:0: Video: h264 (libx264) ([33][0][0][0] / 0x0021), yuv420p, 720x404 [SAR 404:405 DAR 16:9], q=-1--1, max. 1372 kb/s, 15 fps, 15360 tbn, 15 tbc
    Metadata:
      encoder         : Lavc56.32.100 libx264
    Stream #0:1: Audio: aac ([64][0][0][0] / 0x0040), 11025 Hz, stereo, fltp, 128 kb/s
    Metadata:
      encoder         : Lavc56.32.100 aac
Stream mapping:
  Stream #0:1 -> #0:0 (h264 (native) -> h264 (libx264))
  Stream #0:0 -> #0:1 (aac (native) -> aac (native))
Press [q] to stop, [?] for help
Past duration 0.756660 too large
Past duration 0.736656 too large
Past duration 0.701653 too large
Past duration 0.696663 too large
Past duration 0.766655 too large
Past duration 0.686653 too large
Past duration 0.711662 too large
Past duration 0.761665 too large
Past duration 0.721657 too large
Past duration 0.606667 too large
[NULL @ 0000000002e73400] RTP: missed 5 packets
[h264 @ 00000000095b3160] error while decoding MB 16 23, bytestream -32
[h264 @ 00000000095b3160] concealing 123 DC, 123 AC, 123 MV errors in I frame
Past duration 0.731667 too large
frame=   27 fps=0.0 q=15.0 size=       1kB time=00:00:02.22 bitrate=   4.5kbits/s dup=0 drop=5
Past duration 0.681664 too large
Past duration 0.751656 too large
Past duration 0.666664 too large
frame=   35 fps= 33 q=14.0 size=       1kB time=00:00:02.78 bitrate=   3.6kbits/s dup=0 drop=5
[h264 @ 00000000095b3160] error while decoding MB 17 23, bytestream -10
[h264 @ 00000000095b3160] concealing 122 DC, 122 AC, 122 MV errors in I frame
frame=   39 fps= 23 q=14.0 size=       1kB time=00:00:03.06 bitrate=   3.3kbits/s dup=0 drop=5
Past duration 0.706657 too large
Past duration 0.741661 too large
Past duration 0.716652 too large
frame=   51 fps= 23 q=15.0 size=       1kB time=00:00:03.90 bitrate=   2.6kbits/s dup=0 drop=5
[NULL @ 0000000002e73400] RTP: missed 4 packets
[h264 @ 00000000095b3160] error while decoding MB 20 23, bytestream -50
[h264 @ 00000000095b3160] concealing 119 DC, 119 AC, 119 MV errors in I frame
Past duration 0.746666 too large
Past duration 0.726662 too large
frame=   60 fps= 22 q=16.0 size=       1kB time=00:00:04.45 bitrate=   2.2kbits/s dup=0 drop=5
[h264 @ 00000000095b3160] error while decoding MB 20 23, bytestream -38
frame=   69 fps= 20 q=15.0 size=       1kB time=00:00:05.01 bitrate=   2.0kbits/s dup=0 drop=5
frame=   79 fps= 20 q=15.0 size=       1kB time=00:00:05.66 bitrate=   1.8kbits/s dup=0 drop=5
[h264 @ 00000000095b3160] error while decoding MB 22 23, bytestream -48
[h264 @ 00000000095b3160] concealing 117 DC, 117 AC, 117 MV errors in I frame
frame=   86 fps= 19 q=21.0 size=     969kB time=00:00:06.22 bitrate=1275.8kbits/s dup=0 drop=5
frame=   94 fps= 19 q=15.0 size=     969kB time=00:00:06.68 bitrate=1187.2kbits/s dup=0 drop=5
Past duration 0.651665 too large
[h264 @ 00000000095b3160] error while decoding MB 25 23, bytestream -68
[h264 @ 00000000095b3160] concealing 114 DC, 114 AC, 114 MV errors in I frame
frame=   99 fps= 16 q=18.0 size=     969kB time=00:00:07.15 bitrate=1110.1kbits/s dup=0 drop=5
[NULL @ 0000000002e73400] RTP: missed 8 packets
[h264 @ 0000000009605500] error while decoding MB 23 21, bytestream -12
[h264 @ 0000000009605500] concealing 206 DC, 206 AC, 206 MV errors in P frame
Past duration 0.621666 too large
[h264 @ 00000000096b5b40] error while decoding MB 23 23, bytestream -46
[h264 @ 00000000096b5b40] concealing 116 DC, 116 AC, 116 MV errors in I frame
frame=  119 fps= 18 q=16.0 size=     969kB time=00:00:08.35 bitrate= 949.7kbits/s dup=0 drop=5
frame=  126 fps= 18 q=15.0 size=     969kB time=00:00:08.91 bitrate= 890.4kbits/s dup=0 drop=5
[h264 @ 00000000096b5b40] error while decoding MB 23 23, bytestream -56
frame=  128 fps= 17 q=16.0 size=     969kB time=00:00:09.00 bitrate= 881.2kbits/s dup=0 drop=5
frame=  142 fps= 17 q=14.0 size=     969kB time=00:00:09.93 bitrate= 798.8kbits/s dup=0 drop=5
[h264 @ 00000000096b5b40] error while decoding MB 23 23, bytestream -39
frame=  150 fps= 17 q=14.0 size=     969kB time=00:00:10.49 bitrate= 756.4kbits/s dup=0 drop=5
[h264 @ 00000000096b5b40] error while decoding MB 25 23, bytestream -10
