Emby Emby Emby Learn
  • Emby Home
  • Video
  • Audio
  • Media Files
    • Subtitles and captions
    • Photos and images
    • Metadata and discovery
    • Playback and streaming
    • Media hardware acceleration
    • Displays and AV connections
    • Live TV and recording
  1. Emby Learn
  2. Video
  3. Tone mapping
  4. Tone-mapping curves
  5. General-purpose curves
  6. Gamma
Search Results for
    Show / Hide Table of Contents
    Tone Mapping Curve: Gamma
    Gamma tone mapping uses a power function to redistribute brightness, with implementation-specific handling near black.
    A power mapping can give lower values more output room than uniform scaling. In the plotted FFmpeg example, most of the curve uses T(x) = (x/8)^(1/1.8), fitting a source peak of eight into output white one.
    FFmpeg gamma mapping with parameter 1.8 and source peak eight.
    FFmpeg 8.1 scalar CPU function, relative linear light for neutral gray. Its very dark region uses the implementation's linear extension.
    Input Mapped output Uniform division by eight
    1 About 0.315 0.125
    4 About 0.680 0.500
    8 1 1
    The endpoint fits in both cases. The power function assigns more output to the lower and middle inputs, changing the contrast distribution.
    The straight segment near black
    A bare power with exponent below one becomes very steep near zero. FFmpeg replaces the part below input 0.05 with a straight extension that meets the power value there:
    T(x) = x × (0.05/8)^(1/1.8) / 0.05 for x up to 0.05.
    Input 0.01 therefore produces about 0.01193, and 0.05 produces about 0.05963. The plotted function includes that treatment; using the power expression down to zero would describe a different shadow response.
    Resolve the parameter's meaning before reproducing a result
    libplacebo's mapper also uses the name gamma, but preserves an unchanged lower interval and chooses a power above its knee. Its knee parameter has a different role from FFmpeg's gamma parameter.
    Neither is simply the display gamma. This function remaps a brightness range. Display gamma participates in a signal-to-light response. During an Emby comparison, locating that operation within the playback path keeps the mapping arithmetic separate from output interpretation.
    See Also
    • What a Tone-Mapping Curve Controls
    • Video Gamma
    • Tone Mapping Curve: Mobius
    References
    • FFmpeg 8.1: gamma tonemap implementation
    • libplacebo 7.360.1: gamma mapping
    On this Page
    Back to Top
