ng4ever 40 Posted July 14, 2021 Author Posted July 14, 2021 3 minutes ago, vdatanet said: No, I talking about Emby’s settings. Best available is in Firestick’s settings.
vdatanet 1619 Posted July 14, 2021 Posted July 14, 2021 2 minutes ago, ng4ever said: Correct. Do you get direct play with audio software decoding in SFN?
ng4ever 40 Posted July 14, 2021 Author Posted July 14, 2021 6 minutes ago, vdatanet said: Correct. Do you get direct play with audio software decoding in SFN? Yes.
vdatanet 1619 Posted July 14, 2021 Posted July 14, 2021 1 minute ago, ng4ever said: Yes. No gitching?
ng4ever 40 Posted July 14, 2021 Author Posted July 14, 2021 1 minute ago, vdatanet said: No gitching? Nope no glitching as far as I can tell. 1
ng4ever 40 Posted July 14, 2021 Author Posted July 14, 2021 Ok the movie froze on them while playing it This sucks. Hopefully there is a way to fix this permanently.
vdatanet 1619 Posted July 14, 2021 Posted July 14, 2021 3 minutes ago, ng4ever said: Ok the movie froze on them while playing it What's the video bitrate?
ng4ever 40 Posted July 14, 2021 Author Posted July 14, 2021 1 minute ago, vdatanet said: What's the video bitrate? 55.2 Mb/s I believe but not 100% sure.
vdatanet 1619 Posted July 14, 2021 Posted July 14, 2021 3 minutes ago, ng4ever said: 55.2 Mb/s I believe but not 100% sure. Fire Stick 4K can't handle that. That's a different issue.
ng4ever 40 Posted July 14, 2021 Author Posted July 14, 2021 1 minute ago, vdatanet said: Fire Stick 4K can't handle that. That's a different issue. Why does it work fine with Plex then?
vdatanet 1619 Posted July 14, 2021 Posted July 14, 2021 37 minutes ago, ng4ever said: Why does it work fine with Plex then? Maybe Plex is transcoding.
ng4ever 40 Posted July 14, 2021 Author Posted July 14, 2021 (edited) 6 minutes ago, vdatanet said: Maybe Plex is transcoding. Ok how do I force Emby to transcode automatically just for this one movie when playing locally in the home network please? Seems to work fine like that on Emby. Edited July 14, 2021 by ng4ever
vdatanet 1619 Posted July 14, 2021 Posted July 14, 2021 Just now, ng4ever said: Ok how do I force Emby to transcode just for this one movie when playing locally in the home network please? Seems to work fine like that on Emby. Because Fire Stick does not support more than 35 Mbps, in the application preferences it would set 35 Mbps as the maximum bitrate on the local network. 1
ng4ever 40 Posted July 14, 2021 Author Posted July 14, 2021 Just now, vdatanet said: Because Fire Stick does not support more than 35 Mbps, in the application preferences it would set 35 Mbps as the maximum bitrate on the local network. Ok I will set 35 Mbps on the Emby app on the Fire Stick 4k. Thanks! Hopefully that helps.
ng4ever 40 Posted July 14, 2021 Author Posted July 14, 2021 The only had the selection for 30 Mbps and 40 Mbps on the Fire Stick 4k I chose 40 Mbps. Seems to be working though! Thankfully. Thanks.
ng4ever 40 Posted July 16, 2021 Author Posted July 16, 2021 (edited) @vdatanetif I got a Apple TV 4k either the previous or latest model would it be able to direct play Murder on Orient Express file ok ? Edited July 16, 2021 by ng4ever
rodainas 191 Posted July 16, 2021 Posted July 16, 2021 (edited) 3 hours ago, ng4ever said: @vdatanetif I got a Apple TV 4k either the previous or latest model would it be able to direct play Murder on Orient Express file ok ? Hi The Apple TV 4k shouldn’t have any problem direct playing the file. Edit: Doesnt direct play it using emby client. Edited July 16, 2021 by rodainas 1 1
vdatanet 1619 Posted July 16, 2021 Posted July 16, 2021 2 hours ago, rodainas said: Hi The Apple TV 4k shouldn’t have any problem direct playing the file. Current model specs: Video Formats H.264/HEVC SDR video up to 2160p, 60 fps, Main/Main 10 profile HEVC Dolby Vision (Profile 5)/HDR10 (Main 10 profile)/HLG up to 2160p, 60 fps H.264 Baseline Profile level 3.0 or lower with AAC-LC audio up to 160 Kbps per channel, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats MPEG-4 video up to 2.5 Mbps, 640 by 480 pixels, 30 fps, Simple profile with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats This is not true. The native Apple TV player cannot direct play MKVs, it needs to stream using HLS. Apple TV requires HLS fMP4 for HEVC, which does not support Emby and then the content is transcoded. Using the MPV player you can play MKV HEVC HDR but using tone mapping. It does not support DTS and requires a remux that causes the same glitches. The only way to get perfect playback is to use Infuse which supports Emby. 2 1
vdatanet 1619 Posted July 16, 2021 Posted July 16, 2021 3 hours ago, ng4ever said: @vdatanetif I got a Apple TV 4k either the previous or latest model would it be able to direct play Murder on Orient Express file ok ? 1
rodainas 191 Posted July 16, 2021 Posted July 16, 2021 31 minutes ago, vdatanet said: This is not true. The native Apple TV player cannot direct play MKVs, it needs to stream using HLS. Apple TV requires HLS fMP4 for HEVC, which does not support Emby and then the content is transcoded. Using the MPV player you can play MKV HEVC HDR but using tone mapping. It does not support DTS and requires a remux that causes the same glitches. The only way to get perfect playback is to use Infuse which supports Emby. Thanks for the clarification. 1
