GB Dreamcast switch
Has anyone came up with a switch for the nullDC dreamcast emulator?
In MBT I use  "-config ImageReader:DefaultImage={PATH}" without the quotes. Works just fine.
Well now I cant get NullDC to work at all. Any luck on setup?
When you say not working what do you mean?
It wont even load a game just from the emu, let alone GB. I think its my pc I need to reboot it cause GB isn't launching any of my games for any systems.
Yeah I just tested and now GB won't launch any games. I need to check the logs.
When you try to launch the game from the emu do you get any error messages? Try a fresh copy of the emu aswell as from experience, nullDC can stop working randomly every so often.
You also need to edit the 'nullDC.cfg' as well if you havent already. Emulator.AutoStart needs to be set to 1, Fullscreen set to 1,  LoadDefaultImage set to 1 and DefaultImage set to %path%. That along with the command line I gave you should make it work in MBT. If your using classic, change {PATH} to "{rom}".
this works for me with nulldc
-config ImageReader:DefaultImage="{rom}"
Okay, everything is launching okay again (MBC just needed updating). I'll try the switches later.
Thanks,
S.
So @@c0m3r I keep keep getting this error message when nullDC tries to start up. 541b78239c75b_Untitled.png
Was that from launching the emulator directly or through media browser? If direct then that is the correct behaviour. The stuff i said to change in the ini will cause that error but should work from mediabrowser.
