Emby Emby Emby Learn
  • Emby Home
  • Video
  • Audio
  • Media Files
    • Subtitles and captions
    • Photos and images
    • Metadata and discovery
    • Playback and streaming
    • Media hardware acceleration
    • Displays and AV connections
    • Live TV and recording
  1. Emby Learn
  2. Audio
  3. Audio devices and operating-system output
  4. Operating-system audio APIs
  5. Apple Core Audio
Search Results for
    Show / Hide Table of Contents
    Apple Core Audio
    Core Audio is Apple's collection of audio services for formats, conversion, processing, device access, and timed playback.
    Core Audio is a collection of Apple audio services, rather than one codec or one fixed output mode. It covers reading audio, describing formats, converting data, processing samples, and communicating with output devices.
    The name therefore does not establish whether a player mixes audio, changes its sample rate, uses spatial processing or preserves PCM values. Those results depend on the services and configuration used by the application.
    The responsibilities within the framework
    Part Responsibility
    Audio file and stream services Interpret stored or incoming audio data
    Audio Converter services Convert supported representations and sample formats
    Audio Units Process and route signal blocks, including mixing and output
    Audio Queue services Manage queued playback or recording buffers
    Audio hardware abstraction layer, HAL Provide device-oriented access on macOS
    AVAudioSession on supported Apple platforms Express the app's audio use and preferences, and observe the selected route
    Higher-level playback facilities can build on these services. An Emby app using a platform player does not have to call every lower-level API itself.
    The macOS device model and the iOS-family audio-session model also differ. A device access technique on macOS should not be assumed to be an equivalent selectable mode on a phone.
    A sample frame can span several buffers
    An AudioStreamBasicDescription, commonly ASBD, describes the stream's rate, format, channels, sample representation and packet/frame dimensions. Buffer organization then determines where the samples are stored.
    Take 48 kHz stereo with 32-bit floating-point samples:
    Arrangement Samples in memory Storage for 480 sample frames
    Interleaved L₀, R₀, L₁, R₁… in one buffer One 3,840-byte buffer
    Noninterleaved L₀, L₁… and R₀, R₁… in separate buffers Two 1,920-byte buffers
    Both represent 10 ms of stereo audio. Interleaved frames use eight bytes; each noninterleaved channel plane uses four bytes per frame. The number of buffers has not doubled the duration.
    A callback receiving 480 frames needs the appropriate amount of storage in each buffer. Treating a per-plane byte count as the total interleaved count can truncate data or overwrite memory. The format flags and buffer list supply the interpretation; a casual “float stereo” label is incomplete.
    Compressed packets have another relationship to frames. A codec packet can decode to many PCM sample frames. Packet count is not a substitute for the sample clock.
    A preference is not the actual device format
    An application can request a preferred sample rate or I/O buffer duration through its audio session. Those values express a preference. The actual route and other active audio requirements can produce another result.
    After activation or a route change, the application queries the actual sample rate and buffer duration. If a source is 44.1 kHz and the active output route is 48 kHz, some stage must supply suitable 48 kHz samples. A file's original rate remains useful metadata but does not prove the final route's rate.
    A headphone disconnection, Bluetooth selection or other route event can also change capabilities and timing. The player needs to adapt its stream rather than continuing to interpret buffers using an obsolete configuration.
    Rendering on the output deadline
    The output consumes frames at the established clock rate. Callbacks or queues keep it supplied. Data retrieval and expensive preparation need enough advance time so that the render work can meet its deadline.
    For movie playback, the system's audio timing helps the player align video presentation with the output. The duration of one callback is a processing interval, while the complete route can include additional queued and device delay.
    See Also
    • PCM Sample Formats
    • Audio Sample Rate
    • Digital-to-analog conversion (DAC)
    • The Audio Playback Path
    References
    • Apple: Core Audio Essentials
    • Apple: AudioStreamBasicDescription
    • Apple: AVAudioSession
    • Apple: Preferred sample rate and the actual sample rate
    • Apple Core Audio Format specification: Packet table
    On this Page
    Back to Top
