Not Scanning Sub Folders
Hey Everyone,
So I recently loaded this up as a replacement here at home for MediaTomb.  So far its working but its been a struggle.
I initially built this out with a FreeNAS plugin but the MediaBrowser process would randomly die.  So instead I built out a Ubuntu VM with 4GB of Ram and 2CPU on 14.04.  The process would still randomly die during scans but with each update I get it would become more and more stable so that is why I didn't post about the dreaded .net error Object Ref not set to an instance of an object (I used to dabble in C# years ago and I hated that error lol)  So anyways I have my folder hierarchy like so
Movies
          TV Shows
          Kids Movies
I keep everything all tucked into one folder for simplicity with MythTV and other things.
But MediaBrowser wasn't scanning my Kids or TV shows folder, even with the type labeled as Movies and TV
So I setup a new library for Kids Movies as Movies and another library for TV Shows and set the library location to the appropriate sub folder.  Its been setup now like this for over a week and MediaBrowser does not show anything located within those libraries.  I'd really like to get it to scan those new libraries so I can setup my kids tablet with the android app and his account so he is stuck with just kids movies :).
Thank you all in advance for your help.  If there are any logs you need or what not let me know.  I have splunk setup on the VM and its indexing the MediaBrowser log file.
thefirstofthe300
Can you post screenshots of your library configuration and the folder structure?
That would help a lot.
As requested here are the screen shots of my library.  I expanded them so you can see the full path.  Thanks.54ae1af688a36_Library1.png
Thanks for your help
thefirstofthe300
So I gather that there are movies in the folder "Movies and the such" ( /mnt/share/Movies and the such/movie.ext ) and that is the reason that you have the multiple movie library definitions?  Also what version of the server are you running?
Can you try removing the library "Movies" and leaving the "Kids Movies" and "TV shows" libraries and do a library scan?
@@Luke Would this folder structure cause issues as the server has one path in two libraries?
Ok so I deleted the Movies library and I'm scanning now.  Will let you know how it goes.
So yes that did work.  So now what I've done is created sym links for all 3 of my libraries so I'll just add them in that way and see how that goes.
thefirstofthe300
Ok. The simplest way to do this might be to simply move the TV shows and Kids Movies to the /mnt/share directory. Then simply add them from there.
I think what is happening is that the server is choking on having the same file paths in multiple libraries, so you just need to eliminate that somehow.
Thats a little simpler said than done.  So for now I have created symlinks in the /mnt/ such as /mnt/TV /mnt/Movies /mnt/Kids.  The MB Server does not see the symlink in the WebUI but when I typed out the path it saw it just fine.  Since these are actually NFS mounts on my freenas box.  If I were to move things like that it would really screw up a lot of things such as MythTV.  So in order to keep the house happy I'll just see how this symlink fix goes and then if need be I'll move it from there.  So far its up to 30% complete on its scan and thumping along nicely as far as I can tell.  I'll let you all know when it completes how it went.
Also does this error mean anything to anyone?
2015-01-08 11:42:23.0049 Error - Main: UnhandledException *** Error Report *** Version: 3.0.5482.1 Command line: /opt/mediabrowser/MediaBrowser.Server.Mono.exe -programdata /var/lib/mediabrowser Operating system: Unix 3.13.0.43 Processor count: 2 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/mediabrowser Mono: 3.2.8 (Debian 3.2.8+dfsg-4ubuntu1) Application Path: /opt/mediabrowser/MediaBrowser.Server.Mono.exe The underlying Task is already in one of the three final states: RanToCompletion, Faulted, or Canceled. System.InvalidOperationException at System.Threading.Tasks.TaskCompletionSource`1[System.Int32].SetException (IEnumerable`1 exceptions) [0x00000] in <filename unknown>:0 at System.Threading.Tasks.TaskCompletionSource`1[System.Int32].SetException (System.Exception exception) [0x00000] in <filename unknown>:0 at System.Threading.Tasks.TaskFactory`1[System.Int32].InnerInvoke (System.Threading.Tasks.TaskCompletionSource`1 tcs, System.Func`2 endMethod, IAsyncResult l) [0x00000] in <filename unknown>:0 at System.Threading.Tasks.TaskFactory`1+<FromAsyncBeginEnd>c__AnonStorey5`3[System.Int32,System.Byte[],System.Int32,System.Int32].<>m__0 (IAsyncResult l) [0x00000] in <filename unknown>:0 at System.Net.WebAsyncResult.CB (System.Object unused) [0x00000] in <filename unknown>:0
That was thrown and then the system died. My Nagios restarted it and its back to chomping along
thefirstofthe300
@@Luke What do you make of the error?
@@thefuzz4 Can you please post the entire log file for that error? It would help Luke a lot.
Ok so I can't post the whole thing as its too big lol.  So here is from 11:40am to 11:42am MST when the server died
2015-01-08 11:40:00.2345 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/62214/hdmovieclearart/frankenweenie-51bf77c486c42.png
2015-01-08 11:40:02.4097 Debug - ProviderManager: Saving image to /mnt/Kids/Frankenweenie/clearart.png
2015-01-08 11:40:02.4730 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/62214/moviebanner/frankenweenie-51bf77ad2aaa5.jpg
2015-01-08 11:40:02.8495 Debug - ProviderManager: Saving image to /mnt/Kids/Frankenweenie/banner.jpg
2015-01-08 11:40:02.8956 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/62214/moviedisc/frankenweenie-51307ede3117a.png
2015-01-08 11:40:03.4557 Debug - ProviderManager: Saving image to /mnt/Kids/Frankenweenie/disc.png
2015-01-08 11:40:03.5092 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/62214/hdmovielogo/frankenweenie-508bb68ddc4c5.png
2015-01-08 11:40:03.8137 Debug - ProviderManager: Saving image to /mnt/Kids/Frankenweenie/logo.png
2015-01-08 11:40:03.8576 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/62214/moviethumb/frankenweenie-51bf77b509357.jpg
2015-01-08 11:40:04.2459 Debug - ProviderManager: Saving image to /mnt/Kids/Frankenweenie/landscape.jpg
2015-01-08 11:40:04.2883 Debug - ProviderManager: Saving /mnt/Kids/Frankenweenie/Frankenweenie.m4v to Media Browser Xml.
2015-01-08 11:40:04.3084 Debug - ProviderManager: Saving /mnt/Kids/Frankenweenie/Frankenweenie.m4v to Nfo.
2015-01-08 11:40:04.3948 Debug - App: Saving /mnt/Kids/Frankenweenie/Frankenweenie.m4v to database.
2015-01-08 11:40:04.4672 Debug - App: Running MovieXmlProvider for /mnt/Kids/Disney Swiss Family Robinson/Swiss Family Robinson.m4v
2015-01-08 11:40:04.4693 Debug - App: MovieXmlProvider returned no metadata for /mnt/Kids/Disney Swiss Family Robinson/Swiss Family Robinson.m4v
2015-01-08 11:40:04.4693 Debug - App: Running MovieNfoProvider for /mnt/Kids/Disney Swiss Family Robinson/Swiss Family Robinson.m4v
2015-01-08 11:40:04.4693 Debug - App: MovieNfoProvider returned no metadata for /mnt/Kids/Disney Swiss Family Robinson/Swiss Family Robinson.m4v
2015-01-08 11:40:04.4693 Debug - App: Running MovieDbProvider for /mnt/Kids/Disney Swiss Family Robinson/Swiss Family Robinson.m4v
2015-01-08 11:40:04.4704 Info - App: MovieDbProvider: Finding id for item: Disney Swiss Family Robinson
2015-01-08 11:40:04.4715 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Disney+Swiss+Family+Robinson&language=en
2015-01-08 11:40:04.4717 Debug - App: Running MovieXmlProvider for /mnt/Kids/How To Train Your Dragon/How To Train Your Dragon.m4v
2015-01-08 11:40:04.4756 Debug - App: MovieXmlProvider returned no metadata for /mnt/Kids/How To Train Your Dragon/How To Train Your Dragon.m4v
2015-01-08 11:40:04.4757 Debug - App: Running MovieNfoProvider for /mnt/Kids/How To Train Your Dragon/How To Train Your Dragon.m4v
2015-01-08 11:40:04.4757 Debug - App: MovieNfoProvider returned no metadata for /mnt/Kids/How To Train Your Dragon/How To Train Your Dragon.m4v
2015-01-08 11:40:04.4757 Debug - App: Running MovieDbProvider for /mnt/Kids/How To Train Your Dragon/How To Train Your Dragon.m4v
2015-01-08 11:40:04.4777 Info - App: MovieDbProvider: Finding id for item: How To Train Your Dragon
2015-01-08 11:40:05.3678 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=How+To+Train+Your+Dragon&language=en
2015-01-08 11:40:05.3704 Debug - App: MovieDbProvider returned no metadata for /mnt/Kids/Disney Swiss Family Robinson/Swiss Family Robinson.m4v
2015-01-08 11:40:05.3704 Debug - App: Running OmdbItemProvider for /mnt/Kids/Disney Swiss Family Robinson/Swiss Family Robinson.m4v
2015-01-08 11:40:05.3719 Info - App: MovieDbProvider: Finding id for item: Disney Swiss Family Robinson
2015-01-08 11:40:05.5055 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Disney+Swiss+Family+Robinson&language=en
2015-01-08 11:40:05.6158 Debug - App: OmdbItemProvider returned no metadata for /mnt/Kids/Disney Swiss Family Robinson/Swiss Family Robinson.m4v
2015-01-08 11:40:05.6158 Debug - App: Running FFProbeProvider for /mnt/Kids/Disney Swiss Family Robinson/Swiss Family Robinson.m4v
2015-01-08 11:40:05.6169 Debug - MediaEncoder: /var/lib/mediabrowser/ffmpeg/20140716/ffprobe -i file:"/mnt/Kids/Disney Swiss Family Robinson/Swiss Family Robinson.m4v" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format
2015-01-08 11:40:05.6798 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/movie/10191?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null
2015-01-08 11:40:06.0049 Debug - App: Running OmdbItemProvider for /mnt/Kids/How To Train Your Dragon/How To Train Your Dragon.m4v
2015-01-08 11:40:06.0225 Info - App: HttpClientManager GET: http://www.omdbapi.com/?i=tt0892769&tomatoes=true
2015-01-08 11:40:06.0701 Debug - App: Running MovieDbImageProvider for /mnt/Kids/Disney Swiss Family Robinson/Swiss Family Robinson.m4v
2015-01-08 11:40:06.0710 Debug - App: Running FanartMovieImageProvider for /mnt/Kids/Disney Swiss Family Robinson/Swiss Family Robinson.m4v
2015-01-08 11:40:06.0720 Debug - App: Running OmdbImageProvider for /mnt/Kids/Disney Swiss Family Robinson/Swiss Family Robinson.m4v
2015-01-08 11:40:06.0720 Debug - App: Running VideoImageProvider for /mnt/Kids/Disney Swiss Family Robinson/Swiss Family Robinson.m4v
2015-01-08 11:40:06.1404 Debug - App: Running FFProbeProvider for /mnt/Kids/How To Train Your Dragon/How To Train Your Dragon.m4v
2015-01-08 11:40:06.1412 Debug - MediaEncoder: /var/lib/mediabrowser/ffmpeg/20140716/ffprobe -i file:"/mnt/Kids/How To Train Your Dragon/How To Train Your Dragon.m4v" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format
2015-01-08 11:40:06.8579 Info - App: HttpClientManager POST: http://api.opensubtitles.org/xml-rpc
2015-01-08 11:40:07.0837 Debug - ProviderManager: Saving image to /mnt/Kids/Disney Swiss Family Robinson/poster.jpg
2015-01-08 11:40:07.1419 Debug - ProviderManager: Saving /mnt/Kids/Disney Swiss Family Robinson/Swiss Family Robinson.m4v to Media Browser Xml.
2015-01-08 11:40:07.1932 Debug - ProviderManager: Saving /mnt/Kids/Disney Swiss Family Robinson/Swiss Family Robinson.m4v to Nfo.
2015-01-08 11:40:07.2158 Debug - App: Saving /mnt/Kids/Disney Swiss Family Robinson/Swiss Family Robinson.m4v to database.
