neik 874 Posted September 16, 2021 Posted September 16, 2021 1 hour ago, rbjtech said: Have you tried just using your FQDN and port in the config ? At the end of the day, this is just passing API requests over the wire - so it should work over a WAN/HTTPS ? Yes, I have. I am putting my domain+port (https://domain:port/emby/) and the api-key. I don't why but it doesn't work for me.
rbjtech 5341 Posted September 17, 2021 Posted September 17, 2021 16 hours ago, neik said: Yes, I have. I am putting my domain+port (https://domain:port/emby/) and the api-key. I don't why but it doesn't work for me. You are absolutely correct - it doesn't work for me either now I've realised what you are trying to do (external HTTPS access) .. sorry ! I've only ever used this on the LAN - ie the local address over http - never over https. I think it may have something to do with the API key not having sufficient rights to login remotely - which is a good thing tbh. If I could use just an API key to get access to my server remotely, I would be very concerned ... 2
neik 874 Posted September 17, 2021 Posted September 17, 2021 22 minutes ago, rbjtech said: You are absolutely correct - it doesn't work for me either now I've realised what you are trying to do (external HTTPS access) .. sorry ! I've only ever used this on the LAN - ie the local address over http - never over https. I think it may have something to do with the API key not having sufficient rights to login remotely - which is a good thing tbh. If I could use just an API key to get access to my server remotely, I would be very concerned ... Thanks for the explanation! So, if I got it right then instead of using an API key only (which is fine when local) the tool would need some sort of "real" authentication with user+pw in order to be authorized in running those API calls, right?
rbjtech 5341 Posted September 17, 2021 Posted September 17, 2021 1 minute ago, neik said: Thanks for the explanation! So, if I got it right then instead of using an API key only (which is fine when local) the tool would need some sort of "real" authentication with user+pw in order to be authorized in running those API calls, right? One of the Dev's would need to confirm but yes I believe that to be true
pünktchen 1410 Posted September 17, 2021 Posted September 17, 2021 4 hours ago, rbjtech said: If I could use just an API key to get access to my server remotely, I would be very concerned ... Then you should be very concerned now! 2
horstepipe 423 Posted September 17, 2021 Posted September 17, 2021 I‘m wondering, could that tool being used to auto fetch list from Trakt or IMDb to tag specific movies (eg academy award winners)?
VicMoore 755 Posted September 17, 2021 Author Posted September 17, 2021 I would change the access for remote servers if I knew how. Tell me what to do and I will change it. Remember that I am not a professional. I am just a guy that knows a little about javascript and jQuery. I learned some of the Emby API through trial and error. I admit it was fun and I enjoyed learning. So point me in the right direction and I will try and implement what you want. I appreciate all of your comments and suggestions. They have all greatly improved the tool. Vic 2
LongMan 116 Posted September 24, 2021 Posted September 24, 2021 Source map error: Error: request failed with status 404 Resource URL: https://cdn.jsdelivr.net/npm/hls.js@latest Source Map URL: hls.min.js.map I get this error when I try to use the tool. Any help would be appreciated. Cheers, LongMan
VicMoore 755 Posted September 25, 2021 Author Posted September 25, 2021 Hello LongMan... It looks like the problem is loading hls.js I will try and simulate the problem. Try the code below. Be sure to open the HTML and change the server IP address and add your own API key. These are both at the top of the HTML. Vic emby-tag-tool-25a.html
LongMan 116 Posted September 25, 2021 Posted September 25, 2021 @VicMoore Thanks for responding. I am getting the same error with the new file. It shows My server Name, Version and Address correctly. However the Select User object has no option available.
VicMoore 755 Posted September 25, 2021 Author Posted September 25, 2021 I will create a zip file with the resources that the tool loads from a CDN, Then you can load them locally. That should fix your problem. I can't do this until tomorrow. Vic
LongMan 116 Posted September 25, 2021 Posted September 25, 2021 (edited) Ok. Thanks. Tomorrow if fine. Cheers, LongMan Edited September 25, 2021 by LongMan
VicMoore 755 Posted September 25, 2021 Author Posted September 25, 2021 Hello LongMan... I had a few minutes so I uploaded the script files for you. Unzip the attached file into the same folder where you have the HTML file for the tool. Then change the HTML for the tool as shown below. You are just commenting out the HTML that loads resources from a CDN and uncommenting HTML that will load the resources from the folder "scripts." If you have any trouble just let me know. Not all of the files in the scripts folder are used. Vic scripts.zip
VicMoore 755 Posted September 26, 2021 Author Posted September 26, 2021 Hello again LongMan... Don't make the changes above. The problem is in the user api, not in fetching the scripts. The attached code below will allow you to look at the emby users for your server. Run the code then press F12 and the console will come up. Then you can open the event and see the users. I can walk you through it if you need the help. The problem is that the API is not giving me the user names properly. Once I know what it is doing then I can fix it. Vic emby-tag-tool-25b.html
VicMoore 755 Posted September 26, 2021 Author Posted September 26, 2021 LongMan, below is what you should see on the console, except your user names will be shown rather than mine.
