Globalnetwork 0 Posted July 9, 2021 Posted July 9, 2021 I want to buy one VBox Android TV Gateway for Satellite XTi 4134 for DVB-S/S2 Is a device VBox Android TV Gateway for SatelliteXTi 4134 for DVB-S/S2 It is fully supported on emby server Also, how to decode satellite channels on a device VBox ?
Carlo 4561 Posted July 9, 2021 Posted July 9, 2021 Hi, that box is only good for Free-To-Air local broadcast channels so you can't decode channels. This is similar to OTA broadcasts in that they are not encrypted in any way. That box can export an M3U list of channels that can be directly used in Emby. If you're not in the UK or similar place that supports DVB-S/S2 of free to air sat, then this isn't the device you want.
Globalnetwork 0 Posted July 9, 2021 Author Posted July 9, 2021 24 minutes ago, cayars said: Hi, that box is only good for Free-To-Air local broadcast channels so you can't decode channels. This is similar to OTA broadcasts in that they are not encrypted in any way. That box can export an M3U list of channels that can be directly used in Emby. If you're not in the UK or similar place that supports DVB-S/S2 of free to air sat, then this isn't the device you want. I want to decode Arabsat and Nilesat satellite channels and broadcast them through emby server What is the right device?
Carlo 4561 Posted July 10, 2021 Posted July 10, 2021 I would ask the guys at Vbox Communications directly to see what they say. If they don't make a product to do this, maybe they know of a product.
Globalnetwork 0 Posted July 12, 2021 Author Posted July 12, 2021 On 7/10/2021 at 4:36 AM, cayars said: I would ask the guys at Vbox Communications directly to see what they say. If they don't make a product to do this, maybe they know of a product. Thank you for cooperating with me I am waiting for your reply to me
Carlo 4561 Posted July 12, 2021 Posted July 12, 2021 Let us know what they say. Would be good info to know about.
Globalnetwork 0 Posted July 12, 2021 Author Posted July 12, 2021 I emailed them 5 days ago and they haven't responded yet
Globalnetwork 0 Posted July 18, 2021 Author Posted July 18, 2021 hello cayars Is there a response from Vbox?
Carlo 4561 Posted July 18, 2021 Posted July 18, 2021 I haven't emailed them about this as I would not be able to answer any questions they may ask. I had suggested that you email them.
Luke 42243 Posted July 19, 2021 Posted July 19, 2021 @Globalnetwork please let us know if they respond. Thanks.
Globalnetwork 0 Posted July 28, 2021 Author Posted July 28, 2021 On 7/19/2021 at 8:15 AM, Luke said: @Globalnetwork please let us know if they respond. Thanks. Unfortunately they have not responded yet
Globalnetwork 0 Posted July 28, 2021 Author Posted July 28, 2021 I want to decode Arabsat and Nilesat satellite channels and broadcast them through emby server What is the right device?
Lewis2e 0 Posted February 13, 2022 Posted February 13, 2022 @GlobalnetworkI am considering purchasing this device (to use with Freesat in the UK). Did you get it working with Emby?
