NZsolt 0 Posted July 9, 2021 Posted July 9, 2021 Hi! I would like to use Emby on my S905X box. Is it possible to use hardware acceleration in Emby? If yes, then how? Thanks.
Luke 42245 Posted July 10, 2021 Posted July 10, 2021 Hi, we haven't tested this device ourselves. Do you know what graphics hardware it has?
NZsolt 0 Posted July 11, 2021 Author Posted July 11, 2021 It has Mali-450 GPU and use v4l2 api in coreelec.
Luke 42245 Posted July 19, 2021 Posted July 19, 2021 @NZsolt what you could do is install Emby Server on it and then after setup go into the logs section, locate the hardware detection log, and then attach it here. That will give us an idea of what is available.
xxAmigoxx 3 Posted August 5, 2022 Posted August 5, 2022 I want to know what happened. Does this cpu/gpu support EMBY HW Excelleration? @Luke @NZsolt
Luke 42245 Posted August 11, 2022 Posted August 11, 2022 On 8/5/2022 at 5:33 PM, xxAmigoxx said: I want to know what happened. Does this cpu/gpu support EMBY HW Excelleration? @Luke @NZsolt Hi, I would think it should using vaapi.
NZsolt 0 Posted September 27, 2022 Author Posted September 27, 2022 @xxAmigoxx I gave up last year. I think that soc has no enough power to transcode a movie properly.
