Htpc0 5 Posted October 13, 2013 Posted October 13, 2013 What kind of compatibility will MBT have with WMC remotes? e.g. if I press the "info" button, will I be able to bring up the OSD? One thing I really dislike about Plex is that the integration with remote is minimum. You have to map everything yourself, which is an incredible chore.
Nate8727 9 Posted October 13, 2013 Posted October 13, 2013 I would really like a universal remote app for all of the devices like what xbmc has. Despite XBMCs issues, the remote app is phenomenal. 1
Steven 159 Posted October 13, 2013 Posted October 13, 2013 Currently the * button brings up the OSD but I hope it will be mapped to the info button at some point. I would like to be able to map the green button to open MBT personally.
Lee 212 Posted October 13, 2013 Posted October 13, 2013 on w8 i have the green button mapped to Start. That way you can navigate the metro tiles and launch whatever you want... That would be easy to do for MBT.... I do it now with MBC if i want to go straight there!
Steven 159 Posted October 13, 2013 Posted October 13, 2013 Oh that's pretty cool. How did you do that? Although not good for me currently as still in 7 mostly, but good for my kids and when I do finally switch for good.
Lee 212 Posted October 13, 2013 Posted October 13, 2013 http://www.thegreenbutton.tv/forums/viewtopic.php?f=49&t=2132 there you go... 1
Steven 159 Posted October 13, 2013 Posted October 13, 2013 Cheers. I had looked at that previously but didn't really find a way as I wasn't sure how to use hex codes for different applications, etc. Unless I'm missing something?
Lee 212 Posted October 14, 2013 Posted October 14, 2013 if u want I'll upload my regedit... Will Av to be tomorrow now tho...
Syztemlord 7 Posted October 14, 2013 Posted October 14, 2013 Check out CommandFusion. Great free app for Apple or Android. You can make a custom remote fairly quickly. I did mine last weekend and love it. Now I control everything from my tablet, MC, Sky, Amp!
thealienamongus 6 Posted October 14, 2013 Posted October 14, 2013 Intelliremote (24usd) and Eventghost which is free. I've messed around with intelliremote before and like it a lot it's easy to set up and customise multiple profiles, but I haven't tried eventghost yet. 1
all4dom 101 Posted October 14, 2013 Posted October 14, 2013 If anything, make WMC remote a paid plug-in. This way it helps support mb. Just a thought Luke if your reading this. 1
user29 2 Posted October 15, 2013 Posted October 15, 2013 i dont see an answer to the orginal question... Will MBT support MCE Remote?
Htpc0 5 Posted October 15, 2013 Author Posted October 15, 2013 i dont see an answer to the orginal question... Will MBT support MCE Remote? I'm guessing not. Otherwise, the devs would have weighed in already
gcw07 347 Posted October 15, 2013 Posted October 15, 2013 I'm guessing not. Otherwise, the devs would have weighed in already So far it has been working perfectly fine using my Harmony that is setup as a WMC remote. 1
Cheesegeezer 3106 Posted October 15, 2013 Posted October 15, 2013 So far it has been working perfectly fine using my Harmony that is setup as a WMC remote. Ditto!!
Steven 159 Posted October 15, 2013 Posted October 15, 2013 It works perfectly fine using a WMC Remote, it is just small details like the info button opening the OSD instead of the * key and a big wish from me is to somehow integrate the option to map the green button to open MBT. Maybe it could be done by making a change to the registry? I'm finding, especially with the kids, they are so used to just hitting the green button that they aren't using MBT but instead using WMC and MBC due to this.
yaksplat 68 Posted October 15, 2013 Posted October 15, 2013 I still like using the xbox 360 controller.
