NVDEC and CUVID API names
NVDEC names NVIDIA’s decoding engine while CUVID and NVDECODE names persist in software interfaces, library symbols and media-program wrappers that reach its supported decode paths.
NVIDIA video decoding appears under several related names. NVDEC names the dedicated engine. NVDECODE API names its software interface, while CUVID remains visible in function, header and library names.
Reading those names at their own levels avoids inventing separate codec formats or hardware blocks.
Current interfaces retain CUVID symbols
The SDK 13.1 guide still documents these names:
| Name | Role |
| cuviddec.h and nvcuvid.h | Decoder-interface headers |
| cuvidCreateDecoder | Create the selected decoder |
| cuvidDecodePicture | Submit picture reconstruction |
| cuvidMapVideoFrame | Obtain the traditional mapped/post-processed output |
| cuvidUnmapVideoFrame | Release that mapped output |
| nvcuvid.dll or libnvcuvid.so | Platform library naming in the documented stack |
The names are part of the software contract. Seeing cuvid in a trace does not establish that the application is using a separate ancient decoder engine.
The NVDEC article develops the surface and ownership behavior behind those calls.
A media program can expose different wrappers
An application can integrate dedicated codec wrappers with cuvid-related names, or use a hardware-acceleration path that describes its device frames as CUDA.
For example, h264_cuvid names a H.264 decoding wrapper in builds that provide it. A -hwaccel cuda option requests a supported hardware-acceleration arrangement under the media program's own configuration.
These names do not replace the actual source codec. H.264 remains H.264, and HEVC needs its own suitable decode configuration.
They also do not identify the encoder. A later h264_nvenc name concerns the H.264 output encoding stage.
Device context and engine execution are different facts
A decoder API can use a CUDA context and expose CUDA-addressable output. That makes the picture useful to GPU processing or a compatible encoder.
The compressed reconstruction can still be carried out by NVDEC's specialized hardware. A CUDA memory/interface label and a compute-engine activity counter have different scopes.
See Also
- NVIDIA NVDEC
- NVIDIA CUDA in media processing
- NVIDIA NVENC
- How media APIs connect applications to hardware
- Reading a transcoding log
