Emby Blog
  • entries
    570
  • comments
    4976
  • views
    3500443
Contributors to this blog
  • Luke 353
  • ebr 70
  • Carlo 31
  • sross44 18
  • 7illusions 15
  • ScottIsAFool 12
  • Abobader 11
  • radeon 8
  • xnappo 8
  • darwindeeds 7
  • Redshirt 6
  • Cheesegeezer 5
  • leedavies 3
  • Aphid 3
  • bigjohn 3
  • snazy2000 3
  • softworkz 3
  • techywarrior 3
  • Soultaker 2
  • chef 2
  • gcw07 2
  • marcelveldt 1
  • hurricanehrndz 1
Emby for Amazon Fire TV 3.4.65 Released
Emby for Amazon Fire TV 3.4.65 has been released. Here are the highlights:
  • The download feature is back !
  • Improve performance
  • Fixes for gamepad input
  • Add playback option to disable direct play of various formats
  • Add option to configure to login as specific user on startup
  • Fix video rotation on Fire TV devices when direct playing
  • Add convert unsupported audio option
  • Play vtt subtitles directly without conversion from the server
  • Support playback correction
  • Add a-z picker to add to collection/playlist
  • Fixes for closed caption rendering
  • Fixes related to autoplay episodes options
  • Add video screen up action option to control up button press behaviorĀ
  • Add option to control video player long press action
  • Like 3
4 Comments
Recommended Comments
Tank_Killer
Not_Left_Blank
When I checked the amazon app store (17/05/2025) it showed Emby for fire tv as version 2.1.26a which is what I currently have installed on mine. Will this at some point become 3.4.65 or will 2.1.26a still be available? I tried the plain Emby which I presume is the android version and while it looks slightly nicer I had one problem with it. The android version is 3.4.68 and does not have the Playback setting Deinterlace SD Content. As I have quite a few cases where I get a green screen with audio only I have found this invaluable as I just set this and the problem goes away. Yes I know there is playback correction but that needs selecting each time as the system does remember it and in any case needs done for each episode of a series and doesn't cross profiles. Is there a solution that is as simple as just settingĀ Deinterlace SD Content as I really don't feel likeĀ  going through my collection and reencoding each file.
  • Thanks 1
Not_Left_Blank
That should be "Yes I know there is playback correction but that needs selecting each time as the system does not remember it"
  • Thanks 1
Luke
Correct yes.