VicMoore 755 Posted September 26, 2021 Author Posted September 26, 2021 Good morning LongMan... So far I have not been able to duplicate your problem. I am starting to wonder if the problem might be your browser. I have only tested this software on Chrome and Edge, running on windows 10. By the way, the error message you are getting should not have any effect on the tools operation. The problem is that your user names are not appearing in the pulldown list. Vic
LongMan 116 Posted September 26, 2021 Posted September 26, 2021 Good Morning, Thanks again for looking into this. I have have tried three browsers, Firefox, Chrome and Microsoft Edge. They all show the same thing. It could be that I don't understand how to use it. I replace the included address and API key and double click ion the file and it opens in Firefox. It looks the same as the picture in the link except that it contains my server info.
LongMan 116 Posted September 26, 2021 Posted September 26, 2021 BTW. Would it be possible to allow me to type in the username and password if necessay.
VicMoore 755 Posted September 26, 2021 Author Posted September 26, 2021 LongMan, what did you find on the browser console? Did it list any names? What is in the Big box at the top pf the tool? Can you send me a picture? Vic
yarafie 6 Posted September 26, 2021 Posted September 26, 2021 Just saw this tool exactly what I'm looking for. Which version should I start with planning to use it on my local lan so 192.xxx.xxx.xxx
VicMoore 755 Posted September 26, 2021 Author Posted September 26, 2021 (edited) Attached below is the latest code. Let me know if you need help. Vic Edited September 26, 2021 by VicMoore
VicMoore 755 Posted September 26, 2021 Author Posted September 26, 2021 (edited) Yarafie, I made a mistake, the latest code is below. I was too quick with the mouse and sent the note before reading it. Be sure to edit the top of the HTML and change the server address and the Emby API key to your own. Vic emby-tag-tool-25c.html Edited September 26, 2021 by VicMoore 1
LongMan 116 Posted September 26, 2021 Posted September 26, 2021 Cookie “” has been rejected as third-party. hls.js@latest HTTP “Content-Type” of “text/html” is not supported. Load of media resource file:///C:/Users/LongMan/Downloads/emby-tag-tool-25c.html# failed. emby-tag-tool-25c.html All candidate resources failed to load. Media load paused. emby-tag-tool-25c.html Error in parsing value for ‘width’. Declaration dropped. emby-tag-tool-25c.html:359:24 Expected ‘none’, URL, or filter function but found ‘alpha(’. Error in parsing value for ‘filter’. Declaration dropped. emby-tag-tool-25c.html:633:18 Expected declaration but found ‘=’. Skipped to next declaration. emby-tag-tool-25c.html:641:15 Source map error: Error: request failed with status 404 Resource URL: https://cdn.jsdelivr.net/npm/hls.js@latest Source Map URL: hls.min.js.map
Happy2Play 9811 Posted September 26, 2021 Posted September 26, 2021 5 minutes ago, LongMan said: Cookie “” has been rejected as third-party. hls.js@latest HTTP “Content-Type” of “text/html” is not supported. Load of media resource file:///C:/Users/LongMan/Downloads/emby-tag-tool-25c.html# failed. emby-tag-tool-25c.html All candidate resources failed to load. Media load paused. emby-tag-tool-25c.html Error in parsing value for ‘width’. Declaration dropped. emby-tag-tool-25c.html:359:24 Expected ‘none’, URL, or filter function but found ‘alpha(’. Error in parsing value for ‘filter’. Declaration dropped. emby-tag-tool-25c.html:633:18 Expected declaration but found ‘=’. Skipped to next declaration. emby-tag-tool-25c.html:641:15 Source map error: Error: request failed with status 404 Resource URL: https://cdn.jsdelivr.net/npm/hls.js@latest Source Map URL: hls.min.js.map What browser? Only things I see in my console is warning. But has no effect on displaying my libraries. FF Edge/Chrome
VicMoore 755 Posted September 26, 2021 Author Posted September 26, 2021 (edited) LongMan, are you using Chrome or Edge? Can you send me a screen shot So I can see what is going on. I need more information to determine how to help you. Make sure you are using the code below. Vic emby-tag-tool-25c.html Edited September 26, 2021 by VicMoore
