Emby Emby Emby Learn
  • Emby Home
  • Video
  • Audio
  • Media Files
    • Subtitles and captions
    • Photos and images
    • Metadata and discovery
    • Playback and streaming
    • Media hardware acceleration
    • Displays and AV connections
    • Live TV and recording
  1. Emby Learn
  2. Audio
  3. Digital audio fundamentals
  4. Audio bitrate
Search Results for
    Show / Hide Table of Contents
    Audio Bitrate
    Audio bitrate is the amount of encoded audio data carried per second.
    Bitrate is a data-flow measurement: how many bits of audio are carried in one second. Use it to estimate storage or delivery demand. For a compressed track, the encoder and signal determine that flow; for tightly packed integer PCM, it follows directly from the sample format.
    Calculate PCM from one sample frame
    A 48 kHz stereo track has 48,000 time positions each second. With 24 bits for each of its two channel samples, one sample frame contains 48 bits.
    48,000 × 24 × 2 = 2,304,000 bit/s, or 2.304 Mbit/s.
    PCM representation Audio payload rate
    44.1 kHz, 16-bit, 2 channels 1.4112 Mbit/s
    48 kHz, 24-bit, 2 channels 2.304 Mbit/s
    48 kHz, 24-bit, 6 channels 6.912 Mbit/s
    Decimal units are used here. File headers and transport overhead are excluded, and the samples are assumed to occupy exactly their stated integer precision.
    To find storage, divide by eight and multiply by duration. Ten minutes of the 48 kHz, 24-bit stereo example contain:
    2,304,000 / 8 × 600 = 172,800,000 bytes, or 172.8 MB.
    If those 24-bit values occupy 32-bit storage words, the calculation uses 32 instead of 24. The stored sample data then occupy 230.4 MB for ten minutes. Precision and storage rate can change independently.
    Count compressed data over time
    A compressed codec represents the signal using coded blocks rather than storing every PCM value. Its encoded rate must be measured or supplied by the encoder configuration.
    Suppose three consecutive one-second intervals contain 16,000, 24,000, and 20,000 bytes of encoded audio. Their instantaneous interval rates are 128, 192, and 160 kbit/s. The three-second average is:
    (16,000 + 24,000 + 20,000) × 8 / 3 = 160 kbit/s.
    A header's nominal rate, an average for the whole track, and a rate measured over a short interval can therefore describe different observations. Variable-rate delivery needs enough buffering to handle the intervals, even when the long-term average is comfortably below the connection's throughput.
    What soundtrack bitrate tells you
    For a lossless track, successful decoding restores the encoded samples regardless of how efficiently the encoder compressed them. For lossy encoding, a data budget constrains how accurately the signal can be represented; comparison also depends on codec, channel count, and material.
    An Emby movie's total delivery demand includes video, selected audio, and packaging overhead. Use the audio rate to compare soundtrack contributions, and the total media rate when sizing the complete stream's delivery.
    See Also
    • Audio Sample Rate
    • Audio Bit Depth
    • Multichannel Audio
    References
    • Microsoft WAVEFORMATEX: Sample rate, channels, and data rate
    • ITU-R BS.646-1: Source encoding for digital sound signals in broadcasting studios
    On this Page
    Back to Top