2015-01-08 11:40:07.5385 Info - App: HttpClientManager POST: http://api.opensubtitles.org/xml-rpc
2015-01-08 11:40:08.7241 Info - App: HttpClientManager POST: http://api.opensubtitles.org/xml-rpc
2015-01-08 11:40:09.4155 Info - SubtitleManager: Saving subtitles to /mnt/Kids/How To Train Your Dragon/How To Train Your Dragon.eng.srt
2015-01-08 11:40:09.4804 Debug - App: Running MovieDbImageProvider for /mnt/Kids/How To Train Your Dragon/How To Train Your Dragon.m4v
2015-01-08 11:40:09.4857 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/zMAm3WYmvD40FaWFsOmpicQFabz.jpg
2015-01-08 11:40:09.9202 Debug - ProviderManager: Saving image to /mnt/Kids/How To Train Your Dragon/poster.jpg
2015-01-08 11:40:10.0388 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/nMulOcoR6HAahofkcuo4mtA0o9j.jpg
2015-01-08 11:40:10.3953 Debug - ProviderManager: Saving image to /mnt/Kids/How To Train Your Dragon/fanart.jpg
2015-01-08 11:40:10.4431 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/kQ0Sq4ihGmBq6r00S7KmhtOyO6Z.jpg
2015-01-08 11:40:10.9961 Debug - ProviderManager: Saving image to /mnt/Kids/How To Train Your Dragon/extrafanart/fanart1.jpg
2015-01-08 11:40:11.0884 Debug - ProviderManager: Saving image to /mnt/Kids/How To Train Your Dragon/extrathumbs/thumb1.jpg
2015-01-08 11:40:11.1812 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/3eR9HOkPZUbrGWDRdKHeKoiMLc4.jpg
2015-01-08 11:40:11.3496 Debug - ProviderManager: Saving image to /mnt/Kids/How To Train Your Dragon/extrafanart/fanart2.jpg
2015-01-08 11:40:11.4231 Debug - ProviderManager: Saving image to /mnt/Kids/How To Train Your Dragon/extrathumbs/thumb2.jpg
2015-01-08 11:40:11.4753 Debug - App: Running FanartMovieImageProvider for /mnt/Kids/How To Train Your Dragon/How To Train Your Dragon.m4v
2015-01-08 11:40:11.4769 Info - App: HttpClientManager GET: http://webservice.fanart.tv/v3/movies/10191?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4
2015-01-08 11:40:16.4184 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/10191/hdmovieclearart/how-to-train-your-dragon-506ffe732b22e.png
2015-01-08 11:40:17.0611 Debug - ProviderManager: Saving image to /mnt/Kids/How To Train Your Dragon/clearart.png
2015-01-08 11:40:17.1208 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/10191/moviebanner/how-to-train-your-dragon-53386ba496ac2.jpg
2015-01-08 11:40:17.4264 Debug - ProviderManager: Saving image to /mnt/Kids/How To Train Your Dragon/banner.jpg
2015-01-08 11:40:17.4561 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/10191/moviedisc/how-to-train-your-dragon-51399f947e054.png
2015-01-08 11:40:18.0952 Debug - ProviderManager: Saving image to /mnt/Kids/How To Train Your Dragon/disc.png
2015-01-08 11:40:18.1702 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/10191/hdmovielogo/how-to-train-your-dragon-5053b67a4b0e4.png
2015-01-08 11:40:18.6798 Debug - ProviderManager: Saving image to /mnt/Kids/How To Train Your Dragon/logo.png
2015-01-08 11:40:18.7480 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/10191/moviethumb/how-to-train-your-dragon-53386c16343aa.jpg
2015-01-08 11:40:19.0519 Debug - ProviderManager: Saving image to /mnt/Kids/How To Train Your Dragon/landscape.jpg
2015-01-08 11:40:19.0897 Debug - ProviderManager: Saving /mnt/Kids/How To Train Your Dragon/How To Train Your Dragon.m4v to Media Browser Xml.
2015-01-08 11:40:19.1127 Debug - ProviderManager: Saving /mnt/Kids/How To Train Your Dragon/How To Train Your Dragon.m4v to Nfo.
2015-01-08 11:40:19.1441 Debug - App: Saving /mnt/Kids/How To Train Your Dragon/How To Train Your Dragon.m4v to database.
2015-01-08 11:40:19.2127 Debug - App: Running MovieXmlProvider for /mnt/Kids/G-Force/G-Force.m4v
2015-01-08 11:40:19.2194 Debug - App: Running MovieXmlProvider for /mnt/Kids/Disney A Bug's Life/A Bug's Life.m4v
2015-01-08 11:40:19.2204 Debug - App: MovieXmlProvider returned no metadata for /mnt/Kids/G-Force/G-Force.m4v
2015-01-08 11:40:19.2204 Debug - App: Running MovieNfoProvider for /mnt/Kids/G-Force/G-Force.m4v
2015-01-08 11:40:19.2204 Debug - App: MovieNfoProvider returned no metadata for /mnt/Kids/G-Force/G-Force.m4v
2015-01-08 11:40:19.2207 Debug - App: Running MovieDbProvider for /mnt/Kids/G-Force/G-Force.m4v
2015-01-08 11:40:19.2217 Info - App: MovieDbProvider: Finding id for item: G-Force
2015-01-08 11:40:19.2217 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=G-Force&language=en
2015-01-08 11:40:19.2245 Debug - App: MovieXmlProvider returned no metadata for /mnt/Kids/Disney A Bug's Life/A Bug's Life.m4v
2015-01-08 11:40:19.2245 Debug - App: Running MovieNfoProvider for /mnt/Kids/Disney A Bug's Life/A Bug's Life.m4v
2015-01-08 11:40:19.2247 Debug - App: MovieNfoProvider returned no metadata for /mnt/Kids/Disney A Bug's Life/A Bug's Life.m4v
2015-01-08 11:40:19.2247 Debug - App: Running MovieDbProvider for /mnt/Kids/Disney A Bug's Life/A Bug's Life.m4v
2015-01-08 11:40:19.2261 Info - App: MovieDbProvider: Finding id for item: Disney A Bug's Life
2015-01-08 11:40:19.4699 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Disney+A+Bug's+Life&language=en
2015-01-08 11:40:19.7353 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/movie/19585?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null
2015-01-08 11:40:19.7353 Debug - App: MovieDbProvider returned no metadata for /mnt/Kids/Disney A Bug's Life/A Bug's Life.m4v
2015-01-08 11:40:19.7357 Debug - App: Running OmdbItemProvider for /mnt/Kids/Disney A Bug's Life/A Bug's Life.m4v
2015-01-08 11:40:19.7357 Info - App: MovieDbProvider: Finding id for item: Disney A Bug's Life
2015-01-08 11:40:19.8425 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Disney+A+Bug's+Life&language=en
2015-01-08 11:40:20.0743 Debug - App: Running OmdbItemProvider for /mnt/Kids/G-Force/G-Force.m4v
2015-01-08 11:40:20.0802 Info - App: HttpClientManager GET: http://www.omdbapi.com/?i=tt0436339&tomatoes=true
2015-01-08 11:40:20.2368 Debug - App: OmdbItemProvider returned no metadata for /mnt/Kids/Disney A Bug's Life/A Bug's Life.m4v
2015-01-08 11:40:20.2368 Debug - App: Running FFProbeProvider for /mnt/Kids/Disney A Bug's Life/A Bug's Life.m4v
2015-01-08 11:40:20.4315 Debug - MediaEncoder: /var/lib/mediabrowser/ffmpeg/20140716/ffprobe -i file:"/mnt/Kids/Disney A Bug's Life/A Bug's Life.m4v" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format
2015-01-08 11:40:21.8361 Debug - App: Running FFProbeProvider for /mnt/Kids/G-Force/G-Force.m4v
2015-01-08 11:40:21.8371 Debug - MediaEncoder: /var/lib/mediabrowser/ffmpeg/20140716/ffprobe -i file:"/mnt/Kids/G-Force/G-Force.m4v" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format
2015-01-08 11:40:22.3317 Info - App: HttpClientManager POST: http://api.opensubtitles.org/xml-rpc
2015-01-08 11:40:22.5693 Debug - App: Running MovieDbImageProvider for /mnt/Kids/Disney A Bug's Life/A Bug's Life.m4v
2015-01-08 11:40:22.5702 Debug - App: Running FanartMovieImageProvider for /mnt/Kids/Disney A Bug's Life/A Bug's Life.m4v
2015-01-08 11:40:22.5708 Debug - App: Running OmdbImageProvider for /mnt/Kids/Disney A Bug's Life/A Bug's Life.m4v
2015-01-08 11:40:22.5708 Debug - App: Running VideoImageProvider for /mnt/Kids/Disney A Bug's Life/A Bug's Life.m4v
2015-01-08 11:40:23.2444 Debug - ProviderManager: Saving image to /mnt/Kids/Disney A Bug's Life/poster.jpg
2015-01-08 11:40:23.3090 Debug - ProviderManager: Saving /mnt/Kids/Disney A Bug's Life/A Bug's Life.m4v to Media Browser Xml.
2015-01-08 11:40:23.3331 Debug - ProviderManager: Saving /mnt/Kids/Disney A Bug's Life/A Bug's Life.m4v to Nfo.
2015-01-08 11:40:23.3606 Debug - App: Saving /mnt/Kids/Disney A Bug's Life/A Bug's Life.m4v to database.
2015-01-08 11:40:23.4870 Info - App: HttpClientManager POST: http://api.opensubtitles.org/xml-rpc
2015-01-08 11:40:24.3160 Info - SubtitleManager: Saving subtitles to /mnt/Kids/G-Force/G-Force.eng.srt
2015-01-08 11:40:24.3598 Debug - App: Running MovieDbImageProvider for /mnt/Kids/G-Force/G-Force.m4v
2015-01-08 11:40:24.3681 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/ecTQ40F6Ob4JW2qMRUf8ThxViyd.jpg
2015-01-08 11:40:24.7836 Debug - ProviderManager: Saving image to /mnt/Kids/G-Force/poster.jpg
2015-01-08 11:40:24.8274 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/dnBiiPKJnIKb1e8BcDo3cicdjFG.jpg
2015-01-08 11:40:25.2533 Debug - ProviderManager: Saving image to /mnt/Kids/G-Force/fanart.jpg
2015-01-08 11:40:25.3983 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/4chqA0RqJxpDRU3zpmjyCkvcLMu.jpg
2015-01-08 11:40:25.9769 Debug - ProviderManager: Saving image to /mnt/Kids/G-Force/extrafanart/fanart1.jpg
2015-01-08 11:40:26.0956 Debug - ProviderManager: Saving image to /mnt/Kids/G-Force/extrathumbs/thumb1.jpg
2015-01-08 11:40:26.3067 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/uEeuHrsp6TIT7uu9q9sRxiZNlMa.jpg
2015-01-08 11:40:26.8640 Debug - ProviderManager: Saving image to /mnt/Kids/G-Force/extrafanart/fanart2.jpg
2015-01-08 11:40:26.9060 Debug - ProviderManager: Saving image to /mnt/Kids/G-Force/extrathumbs/thumb2.jpg
2015-01-08 11:40:26.9681 Debug - App: Running FanartMovieImageProvider for /mnt/Kids/G-Force/G-Force.m4v
2015-01-08 11:40:26.9699 Info - App: HttpClientManager GET: http://webservice.fanart.tv/v3/movies/19585?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4
2015-01-08 11:40:27.3138 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/19585/hdmovieclearart/g-force-5452a2ac39a99.png
2015-01-08 11:40:29.3496 Debug - ProviderManager: Saving image to /mnt/Kids/G-Force/clearart.png
2015-01-08 11:40:29.4252 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/19585/moviebanner/g-force-542c13bbe4c1e.jpg
2015-01-08 11:40:29.7629 Debug - ProviderManager: Saving image to /mnt/Kids/G-Force/banner.jpg
2015-01-08 11:40:29.8062 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/19585/moviedisc/g-force-51320d2301000.png
2015-01-08 11:40:31.3432 Debug - ProviderManager: Saving image to /mnt/Kids/G-Force/disc.png
2015-01-08 11:40:31.4397 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/19585/hdmovielogo/g-force-51fad239be403.png
2015-01-08 11:40:31.7571 Debug - ProviderManager: Saving image to /mnt/Kids/G-Force/logo.png
2015-01-08 11:40:31.8007 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/19585/moviethumb/g-force-542c13d26be9f.jpg
2015-01-08 11:40:32.1793 Debug - ProviderManager: Saving image to /mnt/Kids/G-Force/landscape.jpg
2015-01-08 11:40:32.2365 Debug - ProviderManager: Saving /mnt/Kids/G-Force/G-Force.m4v to Media Browser Xml.
2015-01-08 11:40:32.2662 Debug - ProviderManager: Saving /mnt/Kids/G-Force/G-Force.m4v to Nfo.
2015-01-08 11:40:32.3445 Debug - App: Saving /mnt/Kids/G-Force/G-Force.m4v to database.
