Emby Emby Emby Learn
  • Emby Home
  • Video
  • Audio
  • Media Files
    • Subtitles and captions
    • Photos and images
    • Metadata and discovery
    • Playback and streaming
    • Media hardware acceleration
    • Displays and AV connections
    • Live TV and recording
  1. Emby Learn
  2. Live TV and recording
  3. Broadcast standards
  4. DVB family
  5. DVB-C
Search Results for
    Show / Hide Table of Contents
    DVB-C cable television
    DVB-C specifies a digital cable transmission arrangement whose QAM modulation and framing recover service data before access and media decoding are established.
    DVB-C defines framing, channel coding and modulation for digital cable systems. Its QAM arrangement lets a receiver recover data from a compatible cable carrier.
    It does not, by itself, describe whether a programme is encrypted or which video codec it contains.
    More constellation alternatives label more bits
    QAM uses amplitude/phase relationships represented by a constellation of possible symbol points.
    For an original mapping exercise:
    Alphabet Alternatives Bits needed to label a point
    64-QAM 64 6
    256-QAM 256 8
    At a declared five million symbols per second, the raw label rates are thirty and forty Mbit/s respectively.
    These calculations omit error coding, framing and other transmission structure. They are not the useful programme capacity of an installed cable service.
    Point separation affects recovery
    Consider an original ideal square-constellation model normalized to the same unit mean symbol power.
    An eight-by-eight grid with odd levels −7 through 7 has mean unnormalized energy 42. A sixteen-by-sixteen grid with odd levels −15 through 15 has mean energy 170.
    Their normalized adjacent-point distances are:
    64-point grid:  2 / √42  = 0.308607
    256-point grid: 2 / √170 = 0.153393
    Calculated original square constellations keep equal mean power while showing different point separation.
    The denser alphabet places neighbouring alternatives closer under this normalization. Noise or distortion can consequently move a received point toward another decision region more easily.
    This is a geometric teaching model, not a measured error threshold or a complete DVB-C receiver simulation. Coding and the actual receiver/channel also influence recovery.
    The service can have an access requirement
    A demodulator recovering a cable transport has answered the transmission question. It has not necessarily established a usable protected-service path.
    Clear QAM addresses relevant unencrypted cable services. Encrypted channels addresses the additional access/protection relationship.
    Those conditions should not be inferred merely from a QAM modulation label.
    Emby needs the selected recovered components
    The source/backend identifies the programme and supplies its encoded streams. Client/server preparation then depends on their actual representations.
    See Also
    • Cable television
    • Clear QAM cable television
    • Encrypted TV channels and supported playback paths
    • Broadcast service identifiers
    References
    • DVB: DVB-C framing, coding and modulation specification
    • DVB: Service Information specification
    On this Page
    Back to Top
