Guest Posted July 13, 2021 Posted July 13, 2021 I cant work this one out, I have been slowly sorting out my Collections and randomly I will fine a film or Show has "Left" the collection and I have to re-add it, EG MCU I had this all set up and then 3 films have randomly been kick from the collection, I have re-added them but not sure if it will save or do it a gain. Have I missed a step here?
Carlo 4561 Posted July 13, 2021 Posted July 13, 2021 Hi, are you using NFO files? Have you done any meta-data refreshes?
Guest Posted July 13, 2021 Posted July 13, 2021 Just now, cayars said: Hi, are you using NFO files? Have you done any meta-data refreshes? Not a clue no only its normal schedule scan. Sorry, Im still new to Emby having been with Plex for years so trying to work out all its little kinks
Carlo 4561 Posted July 13, 2021 Posted July 13, 2021 Look at the configuration of your movie library for example and click on the advanced option up top. You will see a reference or two of NFO files. Are these enabled?
Guest Posted July 13, 2021 Posted July 13, 2021 Ahh ok, Yep one for Metadata savers and one for Metadata readers
Carlo 4561 Posted July 13, 2021 Posted July 13, 2021 OK so what should be happening is any time you add a movie to a collection it should be making an adjustment to the NFO file found in your media library next to the movie. You should see a SET line added that contains the collection name. Can you verify you see this for one of your movies in a collection when you edit the NFO file in a text editor?
Guest Posted July 13, 2021 Posted July 13, 2021 Ok, it doesn't seem to be working I can not find any NFO files at all, yet its turned on (have even enabled show hidden files)
Carlo 4561 Posted July 13, 2021 Posted July 13, 2021 Does Emby have write access to your libraries? If yes, please upload your latest server log to let us take a look.
Guest Posted July 13, 2021 Posted July 13, 2021 Yeah it should do embyserver.txt The Films I have just re-added if it helps are Black Widow, Captain Marvel. And then in the last 20 Mins I have had to re add Ghost Rider to the Ghost Rider collection
Carlo 4561 Posted July 13, 2021 Posted July 13, 2021 Thanks for the log. I'm seeing errors trying to read/update NFO files. Can you check your media libraries and make sure the user running Emby has write privs?
Guest Posted July 13, 2021 Posted July 13, 2021 Ahh ok, its on windows so Do I need to run it with admin, cos it add's the poster art to the folders just fine?
Guest Posted July 13, 2021 Posted July 13, 2021 Ok I think I have fully broken my Emby install now I changed the service to log in as a user so that it had full access to UNC paths, and now it cant refresh metadata at all for anything
Carlo 4561 Posted July 13, 2021 Posted July 13, 2021 For right now, until we figure this out, don't run it as a service. Just start it manually from the menu a user with access to all the media. Let's see what happens then. If that works you know what username you can use for running it as a service. But it sounds like it was fine previously if it could write the graphic to the media folder.
Guest Posted July 13, 2021 Posted July 13, 2021 (edited) Ok, I think I fixed it lol. I had thumbnails extraction turned on, and this seems to have been the issue as when I turned it off and refreshed the metadata for Black Widow it worked fine and added the NFO to the folder, I then added it to the collection and it added the lines into the NFO. <set> <name>Marvel Cinematic Universe</name> </set> <set> <name>The Infinity Saga</name> </set> But When I re-enable Thumbnail extraction Emby will not refresh any metadata or write NFO's into folders. Edited July 13, 2021 by morpheus2n2
Carlo 4561 Posted July 13, 2021 Posted July 13, 2021 This should not have anything to do with thumbnail extraction.
Guest Posted July 13, 2021 Posted July 13, 2021 7 minutes ago, cayars said: This should not have anything to do with thumbnail extraction. Nope it should yet that's what's coursing it, I suspect that what ever is coursing the thumb nails extraction to fail is hanging the Emby process so it is not moving on to the next task/job so is not actually ever finishing the metadata collection process. So it looks like part of the chain is failing and coursing a cascade effect.
Carlo 4561 Posted July 13, 2021 Posted July 13, 2021 It might not be hanging but just processing. BIF generation can take a while. Try setting "Generate video preview thumbnails:" to run as a scheduled task so that way it runs each night vs during scan time. See if that helps you.
