Stream Ends before the movie does
Maudite
 Share
Maudite
I unfortunately have this issue quit frequently. While watching a movie all is going well, and then the movie just ends. It is as if it thinks it has reached the end of the movie, as the progress is lost. I can then just go to the scene's and continue watching the rest of the movie with no issue, so not a problem with the files as far as I can tell.
Server ver: 3.0.5464.40000
Watching in web client on Xbox one.
Link to comment
Share on other sites
Maudite
Nobody else has had an issue like this happen? Every video plays to the end just fine?
Link to comment
  • 4 months later...
ITjay
I am also experiencing this issue. I am running 3.0.5621.4 on Debian 8. This problem has happened on 2 different machines and only since I upgraded to 3.0.5621.4. The current machine is a Core 2 Duo 2.66GHz with 6GB RAM. The machine is dedicated to Emby.The player is a Roku 3. Hopefully others have had this problem.
Link to comment
ITjay
After further investigation, it seems that this only affects videos longer than 30 minutes. Normal length TV shows run all the way to the end. If I play the longer episode from the chapter selection at the end it will run all the way so I know the files are ok.
Link to comment
 Share
