Edabb2 1 Posted July 15, 2021 Posted July 15, 2021 Will there ever be an app for Samsung Smart Tv's that doesnt require constant deletion and reinstalling by USB? Seems like its weekly that I have to clear the old app and download a new one to install. Would be super awesome for an app in the samsung app store.
Luke 42240 Posted July 15, 2021 Posted July 15, 2021 Hi, we're hoping so, and that's what we're trying to do. We already have an app in the store for the USA and Canada. We're hoping to expand it worldwide but there are challenges to it beyond our control.
Edabb2 1 Posted July 15, 2021 Author Posted July 15, 2021 I am in Canada and don’t have access to the app. Where can I find it?
Luke 42240 Posted July 15, 2021 Posted July 15, 2021 Ah I'm sorry, I meant to say USA and UK. Sorry about that.
rodainas 191 Posted July 16, 2021 Posted July 16, 2021 (edited) My TV default region isn’t USA nor UK. What I did is change the region to USA with a button combinations on the remote after resetting the samsung apps hub. Done, no more problems with the app. Edited July 16, 2021 by rodainas 1 1
lejared 29 Posted July 17, 2021 Posted July 17, 2021 Unfortunately that's not an option if you also want to use some local apps from your actual region. 2
Luke 42240 Posted July 13, 2023 Posted July 13, 2023 For those in Canada can you please check the app store on your Samsung TV and let us know if the Emby app is available now? Thanks ! 1
Edabb2 1 Posted July 14, 2023 Author Posted July 14, 2023 23 hours ago, Luke said: For those in Canada can you please check the app store on your Samsung TV and let us know if the Emby app is available now? Thanks ! This is fantastic. Thank you so much 1