2015-01-08 11:40:32.3702 Debug - App: Running MovieXmlProvider for /mnt/Kids/Disney Bed Knobs and Broom Sticks/Bed Knobs and Broom Sticks.m4v
2015-01-08 11:40:32.3733 Debug - App: Running MovieXmlProvider for /mnt/Kids/An Extremely Goofy Movie/An Extremely Goofy Movie.m4v
2015-01-08 11:40:32.3755 Debug - App: MovieXmlProvider returned no metadata for /mnt/Kids/Disney Bed Knobs and Broom Sticks/Bed Knobs and Broom Sticks.m4v
2015-01-08 11:40:32.3755 Debug - App: Running MovieNfoProvider for /mnt/Kids/Disney Bed Knobs and Broom Sticks/Bed Knobs and Broom Sticks.m4v
2015-01-08 11:40:32.3757 Debug - App: MovieNfoProvider returned no metadata for /mnt/Kids/Disney Bed Knobs and Broom Sticks/Bed Knobs and Broom Sticks.m4v
2015-01-08 11:40:32.3757 Debug - App: Running MovieDbProvider for /mnt/Kids/Disney Bed Knobs and Broom Sticks/Bed Knobs and Broom Sticks.m4v
2015-01-08 11:40:32.3773 Info - App: MovieDbProvider: Finding id for item: Disney Bed Knobs and Broom Sticks
2015-01-08 11:40:32.3784 Debug - App: MovieXmlProvider returned no metadata for /mnt/Kids/An Extremely Goofy Movie/An Extremely Goofy Movie.m4v
2015-01-08 11:40:32.3784 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Disney+Bed+Knobs+and+Broom+Sticks&language=en
2015-01-08 11:40:32.3784 Debug - App: Running MovieNfoProvider for /mnt/Kids/An Extremely Goofy Movie/An Extremely Goofy Movie.m4v
2015-01-08 11:40:32.3788 Debug - App: MovieNfoProvider returned no metadata for /mnt/Kids/An Extremely Goofy Movie/An Extremely Goofy Movie.m4v
2015-01-08 11:40:32.3788 Debug - App: Running MovieDbProvider for /mnt/Kids/An Extremely Goofy Movie/An Extremely Goofy Movie.m4v
2015-01-08 11:40:32.3801 Info - App: MovieDbProvider: Finding id for item: An Extremely Goofy Movie
2015-01-08 11:40:32.6097 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=An+Extremely+Goofy+Movie&language=en
2015-01-08 11:40:32.6130 Debug - App: MovieDbProvider returned no metadata for /mnt/Kids/Disney Bed Knobs and Broom Sticks/Bed Knobs and Broom Sticks.m4v
2015-01-08 11:40:32.6130 Debug - App: Running OmdbItemProvider for /mnt/Kids/Disney Bed Knobs and Broom Sticks/Bed Knobs and Broom Sticks.m4v
2015-01-08 11:40:32.6146 Info - App: MovieDbProvider: Finding id for item: Disney Bed Knobs and Broom Sticks
2015-01-08 11:40:32.7489 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Disney+Bed+Knobs+and+Broom+Sticks&language=en
2015-01-08 11:40:32.8548 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/movie/15653?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null
2015-01-08 11:40:32.8548 Debug - App: OmdbItemProvider returned no metadata for /mnt/Kids/Disney Bed Knobs and Broom Sticks/Bed Knobs and Broom Sticks.m4v
2015-01-08 11:40:32.8557 Debug - App: Running FFProbeProvider for /mnt/Kids/Disney Bed Knobs and Broom Sticks/Bed Knobs and Broom Sticks.m4v
2015-01-08 11:40:32.8581 Debug - MediaEncoder: /var/lib/mediabrowser/ffmpeg/20140716/ffprobe -i file:"/mnt/Kids/Disney Bed Knobs and Broom Sticks/Bed Knobs and Broom Sticks.m4v" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format
2015-01-08 11:40:33.1761 Debug - App: Running MovieDbImageProvider for /mnt/Kids/Disney Bed Knobs and Broom Sticks/Bed Knobs and Broom Sticks.m4v
2015-01-08 11:40:33.1767 Debug - App: Running FanartMovieImageProvider for /mnt/Kids/Disney Bed Knobs and Broom Sticks/Bed Knobs and Broom Sticks.m4v
2015-01-08 11:40:33.1781 Debug - App: Running OmdbImageProvider for /mnt/Kids/Disney Bed Knobs and Broom Sticks/Bed Knobs and Broom Sticks.m4v
2015-01-08 11:40:33.1787 Debug - App: Running VideoImageProvider for /mnt/Kids/Disney Bed Knobs and Broom Sticks/Bed Knobs and Broom Sticks.m4v
2015-01-08 11:40:33.2468 Debug - App: Running OmdbItemProvider for /mnt/Kids/An Extremely Goofy Movie/An Extremely Goofy Movie.m4v
2015-01-08 11:40:33.2667 Info - App: HttpClientManager GET: http://www.omdbapi.com/?i=tt0208185&tomatoes=true
2015-01-08 11:40:33.5658 Debug - App: Running FFProbeProvider for /mnt/Kids/An Extremely Goofy Movie/An Extremely Goofy Movie.m4v
2015-01-08 11:40:33.5667 Debug - MediaEncoder: /var/lib/mediabrowser/ffmpeg/20140716/ffprobe -i file:"/mnt/Kids/An Extremely Goofy Movie/An Extremely Goofy Movie.m4v" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format
2015-01-08 11:40:33.9326 Info - App: HttpClientManager POST: http://api.opensubtitles.org/xml-rpc
2015-01-08 11:40:33.9547 Debug - ProviderManager: Saving image to /mnt/Kids/Disney Bed Knobs and Broom Sticks/poster.jpg
2015-01-08 11:40:33.9961 Debug - ProviderManager: Saving /mnt/Kids/Disney Bed Knobs and Broom Sticks/Bed Knobs and Broom Sticks.m4v to Media Browser Xml.
2015-01-08 11:40:34.0322 Debug - ProviderManager: Saving /mnt/Kids/Disney Bed Knobs and Broom Sticks/Bed Knobs and Broom Sticks.m4v to Nfo.
2015-01-08 11:40:34.0608 Debug - App: Saving /mnt/Kids/Disney Bed Knobs and Broom Sticks/Bed Knobs and Broom Sticks.m4v to database.
2015-01-08 11:40:34.8736 Info - App: HttpClientManager POST: http://api.opensubtitles.org/xml-rpc
2015-01-08 11:40:35.4705 Info - SubtitleManager: Saving subtitles to /mnt/Kids/An Extremely Goofy Movie/An Extremely Goofy Movie.eng.srt
2015-01-08 11:40:35.5518 Debug - App: Running MovieDbImageProvider for /mnt/Kids/An Extremely Goofy Movie/An Extremely Goofy Movie.m4v
2015-01-08 11:40:35.5567 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/k6O8kLaNhdueuimHihqL5ZPPf9k.jpg
2015-01-08 11:40:35.9088 Debug - ProviderManager: Saving image to /mnt/Kids/An Extremely Goofy Movie/poster.jpg
2015-01-08 11:40:36.0134 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/niXov7pwbNUy9gb8yJaaBlCtPm7.jpg
2015-01-08 11:40:36.3117 Debug - ProviderManager: Saving image to /mnt/Kids/An Extremely Goofy Movie/fanart.jpg
2015-01-08 11:40:36.3669 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/rSDxLbWIcIGso5yDGkotuo5PpSb.jpg
2015-01-08 11:40:36.7783 Debug - ProviderManager: Saving image to /mnt/Kids/An Extremely Goofy Movie/extrafanart/fanart1.jpg
2015-01-08 11:40:36.9226 Debug - ProviderManager: Saving image to /mnt/Kids/An Extremely Goofy Movie/extrathumbs/thumb1.jpg
2015-01-08 11:40:36.9801 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/5WgpagnYpHQxcSwRdxHtvCJI7B7.jpg
2015-01-08 11:40:37.2048 Debug - ProviderManager: Saving image to /mnt/Kids/An Extremely Goofy Movie/extrafanart/fanart2.jpg
2015-01-08 11:40:37.2654 Debug - ProviderManager: Saving image to /mnt/Kids/An Extremely Goofy Movie/extrathumbs/thumb2.jpg
2015-01-08 11:40:37.2993 Debug - App: Running FanartMovieImageProvider for /mnt/Kids/An Extremely Goofy Movie/An Extremely Goofy Movie.m4v
2015-01-08 11:40:37.3007 Info - App: HttpClientManager GET: http://webservice.fanart.tv/v3/movies/15653?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4
2015-01-08 11:40:43.7141 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/15653/moviedisc/an-extremely-goofy-movie-5050f2a28af59.png
2015-01-08 11:40:44.4885 Debug - ProviderManager: Saving image to /mnt/Kids/An Extremely Goofy Movie/disc.png
2015-01-08 11:40:44.5787 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/15653/hdmovielogo/an-extremely-goofy-movie-510dc643f37ac.png
2015-01-08 11:40:45.2141 Debug - ProviderManager: Saving image to /mnt/Kids/An Extremely Goofy Movie/logo.png
2015-01-08 11:40:45.2484 Debug - ProviderManager: Saving /mnt/Kids/An Extremely Goofy Movie/An Extremely Goofy Movie.m4v to Media Browser Xml.
2015-01-08 11:40:45.3077 Debug - ProviderManager: Saving /mnt/Kids/An Extremely Goofy Movie/An Extremely Goofy Movie.m4v to Nfo.
2015-01-08 11:40:45.3318 Debug - App: Saving /mnt/Kids/An Extremely Goofy Movie/An Extremely Goofy Movie.m4v to database.
2015-01-08 11:40:45.3539 Debug - App: Running MovieXmlProvider for /mnt/Kids/Sandlot/The Sandlot.m4v
2015-01-08 11:40:45.3584 Debug - App: Running MovieXmlProvider for /mnt/Kids/Disney Monsters, Inc/Monsters, Inc.m4v
2015-01-08 11:40:45.3595 Debug - App: MovieXmlProvider returned no metadata for /mnt/Kids/Sandlot/The Sandlot.m4v
2015-01-08 11:40:45.3595 Debug - App: Running MovieNfoProvider for /mnt/Kids/Sandlot/The Sandlot.m4v
2015-01-08 11:40:45.3598 Debug - App: MovieNfoProvider returned no metadata for /mnt/Kids/Sandlot/The Sandlot.m4v
2015-01-08 11:40:45.3598 Debug - App: Running MovieDbProvider for /mnt/Kids/Sandlot/The Sandlot.m4v
2015-01-08 11:40:45.3598 Debug - App: MovieXmlProvider returned no metadata for /mnt/Kids/Disney Monsters, Inc/Monsters, Inc.m4v
2015-01-08 11:40:45.3598 Debug - App: Running MovieNfoProvider for /mnt/Kids/Disney Monsters, Inc/Monsters, Inc.m4v
2015-01-08 11:40:45.3608 Debug - App: MovieNfoProvider returned no metadata for /mnt/Kids/Disney Monsters, Inc/Monsters, Inc.m4v
2015-01-08 11:40:45.3608 Info - App: MovieDbProvider: Finding id for item: Sandlot
2015-01-08 11:40:45.3608 Debug - App: Running MovieDbProvider for /mnt/Kids/Disney Monsters, Inc/Monsters, Inc.m4v
2015-01-08 11:40:45.3618 Info - App: MovieDbProvider: Finding id for item: Disney Monsters, Inc
2015-01-08 11:40:45.3618 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Sandlot&language=en
2015-01-08 11:40:45.7063 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Disney+Monsters%2c+Inc&language=en
2015-01-08 11:40:46.2026 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/movie/11528?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null
2015-01-08 11:40:46.3262 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Disney+Monsters++Inc&language=en
2015-01-08 11:40:46.3281 Debug - App: Running OmdbItemProvider for /mnt/Kids/Sandlot/The Sandlot.m4v
2015-01-08 11:40:46.3338 Info - App: HttpClientManager GET: http://www.omdbapi.com/?i=tt0108037&tomatoes=true
2015-01-08 11:40:46.6221 Debug - App: Running FFProbeProvider for /mnt/Kids/Sandlot/The Sandlot.m4v
2015-01-08 11:40:46.6228 Debug - MediaEncoder: /var/lib/mediabrowser/ffmpeg/20140716/ffprobe -i file:"/mnt/Kids/Sandlot/The Sandlot.m4v" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format
2015-01-08 11:40:46.6782 Debug - App: MovieDbProvider returned no metadata for /mnt/Kids/Disney Monsters, Inc/Monsters, Inc.m4v
2015-01-08 11:40:46.6782 Debug - App: Running OmdbItemProvider for /mnt/Kids/Disney Monsters, Inc/Monsters, Inc.m4v
2015-01-08 11:40:46.6811 Info - App: MovieDbProvider: Finding id for item: Disney Monsters, Inc
2015-01-08 11:40:46.6823 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Disney+Monsters%2c+Inc&language=en
2015-01-08 11:40:47.0094 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Disney+Monsters++Inc&language=en
2015-01-08 11:40:47.0209 Debug - App: Running MovieDbImageProvider for /mnt/Kids/Sandlot/The Sandlot.m4v
2015-01-08 11:40:47.0842 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/fKJUQrAm5QbVR5DqgH9U5IflHGQ.jpg
2015-01-08 11:40:47.0853 Debug - App: OmdbItemProvider returned no metadata for /mnt/Kids/Disney Monsters, Inc/Monsters, Inc.m4v
2015-01-08 11:40:47.0891 Debug - App: Running FFProbeProvider for /mnt/Kids/Disney Monsters, Inc/Monsters, Inc.m4v
2015-01-08 11:40:47.0903 Debug - MediaEncoder: /var/lib/mediabrowser/ffmpeg/20140716/ffprobe -i file:"/mnt/Kids/Disney Monsters, Inc/Monsters, Inc.m4v" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format
2015-01-08 11:40:47.3818 Debug - App: Running MovieDbImageProvider for /mnt/Kids/Disney Monsters, Inc/Monsters, Inc.m4v
2015-01-08 11:40:47.3818 Debug - App: Running FanartMovieImageProvider for /mnt/Kids/Disney Monsters, Inc/Monsters, Inc.m4v
2015-01-08 11:40:47.3830 Debug - App: Running OmdbImageProvider for /mnt/Kids/Disney Monsters, Inc/Monsters, Inc.m4v
2015-01-08 11:40:47.3830 Debug - App: Running VideoImageProvider for /mnt/Kids/Disney Monsters, Inc/Monsters, Inc.m4v
2015-01-08 11:40:48.2374 Debug - ProviderManager: Saving image to /mnt/Kids/Disney Monsters, Inc/poster.jpg
2015-01-08 11:40:48.2935 Debug - ProviderManager: Saving /mnt/Kids/Disney Monsters, Inc/Monsters, Inc.m4v to Media Browser Xml.
