anther1989 0 Posted July 15, 2021 Posted July 15, 2021 (edited) Hola que tal he intendo reproducir una lista de IPTV pero me marcar error al intentar abrir un canal, probe la misma lista en Jellyfin y ahi funciona de manera perfecta. Adjunto los logs. Tambien adjunto el logs de Jellyfin, para ver si les da una mejor idea de lo que pasa. ffmpeg-transcode-283d07c3-bd5f-4317-8b74-95cfcb5e9058_1.txt embyserver.txt ffmpeg-transcode-694fa5c2-648e-4ad7-8565-29b78ed571f8_1.txt ffmpeg-transcode-96401ad6-1be2-4471-9872-f6a43633d70e_1.txt hardware_detection-63761951749.txt Jellyfin Logs - FFmpeg.Transcode-2021-07-15_01-08-33_efb48c231d311b8c4d9cf26ebca29e7e_cf027c19.log Edited July 15, 2021 by anther1989
Carlo 4561 Posted July 15, 2021 Posted July 15, 2021 Emby for some reason is having an issue accessing the streams. Would you be able to PM me the m3u file to use to test with?
anther1989 0 Posted July 15, 2021 Author Posted July 15, 2021 cayars ya te envie el m3u por mensaje privado
Carlo 4561 Posted July 22, 2021 Posted July 22, 2021 Hi got the sample list you sent me via PM working (took a couple different VPNs) but it's not a Live stream. It's a 60 second loop. Don't know if you noticed or not but it plays the same thing over and over. You can test this with VLC or other player.
anther1989 0 Posted July 23, 2021 Author Posted July 23, 2021 Hola perdón me actualizaron el link, adjunto actualizada, la probe en media player classic y en jellyfin y si funciona, en vlc no reproduce. Adjunto capturas. prueba.m3u
Luke 42239 Posted July 23, 2021 Posted July 23, 2021 @anther1989 please attach the emby server and ffmpeg log files. Thanks !
anther1989 0 Posted July 23, 2021 Author Posted July 23, 2021 Listo te adjunto los del dia de hoy ffmpeg-transcode-8ff23bcf-f2a4-4a53-94fa-6c5c74d26176_1.txt ffmpeg-transcode-a2ce943d-9dd3-4b4c-9954-37a02dda4081_1.txt ffmpeg-transcode-0481afcb-8b4f-4ecb-b337-88610612fe74_1.txt ffmpeg-transcode-c3c8ab69-347a-4662-b76b-86a9249e2b73_1.txt ffmpeg-transcode-9320e941-7a1f-467c-a13b-bb6d952ee9bb_1.txt ffmpeg-transcode-c2141859-9e6d-4de6-bd99-bfd6404c82d5_1.txt ffmpeg-transcode-85e692c8-5edb-4f7d-9bb0-31e5cdd7d948_1.txt ffmpeg-transcode-00f42cfb-b2b1-4e47-b9f1-773cb1cc159d_1.txt ffmpeg-transcode-a6548f92-6bc9-45f6-8945-dd27ec1c5e14_1.txt embyserver.txt
anther1989 0 Posted July 25, 2021 Author Posted July 25, 2021 Hola alguna idea, una disculpa por estar presionando pero mi tiempo de Emby Premier, termina el 14 de agosto compre un mes para probar pero no he podido reproducir mi lista m3u
Carlo 4561 Posted July 25, 2021 Posted July 25, 2021 On 7/23/2021 at 1:35 PM, anther1989 said: test.m3u 395 B · 1 download This m3u file doesn't return a stream but instead another m3u8 file which has multiple streams in it. That's why it's not working.
anther1989 0 Posted July 25, 2021 Author Posted July 25, 2021 Ahora entiendo pensé que era un error de Emby porque al probarlo en Jellyfin ahí me funciona sin ningún problema y puedo reproducir la lista, pero de acuerdo a lo que mencionas es un problema de compatibilidad es decir Emby no puede reproducir este tipo de archivo con esas secuencias, tengo una duda planean agregar ese soporte a Emby igual como Jellyfin ya que para valorar este punto sino pues tendría que realizar toda la migración de mi servidor multimedia a Jellyfin algo que no me agradaría mucho hacerlo.
