GiGo 108 Posted July 11, 2021 Author Posted July 11, 2021 Sounds like you are on it. I do hate the Error Null dialog, would be great to know what the heck went wrong! So glad someone is giving the Auto Organize plugin so attention. Please keep me updated.
chef 3811 Posted July 11, 2021 Posted July 11, 2021 I have been able to circumvent the "OverwriteExistsingFile" option, when using the "Identify" modal in the configuration, and allow the item to copy over to the library, while having the "OverwriteExistsingFile" option set to false. I believe this is a more intuitive way to handle. Next I'll find the "Are you sure" modal and allow "OverwriteExistsingFile" as well. 1
chef 3811 Posted July 13, 2021 Posted July 13, 2021 (edited) @GiGo Time to test this thing out. This thing is about 90% "fixed". It's safe to test. I would LOVE to know all the weird buggy stuff you might find here, and anything that isn't working intuitively. Download moved down to the next release. @cayars do you have a moment to load this thing and let me know if I have made things worse or better? @rbjtech are you around to try this thing out too? Edited July 13, 2021 by chef
GiGo 108 Posted July 13, 2021 Author Posted July 13, 2021 1 hour ago, chef said: @GiGo Time to test this thing out. This thing is about 90% "fixed". It's safe to test. I would LOVE to know all the weird buggy stuff you might find here, and anything that isn't working intuitively. Emby.AutoOrganize.zip 123.49 kB · 0 downloads @cayars do you have a moment to load this thing and let me know if I have made things worse or better? @rbjtech are you around to try this thing out too? Cheers will give this a go, will report back later
GiGo 108 Posted July 13, 2021 Author Posted July 13, 2021 @chef um... I'm not seeing any changes? I've sinced moved Origin manually and now it matches, but I assumed that with a match already in place I would get an option on the right to change it? I have overwritten the old Auto Organize dll and rebooted the server, version of AutoOrganize is 1.6.0.0, I'm running the latest beta version of emby.
chef 3811 Posted July 13, 2021 Posted July 13, 2021 5 hours ago, GiGo said: @chef um... I'm not seeing any changes? I've sinced moved Origin manually and now it matches, but I assumed that with a match already in place I would get an option on the right to change it? I have overwritten the old Auto Organize dll and rebooted the server, version of AutoOrganize is 1.6.0.0, I'm running the latest beta version of emby. You replaced the dll in "programdata/plugins"? Might have to clear browser data. That is still the old UI.
GiGo 108 Posted July 13, 2021 Author Posted July 13, 2021 1 minute ago, chef said: You replaced the dll in "programdata/plugins"? Might have to clear browser data. That is still the old UI. Yep that solved it! WOW That looks SO SO MUCH BETTER and it WORKS! GREAT WORK! You need to roll this out to everyone it's so much better! 1
GiGo 108 Posted July 13, 2021 Author Posted July 13, 2021 FYI; Just tried a file that I already had in my collection as I wanted to updated it, it would of had the same file name when I click the Organize button it came up with a blank error 'Internal Server Erro' message, however if I click the new Identify button and select the correct show it moves it perfectly without any error message.
chef 3811 Posted July 13, 2021 Posted July 13, 2021 1 minute ago, GiGo said: FYI; Just tried a file that I already had in my collection as I wanted to updated it, it would of had the same file name when I click the Organize button it came up with a blank error 'Internal Server Erro' message, however if I click the new Identify button and select the correct show it moves it perfectly without any error message. Right! I have to track down that error. I saw it too. When the plugin has the option to "overwrite" unchecked, we send a new param (on button click) to "requestOverwrite" to the server. The second button doesn't send that request yet. I'd better track that down today before I send it to Luke.
rbjtech 5341 Posted July 13, 2021 Posted July 13, 2021 8 hours ago, chef said: @rbjtech are you around to try this thing out too? yep - gimme an hour or so and I'll happily test - thanks 1
chef 3811 Posted July 13, 2021 Posted July 13, 2021 (edited) Here is a version which should fix the button click. Clear browser data, because we changed the Javascript. Edited July 14, 2021 by chef
rbjtech 5341 Posted July 13, 2021 Posted July 13, 2021 This was on the previous version - but is looking much more polished than the previous plugin and working well. Is there anything in particular you want me to test, or test everything ?
chef 3811 Posted July 13, 2021 Posted July 13, 2021 (edited) 58 minutes ago, rbjtech said: This was on the previous version - but is looking much more polished than the previous plugin and working well. Is there anything in particular you want me to test, or test everything ? Wondering about those failures. I notice the identify button is not available. Does the Correction Modal appear when you click the "Move" button beside items like "Top Gear-s01e16-USA Road Trip.mp4"? I also winder is there is a better word to use in the UI besides "Failure". Which sounds worse then an "un-identified" item. Edited July 13, 2021 by chef
GiGo 108 Posted July 13, 2021 Author Posted July 13, 2021 8 minutes ago, chef said: I also winder is there is a better word to use in the UI besides "Failure". Which sounds worse then an "un-identified" item. 'Attention' maybe? But honestly don't think it matters. 2
rbjtech 5341 Posted July 13, 2021 Posted July 13, 2021 They are previous failures not yet run though the new version - I'm just going to re-identify them and we should be all green again. Gonna need an hour or so - pesky work is getting in the way ..
chef 3811 Posted July 13, 2021 Posted July 13, 2021 1 minute ago, rbjtech said: They are previous failures not yet run though the new version - I'm just going to re-identify them and we should be all green again. Gonna need an hour or so - pesky work is getting in the way .. Thanks for your time.
chef 3811 Posted July 13, 2021 Posted July 13, 2021 4 minutes ago, GiGo said: 'Attention' maybe? But honestly don't think it matters. Yep! That is much better.
chef 3811 Posted July 13, 2021 Posted July 13, 2021 (edited) I submitted the work on GitHub. But I am absolutely the worst at properly submitting a pull request, so I submitted the work to Luke directly, as well. There were some other feature requests from users, so maybe if there is time, I'll look at those as well. Edited July 13, 2021 by chef 3
rbjtech 5341 Posted July 13, 2021 Posted July 13, 2021 4 hours ago, chef said: Thanks for your time. These are all cleared now @chef - bbc iplayer and thetvdb episode numbering does not match, so I just need to rename to thetvdb naming and all is good. Thanks for the much needed refresh of this essential plugin. 1
GiGo 108 Posted July 14, 2021 Author Posted July 14, 2021 Just noticed an issue when organising, can't see the 'remember this correction' tick box 1
chef 3811 Posted July 14, 2021 Posted July 14, 2021 2 hours ago, GiGo said: Just noticed an issue when organising, can't see the 'remember this correction' tick box I'll fix it right away. Thank you.
chef 3811 Posted July 14, 2021 Posted July 14, 2021 (edited) Here we go, let me know if this fixes the margin issue in the modal This also fixes Movie organization. Edited July 14, 2021 by chef
chef 3811 Posted July 14, 2021 Posted July 14, 2021 (edited) @rbjtech do you know what is the difference between the Auto-detect movies, and auto organize movies options in the auto organize plugin? What is create sub directory per movie? Does that mean in the watched folder or in the actual library? Edited July 14, 2021 by chef
GiGo 108 Posted July 14, 2021 Author Posted July 14, 2021 1 hour ago, chef said: Here we go, let me know if this fixes the margin issue in the modal Emby.AutoOrganize.zip 642.29 kB · 0 downloads This also fixes Movie organization. This appears to the be the source code rather than just the dll file, I would compile it myself but haven't got a clue how to do it lol