Lee 212 Posted October 15, 2013 Posted October 15, 2013 this is the hex edit reg key text to change tgb to start menu: Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\HidIr\Remotes\745a17a0-74d3-11d0-b6fe-00a0c90f57da]"RemoteName"="RC6 based MCE remote""EnableDebounce"=dword:00000001"EnableVendorPassThrough"=dword:00000001"DecoderID"=dword:00000001"CodeSetID"=dword:00000000"CodeBitLen"=dword:00000020"CodeSetNum0"=dword:00000001"CodeSetNum1"=dword:00000002"CodeSetNum2"=dword:00000003"CodeSetNum3"=dword:00000004"CodeSetNumMask"=dword:00007000"CodeSetNumShiftBits"=dword:0000000c"CodeMatchMask"=dword:ffff0f00"CodeMatchValue"=dword:800f0400"DataMask"=dword:000000ff"DataShiftBits"=dword:00000000"ReportLength"=dword:00000003"ReportDescriptor"=hex:05,0c,09,01,a1,01,85,01,19,00,2a,3c,02,15,00,26,3c,02,\ 95,01,75,10,81,00,c0,06,bc,ff,09,88,a1,01,85,02,19,01,29,ff,15,00,25,01,95,\ 01,75,08,81,00,c0,05,01,09,80,a1,01,85,03,19,01,29,ff,15,01,25,ff,95,01,75,\ 08,81,00,c0,05,01,09,06,a1,01,85,04,05,07,19,e0,29,e8,75,01,95,08,81,02,19,\ 00,29,90,26,ff,00,75,08,95,01,81,00,c0"ReportMappingTable"=hex:01,00,00,00,04,00,1e,02,00,00,00,04,00,1f,03,00,00,00, 04,00,20,04,00,00,00,04,00,21,05,00,00,00,04,00,22,06,00,00,00,04,00,23,07,\ 00,00,00,04,00,24,08,00,00,00,04,00,25,09,00,00,00,04,00,26,00,00,00,00,04,\ 00,27,0b,00,00,00,04,00,28,0a,00,00,00,04,00,29,1d,00,00,00,04,02,25,1c,00,\ 00,00,04,02,20,1f,00,00,00,04,00,51,1e,00,00,00,04,00,52,21,00,00,00,04,00,\ 4f,20,00,00,00,04,00,50,22,00,00,00,04,00,28,4e,00,00,00,01,08,02,0f,00,00,\ 00,01,09,02,23,00,00,00,01,24,02,3b,00,00,00,01,04,02,16,00,00,00,01,b0,00,\ 18,00,00,00,01,b1,00,17,00,00,00,01,b2,00,14,00,00,00,01,b3,00,15,00,00,00,\ 01,b4,00,1a,00,00,00,01,b5,00,1b,00,00,00,01,b6,00,19,00,00,00,01,b7,00,6e,\ 00,00,00,01,cd,00,10,00,00,00,01,e9,00,11,00,00,00,01,ea,00,0e,00,00,00,01,\ e2,00,26,00,00,00,01,8d,00,12,00,00,00,01,9c,00,13,00,00,00,01,9d,00,0c,00,\ 00,00,03,82,00,29,00,00,00,03,83,00,2a,00,00,00,03,82,00,0d,00,00,00,04,08,00
Lee 212 Posted October 15, 2013 Posted October 15, 2013 can't remember which line I changed but I can find out as I have the original to revert back if u want that too!!!
Popeye2468 44 Posted October 15, 2013 Posted October 15, 2013 (edited) http://forum.xbmc.org/showthread.php?tid=164252 Take a look at this Also get auto hot key software which you will be able to remap a keyboard key to launch a program of your choice I.e. F1 will launch media browser, so using the the remote remapper software you will be able to select the green button and tell it to press F1 therefore launching media browser or any other app you wish Edited October 15, 2013 by Popeye2468
MrSlippery 0 Posted October 17, 2013 Posted October 17, 2013 So far it has been working perfectly fine using my Harmony that is setup as a WMC remote. That is all I needed to hear, great news!
ABNParatrooper 6 Posted April 13, 2014 Posted April 13, 2014 At Syztemlord, I tried setting my mce remote, but don't know the commands to put in the system manager fields. Can you upload your settings please if you don't mind, thanks. I also looked at editing the registry, but still unsure where to make the changes.
