Edrock200 53 Posted November 19, 2021 Author Posted November 19, 2021 4.6.6 upgrades went through seamlessly as well. 1
Edrock200 53 Posted November 22, 2021 Author Posted November 22, 2021 Not sure if you guys care but figure more info is better than less. Updated one 4.5.4 server straight to 4.6.7 - went perfect, as well as 4.6.4 & 4.6.6 to 4.6.7. This is with both official emby docker repo and linuxserver repos. I did run into one odd error - upon the update, when logging into emby, it kept stating that attempting to update official plugins had failed. When I checked the plugins folder, based on the modify date/time stamps, they did indeed update. Since it was in the process of doing the db upgrade/initial scan, I let it get through that first, then restarted, and the plugins were properly reporting the latest version. For anyone using the Auto Movie Versions plugin, make sure you update to the latest for 4.6+ support. 1
Carlo 4561 Posted November 23, 2021 Posted November 23, 2021 Thanks for that and good tip on the Auto Movie Versions plugin! 1
Edrock200 53 Posted December 8, 2021 Author Posted December 8, 2021 One other odd issue I ran into. Full scans kept failing on one server after just a minute or two. Turned on debug logging and it was a manually installed discord notifier plugin causing the fault. Removed it, scan works now. Also didn't realize how much faster fresh scans go without the screen grabber agent enabled! 1
Luke 42197 Posted December 8, 2021 Posted December 8, 2021 1 hour ago, Edrock200 said: One other odd issue I ran into. Full scans kept failing on one server after just a minute or two. Turned on debug logging and it was a manually installed discord notifier plugin causing the fault. Removed it, scan works now. Also didn't realize how much faster fresh scans go without the screen grabber agent enabled! Thanks for the feedback.
