hjortur17 0 Posted July 13, 2021 Posted July 13, 2021 (edited) I am trying to set up port forwarding on my new router. It has been working on the old router but not any more. The new router is Sagemcom f@st 5366. What else do I need to do to get this to work? Note: It's working In-Home but not if try to access the remote IP address (85.*.*.*) Edited July 13, 2021 by hjortur17
Abobader 3485 Posted July 13, 2021 Posted July 13, 2021 Hello hjortur17, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Happy2Play 9802 Posted July 13, 2021 Posted July 13, 2021 5 minutes ago, hjortur17 said: I am trying to set up port forwarding on my new router. It has been working on the old router but not any more. The new router is Sagemcom f@st 5366. What else do I need to do to get this to work? Note: It's working In-Home but not if try to access the remote IP address (85.*.*.*) Are those the ports you have configured in Emby also? Ideally you use default ports 8096 for http and 8920 for https.
Happy2Play 9802 Posted July 13, 2021 Posted July 13, 2021 (edited) What issues are you having with WANIP:32400? Port is open and can see manual login page. Edited July 13, 2021 by Happy2Play
hjortur17 0 Posted July 13, 2021 Author Posted July 13, 2021 What do you mean? If I have been having issues with WANIP:32400? Port 32400 worked for me last time but not 8096. I have 32400 configured in Emby
Happy2Play 9802 Posted July 13, 2021 Posted July 13, 2021 11 minutes ago, hjortur17 said: What do you mean? If I have been having issues with WANIP:32400? What do you get on WANIP:32400? 18 minutes ago, Happy2Play said: Port is open and can see manual login page.
Carlo 4561 Posted July 14, 2021 Posted July 14, 2021 Are you sure you're not confusing Plex and Emby ports as 32400 is normally used by Plex while 8096 & 8920 are used by Emby. https://support.emby.media/support/solutions/articles/44002137137-remote-setup
Happy2Play 9802 Posted July 14, 2021 Posted July 14, 2021 13 minutes ago, cayars said: Are you sure you're not confusing Plex and Emby ports as 32400 is normally used by Plex while 8096 & 8920 are used by Emby. https://support.emby.media/support/solutions/articles/44002137137-remote-setup OP has configured Emby as the login page is accessible via forum post ip and that port. 1
Carlo 4561 Posted July 14, 2021 Posted July 14, 2021 OK I didn't see a WAN IP so I guess it was removed. What problem is left then or has it been solved?
hjortur17 0 Posted July 14, 2021 Author Posted July 14, 2021 When I try loading WAN:32400 I get server doesn't response on Safari, basically website doesn't load. Do you recommend to use port 8096?
Carlo 4561 Posted July 14, 2021 Posted July 14, 2021 I would suggest using 8096 or 80 for non secured and 8920 or 443 for secured connections. If you like I could remote in and give you a quick hand with this. Might take us 5 minutes or so is all.
justinrh 264 Posted July 14, 2021 Posted July 14, 2021 Are you behind the router when you do your test? You need to be on another network when you do your test. 1
hjortur17 0 Posted July 15, 2021 Author Posted July 15, 2021 I tried changing my server to 8096 but now Im not able to open the Dashboard for my Emby server. I have been trying to see if it’s work by loading the emby app
hjortur17 0 Posted July 15, 2021 Author Posted July 15, 2021 Now for an example my port on http is 8088 but I changed it to 8096
hjortur17 0 Posted July 15, 2021 Author Posted July 15, 2021 And this has now been added to my router from the Emby server, I have not done anything.
Solution hjortur17 0 Posted July 15, 2021 Author Solution Posted July 15, 2021 I got it working by creating new TCP rule. I'm thinking that my router was blocking port 32400 or something.