2015-01-08 11:40:48.4093 Debug - ProviderManager: Saving /mnt/Kids/Disney Monsters, Inc/Monsters, Inc.m4v to Nfo.
2015-01-08 11:40:48.4372 Debug - App: Saving /mnt/Kids/Disney Monsters, Inc/Monsters, Inc.m4v to database.
2015-01-08 11:40:48.6427 Debug - ProviderManager: Saving image to /mnt/Kids/Sandlot/poster.jpg
2015-01-08 11:40:48.7034 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/wSejWDOrdNj5jQO0Ql3oTwiRiSG.jpg
2015-01-08 11:40:49.0772 Debug - ProviderManager: Saving image to /mnt/Kids/Sandlot/fanart.jpg
2015-01-08 11:40:49.1172 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/vw370lxDNwp984BAFdo3UXlKsX5.jpg
2015-01-08 11:40:49.7561 Debug - ProviderManager: Saving image to /mnt/Kids/Sandlot/extrafanart/fanart1.jpg
2015-01-08 11:40:49.8367 Debug - ProviderManager: Saving image to /mnt/Kids/Sandlot/extrathumbs/thumb1.jpg
2015-01-08 11:40:49.8873 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/5hjKhwhuZbOoFUATJvp8ndG0ur4.jpg
2015-01-08 11:40:50.0358 Debug - ProviderManager: Saving image to /mnt/Kids/Sandlot/extrafanart/fanart2.jpg
2015-01-08 11:40:50.0680 Debug - ProviderManager: Saving image to /mnt/Kids/Sandlot/extrathumbs/thumb2.jpg
2015-01-08 11:40:50.1038 Debug - App: Running FanartMovieImageProvider for /mnt/Kids/Sandlot/The Sandlot.m4v
2015-01-08 11:40:50.1143 Info - App: HttpClientManager GET: http://webservice.fanart.tv/v3/movies/11528?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4
2015-01-08 11:40:58.5324 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/11528/moviedisc/the-sandlot-537d57991c4dc.png
2015-01-08 11:40:59.2679 Debug - ProviderManager: Saving image to /mnt/Kids/Sandlot/disc.png
2015-01-08 11:40:59.3523 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/11528/hdmovielogo/the-sandlot-50fe1ae9b2643.png
2015-01-08 11:40:59.6494 Debug - ProviderManager: Saving image to /mnt/Kids/Sandlot/logo.png
2015-01-08 11:40:59.6850 Debug - ProviderManager: Saving /mnt/Kids/Sandlot/The Sandlot.m4v to Media Browser Xml.
2015-01-08 11:40:59.7116 Debug - ProviderManager: Saving /mnt/Kids/Sandlot/The Sandlot.m4v to Nfo.
2015-01-08 11:40:59.8360 Debug - App: Saving /mnt/Kids/Sandlot/The Sandlot.m4v to database.
2015-01-08 11:40:59.8437 Debug - App: Running FolderXmlProvider for /mnt/Kids/Confessions Of A Teenage Drama Queen
2015-01-08 11:40:59.8452 Debug - App: FolderXmlProvider returned no metadata for /mnt/Kids/Confessions Of A Teenage Drama Queen
2015-01-08 11:40:59.8457 Debug - App: Saving /mnt/Kids/Confessions Of A Teenage Drama Queen to database.
2015-01-08 11:40:59.8514 Debug - App: Running MovieXmlProvider for /mnt/Kids/Disney Megamind/Megamind.m4v
2015-01-08 11:40:59.8554 Debug - App: MovieXmlProvider returned no metadata for /mnt/Kids/Disney Megamind/Megamind.m4v
2015-01-08 11:40:59.8554 Debug - App: Running MovieNfoProvider for /mnt/Kids/Disney Megamind/Megamind.m4v
2015-01-08 11:40:59.8566 Debug - App: Running MovieXmlProvider for /mnt/Kids/James and the Giant Peach/James and the Giant Peach.m4v
2015-01-08 11:40:59.8582 Debug - App: MovieNfoProvider returned no metadata for /mnt/Kids/Disney Megamind/Megamind.m4v
2015-01-08 11:40:59.8587 Debug - App: Running MovieDbProvider for /mnt/Kids/Disney Megamind/Megamind.m4v
2015-01-08 11:40:59.8587 Info - App: MovieDbProvider: Finding id for item: Disney Megamind
2015-01-08 11:40:59.8587 Debug - App: MovieXmlProvider returned no metadata for /mnt/Kids/James and the Giant Peach/James and the Giant Peach.m4v
2015-01-08 11:40:59.8587 Debug - App: Running MovieNfoProvider for /mnt/Kids/James and the Giant Peach/James and the Giant Peach.m4v
2015-01-08 11:40:59.8597 Debug - App: MovieNfoProvider returned no metadata for /mnt/Kids/James and the Giant Peach/James and the Giant Peach.m4v
2015-01-08 11:40:59.8597 Debug - App: Running MovieDbProvider for /mnt/Kids/James and the Giant Peach/James and the Giant Peach.m4v
2015-01-08 11:40:59.8608 Info - App: MovieDbProvider: Finding id for item: James and the Giant Peach
2015-01-08 11:40:59.8608 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Disney+Megamind&language=en
2015-01-08 11:41:00.3788 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=James+and+the+Giant+Peach&language=en
2015-01-08 11:41:00.3803 Debug - App: MovieDbProvider returned no metadata for /mnt/Kids/Disney Megamind/Megamind.m4v
2015-01-08 11:41:00.3803 Debug - App: Running OmdbItemProvider for /mnt/Kids/Disney Megamind/Megamind.m4v
2015-01-08 11:41:00.3815 Info - App: MovieDbProvider: Finding id for item: Disney Megamind
2015-01-08 11:41:00.5209 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Disney+Megamind&language=en
2015-01-08 11:41:00.6302 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/movie/10539?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null
2015-01-08 11:41:00.6302 Debug - App: OmdbItemProvider returned no metadata for /mnt/Kids/Disney Megamind/Megamind.m4v
2015-01-08 11:41:00.6313 Debug - App: Running FFProbeProvider for /mnt/Kids/Disney Megamind/Megamind.m4v
2015-01-08 11:41:00.6319 Debug - MediaEncoder: /var/lib/mediabrowser/ffmpeg/20140716/ffprobe -i file:"/mnt/Kids/Disney Megamind/Megamind.m4v" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format
2015-01-08 11:41:01.0439 Debug - App: Running OmdbItemProvider for /mnt/Kids/James and the Giant Peach/James and the Giant Peach.m4v
2015-01-08 11:41:01.0489 Info - App: HttpClientManager GET: http://www.omdbapi.com/?i=tt0116683&tomatoes=true
2015-01-08 11:41:01.1164 Debug - App: Running FFProbeProvider for /mnt/Kids/James and the Giant Peach/James and the Giant Peach.m4v
2015-01-08 11:41:01.1265 Debug - MediaEncoder: /var/lib/mediabrowser/ffmpeg/20140716/ffprobe -i file:"/mnt/Kids/James and the Giant Peach/James and the Giant Peach.m4v" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format
2015-01-08 11:41:01.3617 Info - App: HttpClientManager POST: http://api.opensubtitles.org/xml-rpc
2015-01-08 11:41:01.5454 Debug - App: Running MovieDbImageProvider for /mnt/Kids/Disney Megamind/Megamind.m4v
2015-01-08 11:41:01.5463 Debug - App: Running FanartMovieImageProvider for /mnt/Kids/Disney Megamind/Megamind.m4v
2015-01-08 11:41:01.5475 Debug - App: Running OmdbImageProvider for /mnt/Kids/Disney Megamind/Megamind.m4v
2015-01-08 11:41:01.5477 Debug - App: Running VideoImageProvider for /mnt/Kids/Disney Megamind/Megamind.m4v
2015-01-08 11:41:02.4784 Debug - ProviderManager: Saving image to /mnt/Kids/Disney Megamind/poster.jpg
2015-01-08 11:41:02.5324 Debug - ProviderManager: Saving /mnt/Kids/Disney Megamind/Megamind.m4v to Media Browser Xml.
2015-01-08 11:41:02.5846 Debug - ProviderManager: Saving /mnt/Kids/Disney Megamind/Megamind.m4v to Nfo.
2015-01-08 11:41:02.6074 Info - App: HttpClientManager POST: http://api.opensubtitles.org/xml-rpc
2015-01-08 11:41:02.6114 Debug - App: Saving /mnt/Kids/Disney Megamind/Megamind.m4v to database.
2015-01-08 11:41:03.3782 Info - SubtitleManager: Saving subtitles to /mnt/Kids/James and the Giant Peach/James and the Giant Peach.eng.sub
2015-01-08 11:41:03.4329 Debug - App: Running MovieDbImageProvider for /mnt/Kids/James and the Giant Peach/James and the Giant Peach.m4v
2015-01-08 11:41:03.4382 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/fDfgO1jkPAIX9ZbXka9XcOfDWl3.jpg
2015-01-08 11:41:05.7104 Debug - ProviderManager: Saving image to /mnt/Kids/James and the Giant Peach/poster.jpg
2015-01-08 11:41:05.8184 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/xxxls5ndPmeFh5rnNjY2zm0kSlK.jpg
2015-01-08 11:41:06.3703 Debug - ProviderManager: Saving image to /mnt/Kids/James and the Giant Peach/fanart.jpg
2015-01-08 11:41:06.4453 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/4MWKbMmB45QP2c6BA9kIMyGIRtn.jpg
2015-01-08 11:41:06.7353 Debug - ProviderManager: Saving image to /mnt/Kids/James and the Giant Peach/extrafanart/fanart1.jpg
2015-01-08 11:41:06.7791 Debug - ProviderManager: Saving image to /mnt/Kids/James and the Giant Peach/extrathumbs/thumb1.jpg
2015-01-08 11:41:06.8309 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/AwiESoYTQVx97N1PtUQE0vUQdZu.jpg
2015-01-08 11:41:07.0501 Debug - ProviderManager: Saving image to /mnt/Kids/James and the Giant Peach/extrafanart/fanart2.jpg
2015-01-08 11:41:07.0912 Debug - ProviderManager: Saving image to /mnt/Kids/James and the Giant Peach/extrathumbs/thumb2.jpg
2015-01-08 11:41:07.1369 Debug - App: Running FanartMovieImageProvider for /mnt/Kids/James and the Giant Peach/James and the Giant Peach.m4v
2015-01-08 11:41:07.1386 Info - App: HttpClientManager GET: http://webservice.fanart.tv/v3/movies/10539?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4
2015-01-08 11:41:13.6404 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/10539/moviedisc/james-and-the-giant-peach-5256657f460b1.png
2015-01-08 11:41:14.2472 Debug - ProviderManager: Saving image to /mnt/Kids/James and the Giant Peach/disc.png
2015-01-08 11:41:14.3240 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/10539/hdmovielogo/james-and-the-giant-peach-5102fb30a6c5f.png
2015-01-08 11:41:14.7741 Debug - ProviderManager: Saving image to /mnt/Kids/James and the Giant Peach/logo.png
2015-01-08 11:41:14.8134 Debug - ProviderManager: Saving /mnt/Kids/James and the Giant Peach/James and the Giant Peach.m4v to Media Browser Xml.
2015-01-08 11:41:14.8674 Debug - ProviderManager: Saving /mnt/Kids/James and the Giant Peach/James and the Giant Peach.m4v to Nfo.
2015-01-08 11:41:14.9503 Debug - App: Saving /mnt/Kids/James and the Giant Peach/James and the Giant Peach.m4v to database.
