Removing CDN and re-enabling Direct access
Checked KB articles and haven't found an answer to this
unfortunatly CF has hit me so the CDN is gone. Temporarily looking to remove the CDn for now,
In CF I have disabled the DNS proxy and removed the remote connections handling by proxy, and removed the URL from the path within the dashboard
unfortunately after all of this, I can still only access the server via the IP address directly, I cannot access via the apps or app.emby.media. those are still showing the URL link, rather than the IP.
Is this a timing issue issue or how do I force connect to see the direct IP now, rather than the URL .
It also shows remote wan as IP:80 so it seems connect still thinks that's the path. Anyway to purge that?
Edited by Flexeire
Did you change the settings on Emby itself ? Disabled secure connection mode and removing the hostname there ?
Thanks for reply!
it was a rookie error.
Port number at 80, changed back to correct port and it worked.
  • Thanks 1
giankoski68
2 hours ago, Flexeire said:
Thanks for reply!
No problem.
  • Thanks 1
