Emby Blog
  • entries
    570
  • comments
    4976
  • views
    3499959
Contributors to this blog
  • Luke 353
  • ebr 70
  • Carlo 31
  • sross44 18
  • 7illusions 15
  • ScottIsAFool 12
  • Abobader 11
  • radeon 8
  • xnappo 8
  • darwindeeds 7
  • Redshirt 6
  • Cheesegeezer 5
  • leedavies 3
  • Aphid 3
  • bigjohn 3
  • snazy2000 3
  • softworkz 3
  • techywarrior 3
  • Soultaker 2
  • chef 2
  • gcw07 2
  • marcelveldt 1
  • hurricanehrndz 1
Android TV Updated with New Guide and Grid Views
A new update to the Android TV app will be released soon with a new fresh look and "smooth scrolling" capability in the live TV guide as well as new vertically scrolling grid views.
A Fresh, Smooth Guide
The live TV guide has received a make-over and now has smooth scrolling through both channels and time instead of the old "paging" implementation.
Going Vertical
You spoke and we listened. The grid views in the app now default to a vertically scrolling presentation. This allows you to navigate large collections more quickly and is in line with the designs on all the other platforms. If, however, you really prefer the previous horizontal scrolling presentation in this app, you can switch back to that in any of the views you wish by selecting the "Settings" icon (cog wheel) on the toolbar and selecting that option. It will be remembered for that particular view from that point forward.
In addition, we've now made the direct letter jump bar visible at all times (instead of behind a button) for easy access and made it behave more like you would expect in that it moves you to the first item for that letter within the content instead of restricting the content to only items after that letter.
Improved Performance for European live TV Streams
This release also should make some of those problematic live TV streams that previously may have required you to select the MPV player option play correctly within the default player simplifying your playback experience. There should be no reason to select MPV as the player anymore but we have left the option there for now if you wish to enable it (this option may be removed in the future).
Other Improvements
In addition to the major items above, this release also includes the following fixes and improvements:
  • Improve playback error handling
  • Fix shuffle play of external audio playlists
  • Don't loop theme song playback
  • Scroll default tab into view upon library entry
  • Improve some default images
  • Fix external playlists not showing
  • Add option to not allow video stream copy for live TV
  • Properly remove items from "Play Next" when manually marked watched
  • Add 240Kb/s bitrate option
  • Ensure "Continue Watching" obeys server-side settings
  • Fix playing music artists
  • Fix people search against beta server
  • Fix album sort by year
  • Option for focus rectangle
  • Default to higher bitrate on local LAN on all devices
  • Improve app response when can't validate Premiere do to outage
  • Audible feedback for trying to seek past live time
  • Add container to media details
  • Update translations
  • Make small "Up Next" panel the default (up arrow expands to larger one)
  • Implement new WoL method
  • Direct play items from Play Next
  • Refresh home screen on library change
  • Fix Premiere not recognized immediately
  • Fix diacritics in device name causing login failure
  • Add favorite episodes row to Favorites view in TV library
  • Allow favorite filter in "All" movies and series views
  • Use thumbs for latest TV
  • Sort favorites by name
  • Like 13
15 Comments
Recommended Comments
mastrmind11
great update!
  • Like 1
SikSlayer
Great job on this update!
jblaze12
This is great, forgive my ignorance: is "android tv" the same as what's on my samsung tv (2016 version)? I really like these improvements!
EODCrafter
Thanks! This rolls out in the regular Store App or you have to be a Tester?
BaconFeet
Amazing job on the updates :)
ebr
Hi.  This is available now in the normal store app.  Thanks.
ebr
Hi.  It depends on which app you are using on that device.  If it is the one from Google Play, then yes.
StewieGreen
Wow, nice update!
One question:  What does "Add option to not allow video stream copy for live TV" do and why I would (or would I not) use it?  (I saw it in Live TV settings earlier too)
I'll be sure to try out live tv here in Australia because some of my channels required MPV.
nyplayer
I am only getting 12 hours of guide data when I scroll to the right ....  In windows etc ... I get more. I have the Server set for 14 days.
NerveLow9223
I signed up..Download App etc..I have to search for everything to Hrid or anything..Only Say Options,Empty On Left Side..Can Someone help.
NerveLow9223
No Grid
Sammy
What is the version number?
above1
OMG.. Hallelujah.   A guide that is on par with others out there.   Execellent!
  • Like 1
dcol
Nice, I like improvements. Only thing is the guide scrolling is slow. When you have 100 channels to scroll though it takes time to get to the bottom. I will have to program a page_down and page_up on my remote so not a real biggie for me.
  • Like 1
cptv
Agreed. For those of us with 100+ channels the old scrolling was way better. It's silly that the new implementation does not have any sort of acceleration. Holding down should be much faster than tapping it repeatedly