2015-01-08 11:41:14.9608 Debug - App: Running MovieXmlProvider for /mnt/Kids/Dunston Checks In/Dunston Checks In.m4v
2015-01-08 11:41:14.9630 Debug - App: MovieXmlProvider returned no metadata for /mnt/Kids/Dunston Checks In/Dunston Checks In.m4v
2015-01-08 11:41:14.9630 Debug - App: Running MovieNfoProvider for /mnt/Kids/Dunston Checks In/Dunston Checks In.m4v
2015-01-08 11:41:14.9630 Debug - App: MovieNfoProvider returned no metadata for /mnt/Kids/Dunston Checks In/Dunston Checks In.m4v
2015-01-08 11:41:14.9630 Debug - App: Running MovieDbProvider for /mnt/Kids/Dunston Checks In/Dunston Checks In.m4v
2015-01-08 11:41:14.9641 Info - App: MovieDbProvider: Finding id for item: Dunston Checks In
2015-01-08 11:41:14.9651 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Dunston+Checks+In&language=en
2015-01-08 11:41:15.0096 Debug - App: Running MovieXmlProvider for /mnt/Kids/Disney Pirates Of The Caribbean 2 Dead Mans Chest/Pirates of the Caribbean: Dead Mans Chest.m4v
2015-01-08 11:41:15.0125 Debug - App: MovieXmlProvider returned no metadata for /mnt/Kids/Disney Pirates Of The Caribbean 2 Dead Mans Chest/Pirates of the Caribbean: Dead Mans Chest.m4v
2015-01-08 11:41:15.0125 Debug - App: Running MovieNfoProvider for /mnt/Kids/Disney Pirates Of The Caribbean 2 Dead Mans Chest/Pirates of the Caribbean: Dead Mans Chest.m4v
2015-01-08 11:41:15.0128 Debug - App: MovieNfoProvider returned no metadata for /mnt/Kids/Disney Pirates Of The Caribbean 2 Dead Mans Chest/Pirates of the Caribbean: Dead Mans Chest.m4v
2015-01-08 11:41:15.0128 Debug - App: Running MovieDbProvider for /mnt/Kids/Disney Pirates Of The Caribbean 2 Dead Mans Chest/Pirates of the Caribbean: Dead Mans Chest.m4v
2015-01-08 11:41:15.0147 Info - App: MovieDbProvider: Finding id for item: Disney Pirates Of The Caribbean 2 Dead Mans Chest
2015-01-08 11:41:15.5500 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Disney+Pirates+Of+The+Caribbean+2+Dead+Mans+Chest&language=en
2015-01-08 11:41:15.6829 Debug - App: MovieDbProvider returned no metadata for /mnt/Kids/Disney Pirates Of The Caribbean 2 Dead Mans Chest/Pirates of the Caribbean: Dead Mans Chest.m4v
2015-01-08 11:41:15.6829 Debug - App: Running OmdbItemProvider for /mnt/Kids/Disney Pirates Of The Caribbean 2 Dead Mans Chest/Pirates of the Caribbean: Dead Mans Chest.m4v
2015-01-08 11:41:15.6853 Info - App: MovieDbProvider: Finding id for item: Disney Pirates Of The Caribbean 2 Dead Mans Chest
2015-01-08 11:41:15.6865 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Disney+Pirates+Of+The+Caribbean+2+Dead+Mans+Chest&language=en
2015-01-08 11:41:15.8230 Debug - App: OmdbItemProvider returned no metadata for /mnt/Kids/Disney Pirates Of The Caribbean 2 Dead Mans Chest/Pirates of the Caribbean: Dead Mans Chest.m4v
2015-01-08 11:41:15.8230 Debug - App: Running FFProbeProvider for /mnt/Kids/Disney Pirates Of The Caribbean 2 Dead Mans Chest/Pirates of the Caribbean: Dead Mans Chest.m4v
2015-01-08 11:41:15.8238 Debug - MediaEncoder: /var/lib/mediabrowser/ffmpeg/20140716/ffprobe -i file:"/mnt/Kids/Disney Pirates Of The Caribbean 2 Dead Mans Chest/Pirates of the Caribbean: Dead Mans Chest.m4v" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format
2015-01-08 11:41:15.8809 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/movie/17414?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null
2015-01-08 11:41:16.2522 Debug - App: Running MovieDbImageProvider for /mnt/Kids/Disney Pirates Of The Caribbean 2 Dead Mans Chest/Pirates of the Caribbean: Dead Mans Chest.m4v
2015-01-08 11:41:16.2532 Debug - App: Running FanartMovieImageProvider for /mnt/Kids/Disney Pirates Of The Caribbean 2 Dead Mans Chest/Pirates of the Caribbean: Dead Mans Chest.m4v
2015-01-08 11:41:16.2542 Debug - App: Running OmdbImageProvider for /mnt/Kids/Disney Pirates Of The Caribbean 2 Dead Mans Chest/Pirates of the Caribbean: Dead Mans Chest.m4v
2015-01-08 11:41:16.2550 Debug - App: Running VideoImageProvider for /mnt/Kids/Disney Pirates Of The Caribbean 2 Dead Mans Chest/Pirates of the Caribbean: Dead Mans Chest.m4v
2015-01-08 11:41:16.8298 Debug - ProviderManager: Saving image to /mnt/Kids/Disney Pirates Of The Caribbean 2 Dead Mans Chest/poster.jpg
2015-01-08 11:41:16.8298 Debug - App: Running OmdbItemProvider for /mnt/Kids/Dunston Checks In/Dunston Checks In.m4v
2015-01-08 11:41:16.8353 Info - App: HttpClientManager GET: http://www.omdbapi.com/?i=tt0116151&tomatoes=true
2015-01-08 11:41:16.9054 Debug - App: Running FFProbeProvider for /mnt/Kids/Dunston Checks In/Dunston Checks In.m4v
2015-01-08 11:41:16.9061 Debug - MediaEncoder: /var/lib/mediabrowser/ffmpeg/20140716/ffprobe -i file:"/mnt/Kids/Dunston Checks In/Dunston Checks In.m4v" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format
2015-01-08 11:41:16.9755 Debug - ProviderManager: Saving /mnt/Kids/Disney Pirates Of The Caribbean 2 Dead Mans Chest/Pirates of the Caribbean: Dead Mans Chest.m4v to Media Browser Xml.
2015-01-08 11:41:16.9976 Debug - ProviderManager: Saving /mnt/Kids/Disney Pirates Of The Caribbean 2 Dead Mans Chest/Pirates of the Caribbean: Dead Mans Chest.m4v to Nfo.
2015-01-08 11:41:17.0458 Debug - App: Saving /mnt/Kids/Disney Pirates Of The Caribbean 2 Dead Mans Chest/Pirates of the Caribbean: Dead Mans Chest.m4v to database.
2015-01-08 11:41:17.2683 Debug - App: Running MovieDbImageProvider for /mnt/Kids/Dunston Checks In/Dunston Checks In.m4v
2015-01-08 11:41:17.2735 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/lXSWbUA3T2o792SYdbfFKFTcSC1.jpg
2015-01-08 11:41:17.9922 Debug - ProviderManager: Saving image to /mnt/Kids/Dunston Checks In/poster.jpg
2015-01-08 11:41:18.0621 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/p57ZySRzY1s9jiHhWLIFVS2BFs0.jpg
2015-01-08 11:41:18.5305 Debug - ProviderManager: Saving image to /mnt/Kids/Dunston Checks In/fanart.jpg
2015-01-08 11:41:18.5879 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/dpiciyrHsu9BchmC4x8PoCfubre.jpg
2015-01-08 11:41:19.2242 Debug - ProviderManager: Saving image to /mnt/Kids/Dunston Checks In/extrafanart/fanart1.jpg
2015-01-08 11:41:19.2934 Debug - ProviderManager: Saving image to /mnt/Kids/Dunston Checks In/extrathumbs/thumb1.jpg
2015-01-08 11:41:19.3430 Debug - App: Running FanartMovieImageProvider for /mnt/Kids/Dunston Checks In/Dunston Checks In.m4v
2015-01-08 11:41:19.3445 Info - App: HttpClientManager GET: http://webservice.fanart.tv/v3/movies/17414?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4
2015-01-08 11:41:19.7349 Error - App: Error getting response from http://webservice.fanart.tv/v3/movies/17414?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4
Version: 3.0.5482.1
Processor count: 2
64-Bit OS: True
The remote server returned an error: (404) Not Found.
System.Net.WebException
 at System.Net.HttpWebRequest.CheckFinalStatus (System.Net.WebAsyncResult result) [0x00000] in <filename unknown>:0
 at System.Net.HttpWebRequest.SetResponseData (System.Net.WebConnectionData data) [0x00000] in <filename unknown>:0
2015-01-08 11:41:19.7367 Debug - ProviderManager: Saving /mnt/Kids/Dunston Checks In/Dunston Checks In.m4v to Media Browser Xml.
2015-01-08 11:41:19.7591 Debug - ProviderManager: Saving /mnt/Kids/Dunston Checks In/Dunston Checks In.m4v to Nfo.
2015-01-08 11:41:19.8091 Debug - App: Saving /mnt/Kids/Dunston Checks In/Dunston Checks In.m4v to database.
2015-01-08 11:41:19.8768 Debug - App: Running MovieXmlProvider for /mnt/Kids/Harriet The Spy/Harriet The Spy.m4v
2015-01-08 11:41:19.8793 Debug - App: MovieXmlProvider returned no metadata for /mnt/Kids/Harriet The Spy/Harriet The Spy.m4v
2015-01-08 11:41:19.8793 Debug - App: Running MovieNfoProvider for /mnt/Kids/Harriet The Spy/Harriet The Spy.m4v
2015-01-08 11:41:19.8793 Debug - App: MovieNfoProvider returned no metadata for /mnt/Kids/Harriet The Spy/Harriet The Spy.m4v
2015-01-08 11:41:19.8797 Debug - App: Running MovieDbProvider for /mnt/Kids/Harriet The Spy/Harriet The Spy.m4v
2015-01-08 11:41:19.8808 Info - App: MovieDbProvider: Finding id for item: Harriet The Spy
2015-01-08 11:41:19.8818 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Harriet+The+Spy&language=en
2015-01-08 11:41:19.8818 Debug - App: Running MovieXmlProvider for /mnt/Kids/Disney Dumbo/Dumbo.m4v
2015-01-08 11:41:19.8850 Debug - App: MovieXmlProvider returned no metadata for /mnt/Kids/Disney Dumbo/Dumbo.m4v
2015-01-08 11:41:19.8850 Debug - App: Running MovieNfoProvider for /mnt/Kids/Disney Dumbo/Dumbo.m4v
2015-01-08 11:41:19.8850 Debug - App: MovieNfoProvider returned no metadata for /mnt/Kids/Disney Dumbo/Dumbo.m4v
2015-01-08 11:41:19.8850 Debug - App: Running MovieDbProvider for /mnt/Kids/Disney Dumbo/Dumbo.m4v
2015-01-08 11:41:19.8863 Info - App: MovieDbProvider: Finding id for item: Disney Dumbo
2015-01-08 11:41:20.0699 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Disney+Dumbo&language=en
2015-01-08 11:41:20.3590 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/movie/38223?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null
2015-01-08 11:41:20.3590 Debug - App: MovieDbProvider returned no metadata for /mnt/Kids/Disney Dumbo/Dumbo.m4v
2015-01-08 11:41:20.3590 Debug - App: Running OmdbItemProvider for /mnt/Kids/Disney Dumbo/Dumbo.m4v
2015-01-08 11:41:20.3604 Info - App: MovieDbProvider: Finding id for item: Disney Dumbo
2015-01-08 11:41:20.5975 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Disney+Dumbo&language=en
2015-01-08 11:41:20.6018 Debug - App: Running OmdbItemProvider for /mnt/Kids/Harriet The Spy/Harriet The Spy.m4v
2015-01-08 11:41:20.6057 Info - App: HttpClientManager GET: http://www.omdbapi.com/?i=tt0116493&tomatoes=true
2015-01-08 11:41:20.6759 Debug - App: Running FFProbeProvider for /mnt/Kids/Harriet The Spy/Harriet The Spy.m4v
2015-01-08 11:41:20.6883 Debug - MediaEncoder: /var/lib/mediabrowser/ffmpeg/20140716/ffprobe -i file:"/mnt/Kids/Harriet The Spy/Harriet The Spy.m4v" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format
2015-01-08 11:41:20.7496 Debug - App: OmdbItemProvider returned no metadata for /mnt/Kids/Disney Dumbo/Dumbo.m4v
2015-01-08 11:41:20.7500 Debug - App: Running FFProbeProvider for /mnt/Kids/Disney Dumbo/Dumbo.m4v
2015-01-08 11:41:20.7508 Debug - MediaEncoder: /var/lib/mediabrowser/ffmpeg/20140716/ffprobe -i file:"/mnt/Kids/Disney Dumbo/Dumbo.m4v" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format
2015-01-08 11:41:21.1121 Debug - App: Running MovieDbImageProvider for /mnt/Kids/Harriet The Spy/Harriet The Spy.m4v
2015-01-08 11:41:21.1183 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/gqPl6KdsTo1hwknnxJYlnKa9OtX.jpg
2015-01-08 11:41:21.1496 Debug - App: Running MovieDbImageProvider for /mnt/Kids/Disney Dumbo/Dumbo.m4v
2015-01-08 11:41:21.1505 Debug - App: Running FanartMovieImageProvider for /mnt/Kids/Disney Dumbo/Dumbo.m4v
2015-01-08 11:41:21.1517 Debug - App: Running OmdbImageProvider for /mnt/Kids/Disney Dumbo/Dumbo.m4v
2015-01-08 11:41:21.1517 Debug - App: Running VideoImageProvider for /mnt/Kids/Disney Dumbo/Dumbo.m4v
2015-01-08 11:41:21.3881 Debug - ProviderManager: Saving image to /mnt/Kids/Harriet The Spy/poster.jpg
2015-01-08 11:41:21.4560 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/2wBf5VEnYEBAMSvpshdKBdNRkua.jpg
2015-01-08 11:41:21.9632 Debug - ProviderManager: Saving image to /mnt/Kids/Harriet The Spy/fanart.jpg
2015-01-08 11:41:22.0278 Debug - App: Running FanartMovieImageProvider for /mnt/Kids/Harriet The Spy/Harriet The Spy.m4v
2015-01-08 11:41:22.0293 Info - App: HttpClientManager GET: http://webservice.fanart.tv/v3/movies/38223?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4
2015-01-08 11:41:22.3721 Debug - ProviderManager: Saving image to /mnt/Kids/Disney Dumbo/poster.jpg
2015-01-08 11:41:22.4131 Debug - ProviderManager: Saving /mnt/Kids/Disney Dumbo/Dumbo.m4v to Media Browser Xml.