[h264 @ 00000000096b5b40] concealing 114 DC, 114 AC, 114 MV errors in I frame
frame=  158 fps= 16 q=25.0 size=     969kB time=00:00:11.05 bitrate= 718.3kbits/s dup=0 drop=5
[h264 @ 00000000096b5b40] error while decoding MB 24 23, bytestream -12
[h264 @ 00000000096b5b40] concealing 115 DC, 115 AC, 115 MV errors in I frame
frame=  174 fps= 17 q=18.0 size=    1874kB time=00:00:12.07 bitrate=1271.7kbits/s dup=0 drop=5
frame=  181 fps= 17 q=14.0 size=    1874kB time=00:00:12.63 bitrate=1215.6kbits/s dup=0 drop=5
frame=  183 fps= 17 q=-1.0 Lsize=    2240kB time=00:00:12.81 bitrate=1431.4kbits/s dup=0 drop=5
video:2123kB audio:113kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.189996%
[libx264 @ 00000000059d00a0] frame I:3     Avg QP:15.47  size: 71706
[libx264 @ 00000000059d00a0] frame P:47    Avg QP:16.12  size: 20772
[libx264 @ 00000000059d00a0] frame B:133   Avg QP:16.67  size:  7378
[libx264 @ 00000000059d00a0] consecutive B-frames:  2.7%  1.1%  0.0% 96.2%
[libx264 @ 00000000059d00a0] mb I  I16..4:  1.3%  4.4% 94.2%
[libx264 @ 00000000059d00a0] mb P  I16..4:  0.1%  0.1%  0.0%  P16..4: 91.8%  0.0%  0.0%  0.0%  0.0%    skip: 8.0%
[libx264 @ 00000000059d00a0] mb B  I16..4:  0.0%  0.0%  0.0%  B16..8: 25.0%  0.0%  0.0%  direct:39.8%  skip:35.2%  L0:34.1% L1:61.0% BI: 4.9%
[libx264 @ 00000000059d00a0] 8x8 transform intra:5.5% inter:30.1%
[libx264 @ 00000000059d00a0] coded y,uvDC,uvAC intra: 96.6% 94.0% 79.3% inter: 42.2% 25.0% 1.5%
[libx264 @ 00000000059d00a0] i16 v,h,dc,p:  9% 82%  6%  2%
[libx264 @ 00000000059d00a0] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 13% 46% 13%  3%  4%  3%  6%  1% 11%
[libx264 @ 00000000059d00a0] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 20% 35%  7%  5%  7%  5%  8%  4%  9%
[libx264 @ 00000000059d00a0] i8c dc,h,v,p: 31% 30% 28% 11%
[libx264 @ 00000000059d00a0] Weighted P-Frames: Y:0.0% UV:0.0%
[libx264 @ 00000000059d00a0] kb/s:1424.74
Here's the transcode log for when I try to play it from the web client:
(server log also attached)
http://192.168.1.113:8096/videos/d1bcb6de4124e31def037ec88f3ee35d/stream.webm?DeviceId=01697e56dc9e645cb2543b150ec7cacc29d06393&MediaSourceId=053122d1ec71cdbcffce1a2a7793f08e&VideoCodec=vpx&AudioCodec=vorbis&VideoBitrate=29872000&AudioBitrate=128000&MaxWidth=1920&ClientTime=635667900292354754&PlaySessionId=2d0cae29e6f043938b69a73784bcf870&api_key=1f071737179c4c0bb2db382c247f3495
C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\ffmpeg\20150331\ffmpeg.exe -fflags +genpts -i "rtsp://192.168.1.113:7447/67f22897-e419-3645-ab79-a1745ece7f02_1" -sn -codec:v:0 libvpx -force_key_frames expr:gte(t,n_forced*5) -vf "scale=min(iw\,1920):trunc(ow/dar/2)*2" -pix_fmt yuv420p -speed 16 -quality good -profile:v 0 -slices 8 -crf 4 -qmin 0 -qmax 50 -maxrate:v 29872000 -bufsize:v (29872000*2) -b:v 29872000 -vsync vfr -map_metadata -1 -threads 3 -codec:a:0 libvorbis -ab 128000 -af "aresample=async=1" -y "P:\~MediaBrowser\transcoding-temp\d42b9db41cefafff1be64543af891cc2.webm"
[h264 @ 0000000002c83340] RTP: missed 8 packets
[h264 @ 0000000002c83340] error while decoding MB 15 22, bytestream -56
[h264 @ 0000000002c83340] concealing 169 DC, 169 AC, 169 MV errors in I frame
  Metadata:
  Duration: N/A, start: 0.000000, bitrate: N/A
[swscaler @ 0000000002c77fe0] deprecated pixel format used, make sure you did set range correctly
[libvpx @ 0000000002ce3ea0] v1.3.0
[libvorbis @ 0000000002ce4ee0] encoder setup failed
Output #0, webm, to 'P:\~MediaBrowser\transcoding-temp\d42b9db41cefafff1be64543af891cc2.webm':
    Stream #0:0: Video: vp8 (libvpx), yuv420p, 720x404 [SAR 404:405 DAR 16:9], q=0-50, 29872 kb/s, 15 fps, 15 tbn, 15 tbc
    Metadata:
      encoder         : Lavc56.32.100 libvpx
    Stream #0:1: Audio: vorbis, 0 channels, 128 kb/s
    Metadata:
      encoder         : Lavc56.32.100 libvorbis
Stream mapping:
  Stream #0:1 -> #0:0 (h264 (native) -> vp8 (libvpx))
  Stream #0:0 -> #0:1 (aac (native) -> vorbis (libvorbis))
Error while opening encoder for output stream #0:1 - maybe incorrect parameters such as bit_rate, rate, width or height
Log.txt
Edited by wiretap
