Server not starting "IP refuse to connect"
ifamily87
My server been working for a long time, but the last week it stopped working and I keep getting an error that the IP refuse to connect.
I uninstalled and installed the app and still did not solve the issue. See screenshot attached
I have the latest update 4.6.4.0
Tnas TOS version 4.2.15
Edited by ifamily87
Are you connecting from inside TOS or from your browser directly outside of TOS?
If from a browser, have you tried from within TOS too?
ifamily87
I am connecting from inside TOS.
can you please help! I have the latest 4.6.4 version, I tried to install manually, and through the app store but no luck, the server starts and then stop immediately. I cannot access any settings on emby, bad gate way or refuse to connect. I even reset the whole TNAS to factory install new TOS, and still the same issue, all the other apps works.
I just fixed this, log in to your TNAS root folder and delete the emby app data folder, then re install emby again.