Luke 42239 Posted July 28, 2021 Posted July 28, 2021 @anther1989 Hi, this is an m3u channel list. Have you tried importing it into our Live TV m3u feature, instead of IPTV? It should work there: https://support.emby.media/support/solutions/articles/44001848795 Please let us know if this helps. Thanks.
anther1989 0 Posted July 28, 2021 Author Posted July 28, 2021 De echo estoy usando esa sección "Live TV m3u", y es ahí donde no funciona, por eso adquirí un mes de emby premiere para ver tv en esa feature, pero no funciona.
anther1989 0 Posted July 29, 2021 Author Posted July 29, 2021 Hola que tal recien probe con la version de emby beta 4.7.0.3, sigo teniendo el mismo problema al intentar reproducir mi lista en la seccion de Live Tv, ve el el log que el problema es al intentar arrancar el ffmpeg 2021-07-29 18:39:36.258 Error Server: Error processing request *** Error Report *** Version: 4.7.0.3 Command line: C:\Users\ahern\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.22000 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: C:/Users/ahern/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 12 Data path: C:\Users\ahern\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\ahern\AppData\Roaming\Emby-Server\system System.Exception: System.Exception: Error starting ffmpeg at Emby.Server.MediaEncoding.Api.BaseStreamingService.StartFfMpeg(StreamState state, String outputPath, CancellationTokenSource cancellationTokenSource, Boolean acquireResources) at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.ProcessRequest(StreamRequest request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() ffmpeg-transcode log 18:39:35.646 Execution Date: 2021-07-29 18:39:35 18:39:35.988 [hls @ 0000011e03260880] Opening 'https://ott.cdn.iutpcdn.com/LIVE/H01/CANAL2,vxttoken=cGF0aFVSST0lMkZMSVZFJTJGSDAxJTJGQ0FOQUwyJTJGKiZleHBpcnk9MTYyNzYxMjc3NiZmbj1zaGEyNTYmeCUzQXM9dTc3aWVtdmQwYmd3MWVsLGY5YzI3NmU5NjJlNzM5YWUzYzA0NWRkYTgxZDkwYzliOWE1M2ZlZWVhNWUxNzZlZmYzZTAzNGMwYjg4NGQyOTI=/PROFILE02.m3u8' for reading 18:39:36.051 [tls @ 0000011e03297ec0] Error in the pull function. 18:39:36.052 [hls @ 0000011e03260880] parse_playlist error I/O error [https://ott.cdn.iutpcdn.com/LIVE/H01/CANAL2,vxttoken=cGF0aFVSST0lMkZMSVZFJTJGSDAxJTJGQ0FOQUwyJTJGKiZleHBpcnk9MTYyNzYxMjc3NiZmbj1zaGEyNTYmeCUzQXM9dTc3aWVtdmQwYmd3MWVsLGY5YzI3NmU5NjJlNzM5YWUzYzA0NWRkYTgxZDkwYzliOWE1M2ZlZWVhNWUxNzZlZmYzZTAzNGMwYjg4NGQyOTI=/PROFILE02.m3u8] 18:39:36.052 [hls @ 0000011e03260880] Opening 'https://ott.cdn.iutpcdn.com/LIVE/H01/CANAL2,vxttoken=cGF0aFVSST0lMkZMSVZFJTJGSDAxJTJGQ0FOQUwyJTJGKiZleHBpcnk9MTYyNzYxMjc3NiZmbj1zaGEyNTYmeCUzQXM9dTc3aWVtdmQwYmd3MWVsLGY5YzI3NmU5NjJlNzM5YWUzYzA0NWRkYTgxZDkwYzliOWE1M2ZlZWVhNWUxNzZlZmYzZTAzNGMwYjg4NGQyOTI=/PROFILE03.m3u8' for reading 18:39:36.114 [tls @ 0000011e03297ec0] Error in the pull function. 