tipex 2 Posted April 10, 2015 Share Posted April 10, 2015 Hi all, I'm setting up a raspberry PI (for testing) with ARCHlinux. Yesterday when I tried to install mediabrowser-server, it worked fine. So far so good. Today I started with a fresh linux Installation and I wanted to install emby-server. During package creation (makepkg -s) I got the message: error: failed retrieving file 'harfbuzz-0.9.40-1-armv6h.pkg.tar.xz' from mirror.archlinuxarm.org : The requested URL returned error: 404 When I checked the archlinuxarm.org mirror I found there the version 0.9.40-2. Now I cannot install emby-server nor mediabrowser-server, because I receive for both the same error message. Can sombodey help me out? Thank a lot. Thomas Link to comment Share on other sites More sharing options...
thefirstofthe300 290 Posted April 10, 2015 Share Posted April 10, 2015 sudo pacman -Syy You local pacman database is out of date so you need to update it. If you run the above command it is recommended that you also update using pacman -Syu as bad things can happen if you don't. Link to comment Share on other sites More sharing options...
tipex 2 Posted April 10, 2015 Author Share Posted April 10, 2015 Now makepkg is running :-) Thank you! Yesterday I was already running pacman -Syu (had to modify after that cmdline.txt). I wasn't aware that I have to run also pacman -Syy. Again thank you! Link to comment Share on other sites More sharing options...
