crusher11 1134 Posted July 10, 2021 Author Posted July 10, 2021 But right now, IP:8096 gets me my Emby server. Which makes no sense, because 8096 is not listed in the Emby settings anywhere.
Carlo 4561 Posted July 10, 2021 Posted July 10, 2021 If you mean from remote then that would indicate you have a port forward from the WAN side of your router to either Emby or an instance of NGINX set to listen on on 8096. Most likely it's the first. What is IP addresses of your Emby Server? What is the IP address of your NGINX server?
Carlo 4561 Posted July 10, 2021 Posted July 10, 2021 4 minutes ago, crusher11 said: They're the same, aren't they? Not my setup so I wouldn't know. Do they run on the same machine?
crusher11 1134 Posted July 10, 2021 Author Posted July 10, 2021 They're both on my NAS, yeah, but come to think of it did you mean local or remote IP? Because I would assume everything on my local network has the same remote IP, no?
Carlo 4561 Posted July 10, 2021 Posted July 10, 2021 Yes then same IP internally. Yes outside/wan address will appear the same for any traffic from inside your network. The reason I asked is being the same IP address anything bound to a port will be able to listen/respond to traffic. So in this case 8096 will be Emby itself doing the communication. 8096 will be Emby 80 will be NGINX 443 will be NGINX based on your config you posted previously. Thus you will want your port forwarding to be WAN:80 to NAS-IP:80 & WAN:443 to NAS-IP:443 Have you tried that yet?
crusher11 1134 Posted July 10, 2021 Author Posted July 10, 2021 But where does 8096 come from? Emby's ports are 4343 andd 7241.
rodainas 191 Posted July 10, 2021 Posted July 10, 2021 (edited) 12 minutes ago, crusher11 said: But where does 8096 come from? Emby's ports are 4343 andd 7241. 8096 is local port used by emby, nginx communicates with those internally. if you are using nginx the public ports on emby doesnt matter, are not used. You have set proxypass on nginx to 8096 so you need to use that local port on emby config Edited July 10, 2021 by rodainas
crusher11 1134 Posted July 10, 2021 Author Posted July 10, 2021 But if I just enter my IP and that port, how does NGINX get involved?
rodainas 191 Posted July 10, 2021 Posted July 10, 2021 (edited) 1 minute ago, crusher11 said: But if I just enter my IP and that port, how does NGINX get involved? Go over an example, which ip which port. local ip or public ip, local port 8096? Edited July 10, 2021 by rodainas
rodainas 191 Posted July 10, 2021 Posted July 10, 2021 Nginx is not involved if you access within your network, is involved when you access outside from 80 or 443 ports.
rodainas 191 Posted July 10, 2021 Posted July 10, 2021 1 minute ago, crusher11 said: Public IP, port 8096. You cant use public ip with local port. you use public ip with public port, being 80 or 443 if https
crusher11 1134 Posted July 10, 2021 Author Posted July 10, 2021 But I literally can. I can type "123.456.789.101:8096" into my browser's address bar, and it gets me a remote connection to my Emby server.
rodainas 191 Posted July 10, 2021 Posted July 10, 2021 That sounds like you are forwarding that port to emby directly on your router, because your nginx config doesnt listen on that port. 1
crusher11 1134 Posted July 10, 2021 Author Posted July 10, 2021 Where? How? There's nothing in the router settings about it that I can see, and UPnP is disabled in Emby.
vdatanet 1619 Posted July 10, 2021 Posted July 10, 2021 (edited) On 7/9/2021 at 3:57 AM, crusher11 said: I just got a new router, which means my server has moved from local IP 10.0.x.x to 192.168.x.x. I added exactly the same port-forwarding rules to the new router that I had in the old router, changed the local IP address in the NGINX config, restarted NGINX and...it doesn't connect. The domain gets a CloudFlare 524 error. My IP address followed by ports 80, 443, 4343, 8920 and 7241 fails. My IP address followed by port 8096 succeeds. This doesn't make any sense. I have Emby's ports in the network config set to 4343 for secure and 7241 for non-secure. CanYouSeeMe.org can only see me on port 8096. NGINX isn't jumping in front of any of the attempts at direct-IP access, which from memory it's supposed to. According to these rules, Nginx was not involved in your old router configuration. 7241 and 4343 are ports used by Emby. Try 80 and 443 as internal ports (Nginx is listening those ports) Edited July 10, 2021 by vdatanet
crusher11 1134 Posted July 10, 2021 Author Posted July 10, 2021 (edited) And yet 8096 works. This makes no sense. As for why those ports, someone said something about not using 80 and 443 because those are the default ports for things and hackers might try them, which means using other ports is a security-by-obscurity measure, and also that if it's a port known for being a media server ISPs might throttle it. Thus I could forward the external ports 80 and 443 to 7241 and 4343 respectively, working around those issues. I think. The conversation was a while ago. Edited July 10, 2021 by crusher11
vdatanet 1619 Posted July 10, 2021 Posted July 10, 2021 You have to change this: proxy_pass http://192.168.0.2:8096; By this: proxy_pass http://192.168.0.2:7241;
rodainas 191 Posted July 10, 2021 Posted July 10, 2021 (edited) 6 minutes ago, vdatanet said: You have to change this: proxy_pass http://192.168.0.2:8096; By this: proxy_pass http://192.168.0.2:7241; Other thing you could do is close port 8096 And letting nginx like it is, you will be forced to use 80 or 443 connected remotely, if you dont want those just change the listening ports on nginx, and remember to forward those new ones the reason you can still connect to 8096 is because is still open. Edited July 10, 2021 by rodainas
crusher11 1134 Posted July 10, 2021 Author Posted July 10, 2021 4 minutes ago, vdatanet said: You have to change this: proxy_pass http://192.168.0.2:8096; By this: proxy_pass http://192.168.0.2:7241; Domain still doesn't work.
vdatanet 1619 Posted July 10, 2021 Posted July 10, 2021 1 minute ago, crusher11 said: Domain still doesn't work. and using public IP, it works?
Carlo 4561 Posted July 10, 2021 Posted July 10, 2021 5 minutes ago, crusher11 said: And yet 8096 works. This makes no sense. Don't trust a test done from inside your LAN. Test this from a remote location or cell phone not using WIFI. Your router could be doing some "loopback" magic getting in the way and making your testing confusing. 1
vdatanet 1619 Posted July 10, 2021 Posted July 10, 2021 Just now, cayars said: Don't trust a test done from inside your LAN. Test this from a remote location or cell phone not using WIFI. Your router could be doing some "loopback" magic getting in the way and making your testing confusing. Again thinking the same thing. 1
rodainas 191 Posted July 10, 2021 Posted July 10, 2021 (edited) I set a remote vps with nginx, similar config like you, I could still access with public ip and 8096, I closed it, now the only way to access if by using the listening on nginx It was impossible for me to test locally because the vps is outside my network, am sure you only need to close it, and use what nginx listens to. Edited July 10, 2021 by rodainas