2015-01-08 11:41:22.4468 Debug - ProviderManager: Saving /mnt/Kids/Disney Dumbo/Dumbo.m4v to Nfo.
2015-01-08 11:41:22.4699 Debug - App: Saving /mnt/Kids/Disney Dumbo/Dumbo.m4v to database.
2015-01-08 11:41:27.5251 Error - App: Error getting response from http://webservice.fanart.tv/v3/movies/38223?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4
Version: 3.0.5482.1
Processor count: 2
64-Bit OS: True
2015-01-08 11:41:27.5272 Debug - ProviderManager: Saving /mnt/Kids/Harriet The Spy/Harriet The Spy.m4v to Media Browser Xml.
2015-01-08 11:41:27.5492 Debug - ProviderManager: Saving /mnt/Kids/Harriet The Spy/Harriet The Spy.m4v to Nfo.
2015-01-08 11:41:27.5776 Debug - App: Saving /mnt/Kids/Harriet The Spy/Harriet The Spy.m4v to database.
2015-01-08 11:41:27.5938 Debug - App: Running MovieXmlProvider for /mnt/Kids/Disney Winnie The Pooh/Winnie The Pooh.m4v
2015-01-08 11:41:27.5962 Debug - App: MovieXmlProvider returned no metadata for /mnt/Kids/Disney Winnie The Pooh/Winnie The Pooh.m4v
2015-01-08 11:41:27.5962 Debug - App: Running MovieNfoProvider for /mnt/Kids/Disney Winnie The Pooh/Winnie The Pooh.m4v
2015-01-08 11:41:27.5962 Debug - App: MovieNfoProvider returned no metadata for /mnt/Kids/Disney Winnie The Pooh/Winnie The Pooh.m4v
2015-01-08 11:41:27.5962 Debug - App: Running MovieDbProvider for /mnt/Kids/Disney Winnie The Pooh/Winnie The Pooh.m4v
2015-01-08 11:41:27.5971 Info - App: MovieDbProvider: Finding id for item: Disney Winnie The Pooh
2015-01-08 11:41:27.5981 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Disney+Winnie+The+Pooh&language=en
2015-01-08 11:41:27.5981 Debug - App: Running MovieXmlProvider for /mnt/Kids/Monster House/Monster House.m4v
2015-01-08 11:41:27.6006 Debug - App: MovieXmlProvider returned no metadata for /mnt/Kids/Monster House/Monster House.m4v
2015-01-08 11:41:27.6008 Debug - App: Running MovieNfoProvider for /mnt/Kids/Monster House/Monster House.m4v
2015-01-08 11:41:27.6008 Debug - App: MovieNfoProvider returned no metadata for /mnt/Kids/Monster House/Monster House.m4v
2015-01-08 11:41:27.6008 Debug - App: Running MovieDbProvider for /mnt/Kids/Monster House/Monster House.m4v
2015-01-08 11:41:27.6008 Info - App: MovieDbProvider: Finding id for item: Monster House
2015-01-08 11:41:28.1604 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Monster+House&language=en
2015-01-08 11:41:28.1621 Debug - App: MovieDbProvider returned no metadata for /mnt/Kids/Disney Winnie The Pooh/Winnie The Pooh.m4v
2015-01-08 11:41:28.1621 Debug - App: Running OmdbItemProvider for /mnt/Kids/Disney Winnie The Pooh/Winnie The Pooh.m4v
2015-01-08 11:41:28.1637 Info - App: MovieDbProvider: Finding id for item: Disney Winnie The Pooh
2015-01-08 11:41:28.2713 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Disney+Winnie+The+Pooh&language=en
2015-01-08 11:41:28.3749 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/movie/9297?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null
2015-01-08 11:41:28.3749 Debug - App: OmdbItemProvider returned no metadata for /mnt/Kids/Disney Winnie The Pooh/Winnie The Pooh.m4v
2015-01-08 11:41:28.3758 Debug - App: Running FFProbeProvider for /mnt/Kids/Disney Winnie The Pooh/Winnie The Pooh.m4v
2015-01-08 11:41:28.3779 Debug - MediaEncoder: /var/lib/mediabrowser/ffmpeg/20140716/ffprobe -i file:"/mnt/Kids/Disney Winnie The Pooh/Winnie The Pooh.m4v" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format
2015-01-08 11:41:28.5364 Debug - App: Running OmdbItemProvider for /mnt/Kids/Monster House/Monster House.m4v
2015-01-08 11:41:28.5429 Info - App: HttpClientManager GET: http://www.omdbapi.com/?i=tt0385880&tomatoes=true
2015-01-08 11:41:28.6945 Debug - App: Running MovieDbImageProvider for /mnt/Kids/Disney Winnie The Pooh/Winnie The Pooh.m4v
2015-01-08 11:41:28.7003 Debug - App: Running FanartMovieImageProvider for /mnt/Kids/Disney Winnie The Pooh/Winnie The Pooh.m4v
2015-01-08 11:41:28.7017 Debug - App: Running OmdbImageProvider for /mnt/Kids/Disney Winnie The Pooh/Winnie The Pooh.m4v
2015-01-08 11:41:28.7017 Debug - App: Running VideoImageProvider for /mnt/Kids/Disney Winnie The Pooh/Winnie The Pooh.m4v
2015-01-08 11:41:29.4535 Debug - ProviderManager: Saving image to /mnt/Kids/Disney Winnie The Pooh/poster.jpg
2015-01-08 11:41:29.4944 Debug - ProviderManager: Saving /mnt/Kids/Disney Winnie The Pooh/Winnie The Pooh.m4v to Media Browser Xml.
2015-01-08 11:41:29.5262 Debug - ProviderManager: Saving /mnt/Kids/Disney Winnie The Pooh/Winnie The Pooh.m4v to Nfo.
2015-01-08 11:41:29.5515 Debug - App: Saving /mnt/Kids/Disney Winnie The Pooh/Winnie The Pooh.m4v to database.
2015-01-08 11:41:31.6115 Debug - App: Running FFProbeProvider for /mnt/Kids/Monster House/Monster House.m4v
2015-01-08 11:41:31.6124 Debug - MediaEncoder: /var/lib/mediabrowser/ffmpeg/20140716/ffprobe -i file:"/mnt/Kids/Monster House/Monster House.m4v" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format
2015-01-08 11:41:32.4017 Debug - App: Running MovieDbImageProvider for /mnt/Kids/Monster House/Monster House.m4v
2015-01-08 11:41:32.4076 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/m0gpGljVAKAHM36BLX0RR4cxrNl.jpg
2015-01-08 11:41:33.1584 Debug - ProviderManager: Saving image to /mnt/Kids/Monster House/poster.jpg
2015-01-08 11:41:33.2044 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/xCPq0OXDs7LyFTzOCxanjkyr36l.jpg
2015-01-08 11:41:33.8343 Debug - ProviderManager: Saving image to /mnt/Kids/Monster House/fanart.jpg
2015-01-08 11:41:33.9033 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/rNIkngdO5WRu4HPJcHFVhIdyAnn.jpg
2015-01-08 11:41:35.0392 Debug - ProviderManager: Saving image to /mnt/Kids/Monster House/extrafanart/fanart1.jpg
2015-01-08 11:41:35.1325 Debug - ProviderManager: Saving image to /mnt/Kids/Monster House/extrathumbs/thumb1.jpg
2015-01-08 11:41:35.1912 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/aMXRu2EUHiNzWkEgwTu8PYQXhf5.jpg
2015-01-08 11:41:35.9465 Debug - ProviderManager: Saving image to /mnt/Kids/Monster House/extrafanart/fanart2.jpg
2015-01-08 11:41:36.0190 Debug - ProviderManager: Saving image to /mnt/Kids/Monster House/extrathumbs/thumb2.jpg
2015-01-08 11:41:36.1034 Debug - App: Running FanartMovieImageProvider for /mnt/Kids/Monster House/Monster House.m4v
2015-01-08 11:41:36.1050 Info - App: HttpClientManager GET: http://webservice.fanart.tv/v3/movies/9297?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4
2015-01-08 11:41:44.7334 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/9297/hdmovieclearart/monster-house-5299c1f3b3256.png
2015-01-08 11:41:45.6184 Debug - ProviderManager: Saving image to /mnt/Kids/Monster House/clearart.png
2015-01-08 11:41:45.6754 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/9297/moviebanner/monster-house-51a44c2338ab8.jpg
2015-01-08 11:41:46.0346 Debug - ProviderManager: Saving image to /mnt/Kids/Monster House/banner.jpg
2015-01-08 11:41:46.1010 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/9297/moviedisc/monster-house-5154d9c3eebb3.png
2015-01-08 11:41:47.0034 Debug - ProviderManager: Saving image to /mnt/Kids/Monster House/disc.png
2015-01-08 11:41:47.0756 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/9297/movielogo/monster-house-4fae8e2220857.png
2015-01-08 11:41:47.4248 Debug - ProviderManager: Saving image to /mnt/Kids/Monster House/logo.png
2015-01-08 11:41:47.4545 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/9297/moviethumb/monster-house-5299c223ce987.jpg
2015-01-08 11:41:48.1731 Debug - ProviderManager: Saving image to /mnt/Kids/Monster House/landscape.jpg
2015-01-08 11:41:48.2253 Debug - ProviderManager: Saving /mnt/Kids/Monster House/Monster House.m4v to Media Browser Xml.
2015-01-08 11:41:48.2666 Debug - ProviderManager: Saving /mnt/Kids/Monster House/Monster House.m4v to Nfo.
2015-01-08 11:41:48.3217 Debug - App: Saving /mnt/Kids/Monster House/Monster House.m4v to database.
