Parsing Python Script
Go to solution Solved by Carlo,
ghaugabrook
Hello Emby Community,
I'm using m3u2strm python script to parse my m3u. I have it setup with windows scheduler as well. This issue I'm having with one of my tv series m3u is the process is breaking at the show "#Black". I know # tells python to comment out. How can I get around this issue or ignore it during the parsing process without having to manually edit the m3u myself? The scheduler is set to run every night at midnight, so the m3u is downloaded every night and updates back to the "#Black". I need a way to either edit or ignore during the automated download and parsing process. Thanks in advance for all help or suggestions.
https://drive.google.com/drive/folders/1JLqn_Ix7fnHSQscW8LhIuoh8qn2i5ZI2?usp=sharing
Edited by ghaugabrook
  • Solution
Hi, save your original file and then try replacing it with this file.
Let me know if it works now.
streamClasses.py
  • Like 1
ghaugabrook
Thanks, I'll try it later this evening after work.
  • Like 1