Guest Posted July 13, 2021 Posted July 13, 2021 3 minutes ago, cayars said: It might not be hanging but just processing. BIF generation can take a while. Try setting "Generate video preview thumbnails:" to run as a scheduled task so that way it runs each night vs during scan time. See if that helps you. Oh no its defo failing 2021-07-13 16:39:36.095 Error App: Error creating thumbnails for \\Plex\Films\DC & Marvel Films\Black Widow (2020)\Black Widow (2021) WEBRip-1080p.mp4 *** Error Report *** Version: 4.6.4.0 Command line: C:\Users\morph\AppData\Roaming\Emby-Server\system\EmbyServer.dll -service Operating system: Microsoft Windows 10.0.19043 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: C:/Users/morph/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 6 Data path: C:\Users\morph\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\morph\AppData\Roaming\Emby-Server\system System.OperationCanceledException: System.OperationCanceledException: The operation was canceled. at System.Threading.CancellationToken.ThrowOperationCanceledException() at System.Threading.SemaphoreSlim.WaitUntilCountOrTimeoutAsync(TaskNode asyncWaiter, Int32 millisecondsTimeout, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.ImageExtraction.ImageExtractorBase.RunExtraction(String inputPath, ReadOnlyMemory`1 container, MediaStream videoStream, Nullable`1 protocol, Nullable`1 streamIndex, Nullable`1 threedFormat, Nullable`1 startOffset, Nullable`1 interval, String targetDirectory, String targetFilename, Nullable`1 maxWidth, Boolean enableThumbnailFilter, CancellationToken cancellationToken) at MediaBrowser.Providers.MediaInfo.ThumbnailGenerator.CreateThumbnailSet(Video item, LibraryOptions libraryOptions, Int32 width, CancellationToken cancellationToken) at MediaBrowser.Providers.MediaInfo.ThumbnailGenerator.CreateThumbnailSets(Video item, LibraryOptions libraryOptions, CancellationToken cancellationToken) at MediaBrowser.Providers.MediaInfo.ThumbnailGenerator.RefreshThumbnailImages(Video item, LibraryOptions libraryOptions, IDirectoryService directoryService, List`1 chapters, Boolean extractImages, Boolean saveChapters, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Void ThrowOperationCanceledException()
Carlo 4561 Posted July 13, 2021 Posted July 13, 2021 OK so we need to figure out why but try what I mentioned anyway to see if the scan will progress.
Carlo 4561 Posted July 13, 2021 Posted July 13, 2021 Any progress on the scanning front before we try to see what's up with thumbnails? Would rather try to solve one problem first.
Guest Posted July 13, 2021 Posted July 13, 2021 Yeah scanning working fine now and NFO's seem to be getting added now, been testing random media between feeding kids lol
Guest Posted July 14, 2021 Posted July 14, 2021 embyserver.txt@cayars Ok I thought it was working but it seems to still do it randomly, my Captain Marvel keeps removing itself and when I look at the log I see still. 2021-07-14 22:11:20.020 Error App: Error reading existng nfo *** Error Report *** Version: 4.6.4.0 Command line: C:\Users\morph\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19043 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: C:/Users/morph/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 6 Data path: C:\Users\morph\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\morph\AppData\Roaming\Emby-Server\system System.Xml.XmlException: System.Xml.XmlException: Data at the root level is invalid. Line 243, position 1. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.Throw(String res, String arg) at System.Xml.XmlTextReaderImpl.ParseRootLevelWhitespace() at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at NfoMetadata.Savers.BaseNfoSaver.AddCustomTags(String path, List`1 xmlTagsUsed, XmlWriter writer, ILogger logger, IFileSystem fileSystem) at NfoMetadata.Savers.BaseNfoSaver.Save(BaseItem item, LibraryOptions libraryOptions, Stream stream, String xmlPath) Source: System.Private.Xml TargetSite: Void Throw(System.Exception) All the permissions are fine cos its adding art work just not the NFO files (again ignore the ffprode errors these are the corrupt files I am working through lol) Just seems very odd to me that one file operation works fine but then another in the same location spits out a error
Happy2Play 9802 Posted July 14, 2021 Posted July 14, 2021 4 minutes ago, morpheus2n2 said: embyserver.txt 3.59 MB · 0 downloads @cayars Ok I thought it was working but it seems to still do it randomly, my Captain Marvel keeps removing itself and when I look at the log I see still. 2021-07-14 22:11:20.020 Error App: Error reading existng nfo *** Error Report *** Version: 4.6.4.0 Command line: C:\Users\morph\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19043 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: C:/Users/morph/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 6 Data path: C:\Users\morph\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\morph\AppData\Roaming\Emby-Server\system System.Xml.XmlException: System.Xml.XmlException: Data at the root level is invalid. Line 243, position 1. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.Throw(String res, String arg) at System.Xml.XmlTextReaderImpl.ParseRootLevelWhitespace() at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at NfoMetadata.Savers.BaseNfoSaver.AddCustomTags(String path, List`1 xmlTagsUsed, XmlWriter writer, ILogger logger, IFileSystem fileSystem) at NfoMetadata.Savers.BaseNfoSaver.Save(BaseItem item, LibraryOptions libraryOptions, Stream stream, String xmlPath) Source: System.Private.Xml TargetSite: Void Throw(System.Exception) All the permissions are fine cos its adding art work just not the NFO files (again ignore the ffprode errors these are the corrupt files I am working through lol) Just seems very odd to me that one file operation works fine but then another in the same location spits out a error To me those three "Error App: Error reading existng nfo" errors suggest those are corrupt nfo files as they all have different error positions. But figuring out the exact nfo file is another story.
Guest Posted July 14, 2021 Posted July 14, 2021 Yeah, but when its not writing them to the folder to start with it seems odd. What I am seeing is the Artwork gets added to the folder fine, then some media the NFO will be written and saved but others it will not (even though the art work has just been added to said folder) then it will show a read error of the non existent NFO lmao So is it a temp location within emby that's gone bad?