2015-01-08 11:41:48.3687 Debug - App: Running MovieXmlProvider for /mnt/Kids/The Croods/The Croods.m4v
2015-01-08 11:41:48.3714 Debug - App: Running MovieXmlProvider for /mnt/Kids/Space Camp/Space Camp.m4v
2015-01-08 11:41:48.3776 Debug - App: MovieXmlProvider returned no metadata for /mnt/Kids/The Croods/The Croods.m4v
2015-01-08 11:41:48.3779 Debug - App: Running MovieNfoProvider for /mnt/Kids/The Croods/The Croods.m4v
2015-01-08 11:41:48.3779 Debug - App: MovieNfoProvider returned no metadata for /mnt/Kids/The Croods/The Croods.m4v
2015-01-08 11:41:48.3779 Debug - App: Running MovieDbProvider for /mnt/Kids/The Croods/The Croods.m4v
2015-01-08 11:41:48.3797 Info - App: MovieDbProvider: Finding id for item: The Croods
2015-01-08 11:41:48.3814 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=The+Croods&language=en
2015-01-08 11:41:48.3836 Debug - App: MovieXmlProvider returned no metadata for /mnt/Kids/Space Camp/Space Camp.m4v
2015-01-08 11:41:48.3836 Debug - App: Running MovieNfoProvider for /mnt/Kids/Space Camp/Space Camp.m4v
2015-01-08 11:41:48.3838 Debug - App: MovieNfoProvider returned no metadata for /mnt/Kids/Space Camp/Space Camp.m4v
2015-01-08 11:41:48.3838 Debug - App: Running MovieDbProvider for /mnt/Kids/Space Camp/Space Camp.m4v
2015-01-08 11:41:48.3848 Info - App: MovieDbProvider: Finding id for item: Space Camp
2015-01-08 11:41:48.5533 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Space+Camp&language=en
2015-01-08 11:41:48.7046 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/movie/49519?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null
2015-01-08 11:41:48.9104 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/movie/276166?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null
2015-01-08 11:41:48.9193 Debug - App: Running OmdbItemProvider for /mnt/Kids/The Croods/The Croods.m4v
2015-01-08 11:41:48.9269 Info - App: HttpClientManager GET: http://www.omdbapi.com/?i=tt0481499&tomatoes=true
2015-01-08 11:41:49.0546 Debug - App: Running FFProbeProvider for /mnt/Kids/The Croods/The Croods.m4v
2015-01-08 11:41:49.0552 Debug - MediaEncoder: /var/lib/mediabrowser/ffmpeg/20140716/ffprobe -i file:"/mnt/Kids/The Croods/The Croods.m4v" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format
2015-01-08 11:41:49.1318 Debug - App: Running OmdbItemProvider for /mnt/Kids/Space Camp/Space Camp.m4v
2015-01-08 11:41:49.1366 Info - App: HttpClientManager GET: http://www.omdbapi.com/?i=tt0283855&tomatoes=true
2015-01-08 11:41:49.4171 Debug - App: Running MovieDbImageProvider for /mnt/Kids/The Croods/The Croods.m4v
2015-01-08 11:41:49.4272 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/bued85CL5MRd02dkyt7HGbkKAuy.jpg
2015-01-08 11:41:50.2635 Debug - App: Running FFProbeProvider for /mnt/Kids/Space Camp/Space Camp.m4v
2015-01-08 11:41:50.2642 Debug - MediaEncoder: /var/lib/mediabrowser/ffmpeg/20140716/ffprobe -i file:"/mnt/Kids/Space Camp/Space Camp.m4v" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format
2015-01-08 11:41:50.7544 Debug - App: Running MovieDbImageProvider for /mnt/Kids/Space Camp/Space Camp.m4v
2015-01-08 11:41:52.6053 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/5fTfqhnDUilpkgrj61ISz9nJaf8.jpg
2015-01-08 11:41:52.6063 Debug - ProviderManager: Saving image to /mnt/Kids/The Croods/poster.jpg
2015-01-08 11:41:53.9485 Debug - ProviderManager: Saving image to /mnt/Kids/Space Camp/poster.jpg
2015-01-08 11:41:53.9568 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/kYY4CKjjknT1GY45ZueZs556Mnl.jpg
2015-01-08 11:41:54.0209 Debug - App: Running FanartMovieImageProvider for /mnt/Kids/Space Camp/Space Camp.m4v
2015-01-08 11:41:54.0227 Info - App: HttpClientManager GET: http://webservice.fanart.tv/v3/movies/276166?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4
2015-01-08 11:41:55.8657 Debug - ProviderManager: Saving image to /mnt/Kids/The Croods/fanart.jpg
2015-01-08 11:41:56.5655 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/vg2hf8eAZhULxtQRS87CbrH2WMQ.jpg
2015-01-08 11:41:57.2858 Debug - ProviderManager: Saving image to /mnt/Kids/The Croods/extrafanart/fanart1.jpg
2015-01-08 11:41:57.3355 Debug - ProviderManager: Saving image to /mnt/Kids/The Croods/extrathumbs/thumb1.jpg
2015-01-08 11:41:57.3949 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/eJGreIqnFMVDdDtIYSABcHaQCe.jpg
2015-01-08 11:41:58.0210 Debug - ProviderManager: Saving image to /mnt/Kids/The Croods/extrafanart/fanart2.jpg
2015-01-08 11:41:58.0696 Debug - ProviderManager: Saving image to /mnt/Kids/The Croods/extrathumbs/thumb2.jpg
2015-01-08 11:41:58.1191 Debug - App: Running FanartMovieImageProvider for /mnt/Kids/The Croods/The Croods.m4v
2015-01-08 11:41:58.1213 Info - App: HttpClientManager GET: http://webservice.fanart.tv/v3/movies/49519?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4
2015-01-08 11:42:00.2531 Error - App: Error getting response from http://webservice.fanart.tv/v3/movies/276166?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4
*** Error Report ***
Version: 3.0.5482.1
Command line: /opt/mediabrowser/MediaBrowser.Server.Mono.exe -programdata /var/lib/mediabrowser
Operating system: Unix 3.13.0.43
Processor count: 2
64-Bit OS: True
64-Bit Process: True
Program data path: /var/lib/mediabrowser
Mono: 3.2.8 (Debian 3.2.8+dfsg-4ubuntu1)
Application Path: /opt/mediabrowser/MediaBrowser.Server.Mono.exe
2015-01-08 11:42:00.2556 Debug - ProviderManager: Saving /mnt/Kids/Space Camp/Space Camp.m4v to Media Browser Xml.
2015-01-08 11:42:00.2869 Debug - ProviderManager: Saving /mnt/Kids/Space Camp/Space Camp.m4v to Nfo.
2015-01-08 11:42:00.3258 Debug - App: Saving /mnt/Kids/Space Camp/Space Camp.m4v to database.
2015-01-08 11:42:03.0918 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/49519/hdmovieclearart/the-croods-51d7da38a1288.png
2015-01-08 11:42:03.6284 Debug - ProviderManager: Saving image to /mnt/Kids/The Croods/clearart.png
2015-01-08 11:42:03.6779 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/49519/moviebanner/the-croods-51d7da4442263.jpg
2015-01-08 11:42:04.0832 Debug - ProviderManager: Saving image to /mnt/Kids/The Croods/banner.jpg
2015-01-08 11:42:04.1421 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/49519/moviedisc/the-croods-51f4be063b955.png
2015-01-08 11:42:05.0385 Debug - ProviderManager: Saving image to /mnt/Kids/The Croods/disc.png
2015-01-08 11:42:05.1107 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/49519/hdmovielogo/the-croods-52456dd5a2081.png
2015-01-08 11:42:05.6422 Debug - ProviderManager: Saving image to /mnt/Kids/The Croods/logo.png
2015-01-08 11:42:05.6937 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/49519/moviethumb/the-croods-51d7da5bd4e26.jpg
2015-01-08 11:42:06.2520 Debug - ProviderManager: Saving image to /mnt/Kids/The Croods/landscape.jpg
2015-01-08 11:42:06.3725 Debug - ProviderManager: Saving /mnt/Kids/The Croods/The Croods.m4v to Media Browser Xml.
2015-01-08 11:42:06.4225 Debug - ProviderManager: Saving /mnt/Kids/The Croods/The Croods.m4v to Nfo.
2015-01-08 11:42:06.4641 Debug - App: Saving /mnt/Kids/The Croods/The Croods.m4v to database.
2015-01-08 11:42:06.4748 Debug - App: Running MovieXmlProvider for /mnt/Kids/Enchanted/Enchanted.m4v
2015-01-08 11:42:06.4772 Debug - App: MovieXmlProvider returned no metadata for /mnt/Kids/Enchanted/Enchanted.m4v
2015-01-08 11:42:06.4772 Debug - App: Running MovieNfoProvider for /mnt/Kids/Enchanted/Enchanted.m4v
2015-01-08 11:42:06.4772 Debug - App: MovieNfoProvider returned no metadata for /mnt/Kids/Enchanted/Enchanted.m4v
2015-01-08 11:42:06.4772 Debug - App: Running MovieXmlProvider for /mnt/Kids/Disney Mary Poppins/Mary Poppins.m4v
2015-01-08 11:42:06.4772 Debug - App: Running MovieDbProvider for /mnt/Kids/Enchanted/Enchanted.m4v
2015-01-08 11:42:06.4782 Info - App: MovieDbProvider: Finding id for item: Enchanted
2015-01-08 11:42:06.4794 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Enchanted&language=en
2015-01-08 11:42:06.4816 Debug - App: MovieXmlProvider returned no metadata for /mnt/Kids/Disney Mary Poppins/Mary Poppins.m4v
2015-01-08 11:42:06.4818 Debug - App: Running MovieNfoProvider for /mnt/Kids/Disney Mary Poppins/Mary Poppins.m4v
2015-01-08 11:42:06.4818 Debug - App: MovieNfoProvider returned no metadata for /mnt/Kids/Disney Mary Poppins/Mary Poppins.m4v
2015-01-08 11:42:06.4818 Debug - App: Running MovieDbProvider for /mnt/Kids/Disney Mary Poppins/Mary Poppins.m4v
2015-01-08 11:42:06.4832 Info - App: MovieDbProvider: Finding id for item: Disney Mary Poppins
2015-01-08 11:42:06.7672 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Disney+Mary+Poppins&language=en
2015-01-08 11:42:06.9087 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/movie/4523?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null
2015-01-08 11:42:07.0111 Info - App: HttpClientManager GET: http://api.themoviedb.org/3/movie/140823?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null
2015-01-08 11:42:07.0188 Debug - App: Running OmdbItemProvider for /mnt/Kids/Enchanted/Enchanted.m4v
2015-01-08 11:42:07.0234 Info - App: HttpClientManager GET: http://www.omdbapi.com/?i=tt0461770&tomatoes=true
2015-01-08 11:42:07.0880 Debug - App: Running FFProbeProvider for /mnt/Kids/Enchanted/Enchanted.m4v
2015-01-08 11:42:07.0880 Debug - MediaEncoder: /var/lib/mediabrowser/ffmpeg/20140716/ffprobe -i file:"/mnt/Kids/Enchanted/Enchanted.m4v" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format
2015-01-08 11:42:07.2731 Info - App: HttpClientManager POST: http://api.opensubtitles.org/xml-rpc
2015-01-08 11:42:07.3218 Debug - App: Running OmdbItemProvider for /mnt/Kids/Disney Mary Poppins/Mary Poppins.m4v
2015-01-08 11:42:07.3283 Info - App: HttpClientManager GET: http://www.omdbapi.com/?i=tt2140373&tomatoes=true
2015-01-08 11:42:07.3627 Debug - App: Running FFProbeProvider for /mnt/Kids/Disney Mary Poppins/Mary Poppins.m4v
2015-01-08 11:42:07.3753 Debug - MediaEncoder: /var/lib/mediabrowser/ffmpeg/20140716/ffprobe -i file:"/mnt/Kids/Disney Mary Poppins/Mary Poppins.m4v" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format
2015-01-08 11:42:07.6869 Debug - App: Running MovieDbImageProvider for /mnt/Kids/Disney Mary Poppins/Mary Poppins.m4v
2015-01-08 11:42:07.7529 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/mvs3reS18RP6IhjLwwLeVtkoeg0.jpg
2015-01-08 11:42:07.9512 Info - App: HttpClientManager POST: http://api.opensubtitles.org/xml-rpc
2015-01-08 11:42:08.9384 Debug - ProviderManager: Saving image to /mnt/Kids/Disney Mary Poppins/poster.jpg
2015-01-08 11:42:09.0163 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/fJQ5kjLx4UdK05MC323Vlzwr6S8.jpg
2015-01-08 11:42:09.5834 Info - App: HttpClientManager POST: http://api.opensubtitles.org/xml-rpc
2015-01-08 11:42:09.7044 Debug - ProviderManager: Saving image to /mnt/Kids/Disney Mary Poppins/fanart.jpg
2015-01-08 11:42:09.7882 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/4KlGYjUSwMKakNa6rWFMEsj1RyC.jpg
2015-01-08 11:42:10.2171 Info - SubtitleManager: Saving subtitles to /mnt/Kids/Enchanted/Enchanted.eng.srt
2015-01-08 11:42:10.2554 Debug - App: Running MovieDbImageProvider for /mnt/Kids/Enchanted/Enchanted.m4v
2015-01-08 11:42:11.1190 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/syHRHMysV3B7DFOf88McrJl7yim.jpg
2015-01-08 11:42:11.1190 Debug - ProviderManager: Saving image to /mnt/Kids/Disney Mary Poppins/extrafanart/fanart1.jpg
2015-01-08 11:42:11.2198 Debug - ProviderManager: Saving image to /mnt/Kids/Disney Mary Poppins/extrathumbs/thumb1.jpg
2015-01-08 11:42:11.6290 Debug - ProviderManager: Saving image to /mnt/Kids/Enchanted/poster.jpg
2015-01-08 11:42:11.6290 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/pyhvUf8QQhhoWBnoZL1ddtThh1o.jpg
2015-01-08 11:42:12.0850 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/9l5Nzo1qbEslfCu2NYWimpZ1Vkc.jpg
2015-01-08 11:42:12.0850 Debug - ProviderManager: Saving image to /mnt/Kids/Disney Mary Poppins/extrafanart/fanart2.jpg
2015-01-08 11:42:12.1219 Debug - ProviderManager: Saving image to /mnt/Kids/Disney Mary Poppins/extrathumbs/thumb2.jpg
2015-01-08 11:42:12.2109 Debug - App: Running FanartMovieImageProvider for /mnt/Kids/Disney Mary Poppins/Mary Poppins.m4v
2015-01-08 11:42:12.2222 Info - App: HttpClientManager GET: http://webservice.fanart.tv/v3/movies/140823?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4
2015-01-08 11:42:12.4318 Debug - ProviderManager: Saving image to /mnt/Kids/Enchanted/fanart.jpg
2015-01-08 11:42:12.4792 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/owQ42RJbU8CR8eghmksxoDHsSzf.jpg
2015-01-08 11:42:12.7519 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/140823/hdmovieclearart/saving-mr-banks-5284d78a6d679.png
2015-01-08 11:42:12.8732 Debug - ProviderManager: Saving image to /mnt/Kids/Enchanted/extrafanart/fanart1.jpg
2015-01-08 11:42:12.9077 Debug - ProviderManager: Saving image to /mnt/Kids/Enchanted/extrathumbs/thumb1.jpg
2015-01-08 11:42:12.9391 Info - App: HttpClientManager GET: http://image.tmdb.org/t/p/original/7gU2Q69QScJiwKteXUCLfXJjnU.jpg
2015-01-08 11:42:13.2575 Debug - ProviderManager: Saving image to /mnt/Kids/Disney Mary Poppins/clearart.png
2015-01-08 11:42:13.3051 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/140823/moviebanner/saving-mr-banks-53068f7a7dda8.jpg
2015-01-08 11:42:13.6194 Debug - ProviderManager: Saving image to /mnt/Kids/Enchanted/extrafanart/fanart2.jpg
2015-01-08 11:42:13.6644 Debug - ProviderManager: Saving image to /mnt/Kids/Disney Mary Poppins/banner.jpg
2015-01-08 11:42:13.6710 Debug - ProviderManager: Saving image to /mnt/Kids/Enchanted/extrathumbs/thumb2.jpg
2015-01-08 11:42:13.6970 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/140823/moviedisc/saving-mr-banks-5314ee562d37d.png
2015-01-08 11:42:13.7469 Debug - App: Running FanartMovieImageProvider for /mnt/Kids/Enchanted/Enchanted.m4v
2015-01-08 11:42:13.7477 Info - App: HttpClientManager GET: http://webservice.fanart.tv/v3/movies/4523?api_key=5c6b04c68e904cfed1e6cbc9a9e683d4
2015-01-08 11:42:14.6856 Debug - ProviderManager: Saving image to /mnt/Kids/Disney Mary Poppins/disc.png
2015-01-08 11:42:14.7598 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/140823/hdmovielogo/saving-mr-banks-5283cf222c57e.png
2015-01-08 11:42:16.4679 Debug - ProviderManager: Saving image to /mnt/Kids/Disney Mary Poppins/logo.png
2015-01-08 11:42:16.5187 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/140823/moviethumb/saving-mr-banks-535fc2ca5df28.jpg
2015-01-08 11:42:17.5472 Debug - ProviderManager: Saving image to /mnt/Kids/Disney Mary Poppins/landscape.jpg
2015-01-08 11:42:17.6129 Debug - ProviderManager: Saving /mnt/Kids/Disney Mary Poppins/Mary Poppins.m4v to Media Browser Xml.
