PINKISH 2 Posted July 10, 2021 Posted July 10, 2021 Hi, so recently i've had issues with multiple movies and tv shows, that i've downloaded recently and old ones. They seems corrupted on emby, greeen screen in the beginning always and a lot of artefacts. The files are fine, if i watch them directly on my windows pc no issues, but on emby they almost all are broken
Happy2Play 9802 Posted July 10, 2021 Posted July 10, 2021 @PINKISHplease provide the ffmpeg log also. Best guess would be a decoding issue.
vdatanet 1619 Posted July 10, 2021 Posted July 10, 2021 48 minutes ago, PINKISH said: Hi, so recently i've had issues with multiple movies and tv shows, that i've downloaded recently and old ones. They seems corrupted on emby, greeen screen in the beginning always and a lot of artefacts. The files are fine, if i watch them directly on my windows pc no issues, but on emby they almost all are broken Are you remuxing HEVC HDR content?
PINKISH 2 Posted July 10, 2021 Author Posted July 10, 2021 (edited) edit ffmpeg-transcode-52edd249-8d4f-42cf-b5a8-dda6e64973e2_1.txt Edited July 10, 2021 by PINKISH
PINKISH 2 Posted July 10, 2021 Author Posted July 10, 2021 10 minutes ago, vdatanet said: Are you remuxing HEVC HDR content? no, i don't even know how to do that
vdatanet 1619 Posted July 10, 2021 Posted July 10, 2021 1 minute ago, PINKISH said: no, i don't even know how to do that No, It's not a remuxing problem. To test, try to disable hardware acceleration
PINKISH 2 Posted July 10, 2021 Author Posted July 10, 2021 7 minutes ago, vdatanet said: No, It's not a remuxing problem. To test, try to disable hardware acceleration yep it fixed it, but why? I never had any issue before, what should i do to fix that
vdatanet 1619 Posted July 10, 2021 Posted July 10, 2021 (edited) 6 minutes ago, PINKISH said: yep it fixed it, but why? I never had any issue before, what should i do to fix that At least now we know that something has broken hardware acceleration for you. Has something changed in your system? Drivers or something else? @softworkz may help here. Edited July 10, 2021 by vdatanet
PINKISH 2 Posted July 10, 2021 Author Posted July 10, 2021 1 minute ago, vdatanet said: At least now we know that something has broken hardware acceleration for you. Has something changed in your system? Drivers or something else? no nothing, i haven't updated any drivers recently
Luke 42201 Posted July 10, 2021 Posted July 10, 2021 Have you checked to ensure your system and drivers are up to date?
PINKISH 2 Posted July 10, 2021 Author Posted July 10, 2021 just saying it is resolved, after disabling hardware acceleration i just enable it again and no issues anymore. I don't know what was wrong but for once power it on and off was the solution
Luke 42201 Posted July 11, 2021 Posted July 11, 2021 8 hours ago, PINKISH said: just saying it is resolved, after disabling hardware acceleration i just enable it again and no issues anymore. I don't know what was wrong but for once power it on and off was the solution Thanks for the feedback.