18:39:36.116 [hls @ 0000011e03260880] parse_playlist error I/O error [https://ott.cdn.iutpcdn.com/LIVE/H01/CANAL2,vxttoken=cGF0aFVSST0lMkZMSVZFJTJGSDAxJTJGQ0FOQUwyJTJGKiZleHBpcnk9MTYyNzYxMjc3NiZmbj1zaGEyNTYmeCUzQXM9dTc3aWVtdmQwYmd3MWVsLGY5YzI3NmU5NjJlNzM5YWUzYzA0NWRkYTgxZDkwYzliOWE1M2ZlZWVhNWUxNzZlZmYzZTAzNGMwYjg4NGQyOTI=/PROFILE03.m3u8] 18:39:36.116 [hls @ 0000011e03260880] Opening 'https://ott.cdn.iutpcdn.com/LIVE/H01/CANAL2,vxttoken=cGF0aFVSST0lMkZMSVZFJTJGSDAxJTJGQ0FOQUwyJTJGKiZleHBpcnk9MTYyNzYxMjc3NiZmbj1zaGEyNTYmeCUzQXM9dTc3aWVtdmQwYmd3MWVsLGY5YzI3NmU5NjJlNzM5YWUzYzA0NWRkYTgxZDkwYzliOWE1M2ZlZWVhNWUxNzZlZmYzZTAzNGMwYjg4NGQyOTI=/PROFILE05.m3u8' for reading 18:39:36.195 [tls @ 0000011e03297ec0] Error in the pull function. 18:39:36.196 [hls @ 0000011e03260880] parse_playlist error I/O error [https://ott.cdn.iutpcdn.com/LIVE/H01/CANAL2,vxttoken=cGF0aFVSST0lMkZMSVZFJTJGSDAxJTJGQ0FOQUwyJTJGKiZleHBpcnk9MTYyNzYxMjc3NiZmbj1zaGEyNTYmeCUzQXM9dTc3aWVtdmQwYmd3MWVsLGY5YzI3NmU5NjJlNzM5YWUzYzA0NWRkYTgxZDkwYzliOWE1M2ZlZWVhNWUxNzZlZmYzZTAzNGMwYjg4NGQyOTI=/PROFILE05.m3u8] 18:39:36.196 [hls @ 0000011e03260880] Empty segment [https://ott.cdn.iutpcdn.com/LIVE/H01/CANAL2,vxttoken=cGF0aFVSST0lMkZMSVZFJTJGSDAxJTJGQ0FOQUwyJTJGKiZleHBpcnk9MTYyNzYxMjc3NiZmbj1zaGEyNTYmeCUzQXM9dTc3aWVtdmQwYmd3MWVsLGY5YzI3NmU5NjJlNzM5YWUzYzA0NWRkYTgxZDkwYzliOWE1M2ZlZWVhNWUxNzZlZmYzZTAzNGMwYjg4NGQyOTI=/PROFILE02.m3u8] 18:39:36.196 [hls @ 0000011e03260880] Empty segment [https://ott.cdn.iutpcdn.com/LIVE/H01/CANAL2,vxttoken=cGF0aFVSST0lMkZMSVZFJTJGSDAxJTJGQ0FOQUwyJTJGKiZleHBpcnk9MTYyNzYxMjc3NiZmbj1zaGEyNTYmeCUzQXM9dTc3aWVtdmQwYmd3MWVsLGY5YzI3NmU5NjJlNzM5YWUzYzA0NWRkYTgxZDkwYzliOWE1M2ZlZWVhNWUxNzZlZmYzZTAzNGMwYjg4NGQyOTI=/PROFILE03.m3u8] 18:39:36.196 [hls @ 0000011e03260880] Empty segment [https://ott.cdn.iutpcdn.com/LIVE/H01/CANAL2,vxttoken=cGF0aFVSST0lMkZMSVZFJTJGSDAxJTJGQ0FOQUwyJTJGKiZleHBpcnk9MTYyNzYxMjc3NiZmbj1zaGEyNTYmeCUzQXM9dTc3aWVtdmQwYmd3MWVsLGY5YzI3NmU5NjJlNzM5YWUzYzA0NWRkYTgxZDkwYzliOWE1M2ZlZWVhNWUxNzZlZmYzZTAzNGMwYjg4NGQyOTI=/PROFILE05.m3u8] 18:39:36.196 Input #0, hls, from 'http://ipeteve.com/php/SR_REGIO_250721/tp.php?c=184&p=3&k=srregio&f=.m3u8': 