2015-01-08 11:42:17.6354 Debug - ProviderManager: Saving /mnt/Kids/Disney Mary Poppins/Mary Poppins.m4v to Nfo.
2015-01-08 11:42:17.7248 Debug - App: Saving /mnt/Kids/Disney Mary Poppins/Mary Poppins.m4v to database.
2015-01-08 11:42:21.5726 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/4523/hdmovieclearart/enchanted-52a70c55e3cee.png
2015-01-08 11:42:22.0732 Debug - ProviderManager: Saving image to /mnt/Kids/Enchanted/clearart.png
2015-01-08 11:42:22.1490 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/4523/moviebanner/enchanted-540a3b7f16551.jpg
2015-01-08 11:42:22.5245 Debug - ProviderManager: Saving image to /mnt/Kids/Enchanted/banner.jpg
2015-01-08 11:42:22.5562 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/4523/moviedisc/enchanted-529724e473f28.png
2015-01-08 11:42:23.0049 Error - Main: UnhandledException
Version: 3.0.5482.1
Processor count: 2
64-Bit OS: True
The underlying Task is already in one of the three final states: RanToCompletion, Faulted, or Canceled.
System.InvalidOperationException
 at System.Threading.Tasks.TaskCompletionSource`1[System.Int32].SetException (IEnumerable`1 exceptions) [0x00000] in <filename unknown>:0
 at System.Threading.Tasks.TaskCompletionSource`1[System.Int32].SetException (System.Exception exception) [0x00000] in <filename unknown>:0
 at System.Threading.Tasks.TaskFactory`1[System.Int32].InnerInvoke (System.Threading.Tasks.TaskCompletionSource`1 tcs, System.Func`2 endMethod, IAsyncResult l) [0x00000] in <filename unknown>:0
 at System.Threading.Tasks.TaskFactory`1+<FromAsyncBeginEnd>c__AnonStorey5`3[System.Int32,System.Byte[],System.Int32,System.Int32].<>m__0 (IAsyncResult l) [0x00000] in <filename unknown>:0
 at System.Net.WebAsyncResult.CB (System.Object unused) [0x00000] in <filename unknown>:0
2015-01-08 11:42:23.1865 Debug - ProviderManager: Saving image to /mnt/Kids/Enchanted/disc.png
2015-01-08 11:42:23.2714 Info - App: HttpClientManager GET: http://assets.fanart.tv/fanart/movies/4523/hdmovielogo/enchanted-504301272fbd5.png
If you want the whole entire thing let me know and I'll see if I can toss it up somewhere to take a look at it.
And another death
2015-01-08 15:47:10.8232 Error - HttpAsyncTaskHandler: Error occured while Processing Request: Write failure *** Error Report *** Version: 3.0.5482.1 Command line: /opt/mediabrowser/MediaBrowser.Server.Mono.exe -programdata /var/lib/mediabrowser Operating system: Unix 3.13.0.43 Processor count: 2 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/mediabrowser Mono: 3.2.8 (Debian 3.2.8+dfsg-4ubuntu1) Application Path: /opt/mediabrowser/MediaBrowser.Server.Mono.exe Write failure System.IO.IOException at System.Net.Sockets.NetworkStream.Write (System.Byte[] buffer, Int32 offset, Int32 size) [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.ResponseStream.InternalWrite (System.Byte[] buffer, Int32 offset, Int32 count) [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.ResponseStream.Write (System.Byte[] buffer, Int32 offset, Int32 count) [0x00000] in <filename unknown>:0 at ServiceStack.Formats.HtmlFormat.SerializeToStream (IRequest request, System.Object response, IResponse httpRes) [0x00000] in <filename unknown>:0 at ServiceStack.HttpResponseExtensionsInternal.WriteErrorToResponse (IResponse httpRes, IRequest httpReq, System.String contentType, System.String operationName, System.String errorMessage, System.Exception ex, Int32 statusCode) [0x00000] in <filename unknown>:0 at ServiceStack.ServiceStackHost.OnUncaughtException (IRequest httpReq, IResponse httpRes, System.String operationName, System.Exception ex) [0x00000] in <filename unknown>:0 at ServiceStack.HostContext.RaiseUncaughtException (IRequest httpReq, IResponse httpRes, System.String operationName, System.Exception ex) [0x00000] in <filename unknown>:0 at ServiceStack.HttpResponseExtensionsInternal.WriteToResponse (IResponse response, System.Object result, ServiceStack.Web.ResponseSerializerDelegate defaultAction, IRequest request, System.Byte[] bodyPrefix, System.Byte[] bodySuffix) [0x00000] in <filename unknown>:0 at ServiceStack.HttpResponseExtensionsInternal.WriteToResponse (IResponse httpRes, IRequest httpReq, System.Object result, System.Byte[] bodyPrefix, System.Byte[] bodySuffix) [0x00000] in <filename unknown>:0 at ServiceStack.HttpResponseExtensionsInternal.WriteToResponse (IResponse httpRes, IRequest httpReq, System.Object result) [0x00000] in <filename unknown>:0 at ServiceStack.Host.RestHandler+<>c__DisplayClass5.<ProcessRequestAsync>b__0 (System.Object response) [0x00000] in <filename unknown>:0 at ServiceStack.Host.Handlers.ServiceStackHandlerBase.HandleResponse (System.Object response, System.Func`2 callback, System.Func`2 errorCallback) [0x00000] in <filename unknown>:0 InnerException: System.Net.Sockets.SocketException The socket has been shut down at System.Net.Sockets.Socket.Send (System.Byte[] buf, Int32 offset, Int32 size, SocketFlags flags) [0x00000] in <filename unknown>:0 at System.Net.Sockets.NetworkStream.Write (System.Byte[] buffer, Int32 offset, Int32 size) [0x00000] in <filename unknown>:0
So I'm noticing here lately a lot of point releases keep coming out and with each one this appears to become more and more stable.  It still isn't rock solid yet but I do feel that its getting there.  Right now I'm working on manually refreshing all 1400 movies in my library since it isn't picking up the details on its own.  It appears to be doing ok with its scans and not causing the server to die during a scan as of lately.  Only time will tell.
Does this raise any flags for anyone?  Thanks.
2015-01-13 16:24:14.9005 Error - Main: UnhandledException *** Error Report *** Version: 3.0.5490.2 Command line: /opt/mediabrowser/MediaBrowser.Server.Mono.exe -programdata /var/lib/mediabrowser Operating system: Unix 3.13.0.43 Processor count: 2 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/mediabrowser Mono: 3.2.8 (Debian 3.2.8+dfsg-4ubuntu1) Application Path: /opt/mediabrowser/MediaBrowser.Server.Mono.exe The underlying Task is already in one of the three final states: RanToCompletion, Faulted, or Canceled. System.InvalidOperationException at System.Threading.Tasks.TaskCompletionSource`1[System.Int32].SetException (IEnumerable`1 exceptions) [0x00000] in <filename unknown>:0 at System.Threading.Tasks.TaskCompletionSource`1[System.Int32].SetException (System.Exception exception) [0x00000] in <filename unknown>:0 at System.Threading.Tasks.TaskFactory`1[System.Int32].InnerInvoke (System.Threading.Tasks.TaskCompletionSource`1 tcs, System.Func`2 endMethod, IAsyncResult l) [0x00000] in <filename unknown>:0 at System.Threading.Tasks.TaskFactory`1+<FromAsyncBeginEnd>c__AnonStorey5`3[System.Int32,System.Byte[],System.Int32,System.Int32].<>m__0 (IAsyncResult l) [0x00000] in <filename unknown>:0 at System.Net.WebAsyncResult.CB (System.Object unused) [0x00000] in <filename unknown>:0
*** Error Report *** Version: 3.0.5490.2 Command line: /opt/mediabrowser/MediaBrowser.Server.Mono.exe -programdata /var/lib/mediabrowser Operating system: Unix 3.13.0.43 Processor count: 2 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/mediabrowser Mono: 3.2.8 (Debian 3.2.8+dfsg-4ubuntu1) Application Path: /opt/mediabrowser/MediaBrowser.Server.Mono.exe The task has already completed System.InvalidOperationException at System.Runtime.CompilerServices.AsyncTaskMethodBuilder.SetException (System.Exception exception) [0x00000] in <filename unknown>:0 at System.IO.Stream+<CopyToAsync>c__async0.MoveNext () [0x00000] in <filename unknown>:0 at (wrapper unbox) System.IO.Stream/<CopyToAsync>c__async0:MoveNext () at System.Threading.Tasks.AwaiterActionContinuation.Execute () [0x00000] in <filename unknown>:0 at System.Threading.Tasks.Task.ProcessCompleteDelegates () [0x00000] in <filename unknown>:0 at System.Threading.Tasks.Task.HandleGenericException (System.AggregateException e) [0x00000] in <filename unknown>:0 at System.Threading.Tasks.Task.TrySetException (System.AggregateException aggregate, Boolean cancellation, Boolean observed) [0x00000] in <filename unknown>:0 at System.Threading.Tasks.TaskCompletionSource`1[System.Int32].TrySetException (IEnumerable`1 exceptions) [0x00000] in <filename unknown>:0 at System.Threading.Tasks.TaskCompletionSource`1[System.Int32].SetException (IEnumerable`1 exceptions) [0x00000] in <filename unknown>:0 at System.Threading.Tasks.TaskCompletionSource`1[System.Int32].SetException (System.Exception exception) [0x00000] in <filename unknown>:0 at System.Threading.Tasks.TaskFactory`1[System.Int32].InnerInvoke (System.Threading.Tasks.TaskCompletionSource`1 tcs, System.Func`2 endMethod, IAsyncResult l) [0x00000] in <filename unknown>:0 at System.Threading.Tasks.TaskFactory`1+<FromAsyncBeginEnd>c__AnonStorey5`3[System.Int32,System.Byte[],System.Int32,System.Int32].<>m__0 (IAsyncResult l) [0x00000] in <filename unknown>:0 at System.Net.WebAsyncResult.CB (System.Object unused) [0x00000] in <filename unknown>:0
Also I don't know if this would really play a role or not but I am reverse proxing this through my firewall so that way I'm not exposing the server directly to the real world and gives it an extra layer of protection.
