VincentVega 1 Posted July 10, 2021 Posted July 10, 2021 (edited) The TV Show in question is "Firefly (2002)" I have all the episodes named and ordered in bluray order. Firefly (2002) > Season 1 > Firefly (2002) - S01E01.mkv is the folder structure. I am not sure if this can be automated or not because I am not even seeing an option for dvd order on TMDB. Would this have to be done manually? (I only use TMDB for metadata so that everything gets logged correctly with trakt.tv account) Sorry if this isn't the right form. I chose the one I thought best. TIA. EDIT: I re-installed TVDB plug-in after months of not using it to see if DVD order would work, and it still doesn't after a restart. Edited July 10, 2021 by ZakSteele
Solution Luke 42241 Posted July 10, 2021 Solution Posted July 10, 2021 HI, in recent months tvdb has stopped sending this data back in versions of their api lower than 4. see here for details: We'll look at supporting dvd order from moviedb in future updates. thanks.
VincentVega 1 Posted July 10, 2021 Author Posted July 10, 2021 4 minutes ago, Luke said: HI, in recent months tvdb has stopped sending this data back in versions of their api lower than 4. see here for details: We'll look at supporting dvd order from moviedb in future updates. thanks. Thank you Luke. Helpful as always. Will keep an eye out for this feature in the future! 1
