Christofer_H 0 Posted July 10, 2021 Posted July 10, 2021 I just updated to 4.6.4 and now when I look at edit metadata for any of my movies I only have the check box for "Lock This Item To Prevent Future Changes" the rest of the boxes previously present for individual fields are missing? Any Ideas? I previously had only the name field locked for all movies, but now the "Lock This Item To Prevent Future Changes" is unchecked on all movies and I don't want my custom names being changed, but I would like other changes to be processed.
Abobader 3485 Posted July 10, 2021 Posted July 10, 2021 Hello Christofer_H, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Solution Luke 42201 Posted July 10, 2021 Solution Posted July 10, 2021 Hi, it's not gone. Have you explored the lock buttons next to certain fields? 1
Christofer_H 0 Posted July 10, 2021 Author Posted July 10, 2021 My bad, I had missed the lock icons next to certain fields. I must have missed the change when I read the changelog. I can see that all my movies still have the name field locked. Thanks for the quick reply.
AVRider 3 Posted July 10, 2021 Posted July 10, 2021 Luke, I recognize the lock icons. However, these lock icons do not lock changes (Title) for music Artists (not Album Artists), as one example. Any changes are not saved. The lock function held promise overriding not so straight forward tags.
Luke 42201 Posted July 10, 2021 Posted July 10, 2021 Ideally you wouldn't change the title of an artist. That value comes from the embedded value within your audio files. That would be a better place to change that. 1
