survivorhosting 0 Posted July 9, 2021 Posted July 9, 2021 (edited) trying to send an invite and it saying the account is invalid tried a whole new email and same issue any issues with emby connect. yes both are registered and can login to emby community no problems Edited July 9, 2021 by survivorhosting
survivorhosting 0 Posted July 9, 2021 Author Posted July 9, 2021 trying to send aninvite and it saying the account is invalid tried a whole new email and same issue any issues withembyconnect. yes both are registered and can login toemby community no problems
survivorhosting 0 Posted July 9, 2021 Author Posted July 9, 2021 (edited) Does the same thing if I try from a pc Edited July 9, 2021 by survivorhosting
Luke 42242 Posted July 11, 2021 Posted July 11, 2021 What did you enter into the field? Does that person have an Emby Connect account?
survivorhosting 0 Posted July 11, 2021 Author Posted July 11, 2021 Yes I used the email and I tried with the username. Yes the account is registered set up a test server and it worked fine so its something with this server just not sure what .
Luke 42242 Posted July 19, 2021 Posted July 19, 2021 Quote Yes the account is registered Hi @survivorhosting, where is the account registered? Can you please attach the emby server log from when you tried to do this? Thanks.