18:39:36.196 Duration: N/A, bitrate: N/A 18:39:36.196 Program 0 18:39:36.196 Metadata: 18:39:36.196 variant_bitrate : 391040 18:39:36.196 Program 1 18:39:36.196 Metadata: 18:39:36.196 variant_bitrate : 1161088 18:39:36.196 Program 2 18:39:36.196 Metadata: 18:39:36.196 variant_bitrate : 4242784 18:39:36.196 Output #0, segment, to 'C:\Users\ahern\AppData\Roaming\Emby-Server\programdata\transcoding-temp\97D97D_%d.ts': 18:39:36.196 Output file #0 does not contain any stream 18:39:36.199 Adjunto logs completos embyserver.txt ffmpeg-transcode-97f52192-3ba6-44c9-9ea2-f1b0c51f4496_1.txt ffmpeg-transcode-2734752c-2bf2-4e1d-98a2-a2f04398d4eb_1.txt ffmpeg-transcode-dec124b4-7023-48f6-bbcb-914dbd119a36_1.txt hardware_detection-63763180732.txt
eltioares 9 Posted August 16, 2021 Posted August 16, 2021 (edited) Yo tambien lo intente con diferentes m3u y emby tiene bastante limitaciones para esta tarea la verdad quede un poco decepcionado, que Jellyfin que no es un programa de pago pueda y emby no. Pero espero que sigan los pasos de Jellyfin y mejoren este tema. Tiempo al tiempo. Edited August 16, 2021 by eltioares
Luke 42239 Posted September 24, 2021 Posted September 24, 2021 @anther1989 are you still having an issue with this on 4.7.0.12?
anther1989 0 Posted September 24, 2021 Author Posted September 24, 2021 Esa versión no la he probado me pase a Jellyfin, pero deja probar y te escribo como me fue
gagomezdevesa 0 Posted June 11, 2022 Posted June 11, 2022 (edited) Yo sí tengo los mismos problemas. Acabo de adquirir Emby Premiere y primera decepción. La lista m3u la reproduce sin problemas VLC y Jellyfin; pero Emby no la reproduce. La versión de Emby es la 4.7.2.0 Edited June 11, 2022 by gagomezdevesa
Luke 42239 Posted June 16, 2022 Posted June 16, 2022 On 6/11/2022 at 6:55 AM, gagomezdevesa said: Yo sí tengo los mismos problemas. Acabo de adquirir Emby Premiere y primera decepción. La lista m3u la reproduce sin problemas VLC y Jellyfin; pero Emby no la reproduce. La versión de Emby es la 4.7.2.0 Hi there @gagomezdevesa can we please look at an example? Thanks !
eragonz 1 Posted June 20, 2022 Posted June 20, 2022 yo tengo m3u en emby y se reproduce sin problema 1
Luke 42239 Posted July 2, 2022 Posted July 2, 2022 On 6/19/2022 at 10:04 PM, eragonz said: yo tengo m3u en emby y se reproduce sin problema Thanks for the feedback !
Ibizage 0 Posted March 15, 2025 Posted March 15, 2025 Hola a todos, tambien me da error, como lo arreglasteis?
