Missing Movies - DB Query
Go to solution Solved by Anno Dom,
I just added some movies to my media drive (cut/paste) and suddenly only the new movies show.
The Collections db is fine and still there, but all other movies are not reflecting even after i re-scanned the directory.
I then deleted the refresh.db file after going through some posts here.... no change.
I then deleted the library.db file (...mediabrowser-server/data/ library.db), which worked until I shut down the server and restarted it. Then only new movies showed again.
Very weird?
I have attached the most recent logs to see if anyone can help?
server-63564730532.txt
server-63564733236.txt
Sorry server version is 3.0.5572.0, forgot to add that
  • Solution
Okay... problem solved
Turns out that by putting some new movies in a hdd that had info from the old os after a re-install of windows 7 resets UAC and security. So now i have to manually enter all the folders to allow access. Sorry for the trouble
  • Like 1
