hooray4me 52 Posted March 15, 2023 Posted March 15, 2023 How would I add a tag to the tv series as a whole? I see a way to bulk edit within a season of a tv show. Am I missing it?
hooray4me 52 Posted March 15, 2023 Posted March 15, 2023 Could there be an option for Has Parental Rating ? I have over 15000 movies and many of them don't have a rating.
VicMoore 755 Posted March 15, 2023 Author Posted March 15, 2023 (edited) Hello @hooray4me A TV Series is a folder, so select the series with "CTRL-CLICK". Then you can edit it and add your tag. I will look into your other request. I am right now very busy, so it may be a while. Vic Edited March 15, 2023 by VicMoore
VicMoore 755 Posted March 28, 2023 Author Posted March 28, 2023 (edited) Good morning everyone... @Cheesegeezerand I have been working together to create a plugin version of this tool. We have the first code drop ready for testing. It's not the complete tool. It is a bulk editor and has the same layout as the original tool. We are looking for some testers. Anyone interested? Vic Edited March 28, 2023 by VicMoore 1 3
MBSki 1115 Posted March 28, 2023 Posted March 28, 2023 9 minutes ago, VicMoore said: Good morning everyone... @Cheesegeezerand I have been working together to create a plugin version of this tool. We have the first code drop ready for testing. It's not the complete tool. It is a bulk editor and has the same layout as the original tool. We are looking for some testers. Anyone interested? Vic Emby.Bulky.zip 1018.5 kB · 0 downloads Yes, absolutely! How do we test when the plug-in isn't in the store though?
VicMoore 755 Posted March 28, 2023 Author Posted March 28, 2023 You have to manually install it. Copy it to the emby plugin directory and then restart emby. Vic
MBSki 1115 Posted March 28, 2023 Posted March 28, 2023 Just now, VicMoore said: You have to manually install it. Copy it to the emby plugin directory and then restart emby. Got it, thanks Vic! Copy the contents of the zip file or just the dll? I didn't see the dll for some reason.
VicMoore 755 Posted March 28, 2023 Author Posted March 28, 2023 Sorry, I made a mistake - Just the dll - I will post it in one minute
VicMoore 755 Posted March 28, 2023 Author Posted March 28, 2023 the dll is attached below Emby.Bulky.dll 1
MBSki 1115 Posted March 28, 2023 Posted March 28, 2023 9 minutes ago, VicMoore said: the dll is attached below Emby.Bulky.dll 240.5 kB · 0 downloads Awesome, thanks!
rbjtech 5341 Posted March 28, 2023 Posted March 28, 2023 (edited) 1 hour ago, VicMoore said: the dll is attached below Emby.Bulky.dll 240.5 kB · 0 downloads Excited to try this Well done Vic (and assistance from Cheese (aka Dave..) Nice - Do you want feedback on just the viewing and basic editing layout - ie compare to the web version at this stage ? Installing the DLL Copy the DLL from above (you may need to 'allow/accept' the DLL download if your OS is preventing the download) and put it in the main PROGRAMDATA plugins folder in Emby - ie ..\programdata\plugins Do not put it in ..\system\plugins Then restart the emby server The Plugin itself should be in the 'Plugins' folder (green below) and there is also a shortcut to it. (Grey below). Edited March 28, 2023 by rbjtech 1
GrimReaper 4896 Posted March 28, 2023 Posted March 28, 2023 Vic, I've recommended dll post in order for it to be more visible/gain more testers/feedback. 1 1
MBSki 1115 Posted March 28, 2023 Posted March 28, 2023 @VicMoore The plug-in is working well, but I can't seem to select multiple folders. I can select all, or select individual items at the lowest level, but I can't select multiple folders. I thought CTRL+Select was the way to select multiple items, but it isn't working as far as i can tell. A filter would be extremely helpful too.
Eigeplackter 92 Posted March 28, 2023 Posted March 28, 2023 (edited) You mean like mark n folders in a row ? Edited March 28, 2023 by Eigeplackter
VicMoore 755 Posted March 28, 2023 Author Posted March 28, 2023 @rbjtechI want feedback and bug reports. This is our first stab at a plugin. I want to get this piece of code debugged before adding more functionality Vic 1
MBSki 1115 Posted March 28, 2023 Posted March 28, 2023 1 minute ago, Eigeplackter said: You mean like mark n folders in a row ? Yes, I want to select folders or tv shows. I can only multi-select the lowest sub-items.
VicMoore 755 Posted March 28, 2023 Author Posted March 28, 2023 @MBSkiyou are right - I will fix the problem with selecting multiple folders Vic 1
VicMoore 755 Posted March 28, 2023 Author Posted March 28, 2023 I will post the select folder fix in about 30 min
Cheesegeezer 3106 Posted March 28, 2023 Posted March 28, 2023 Please post bugs, UI issues, functionality issues and feature requests. the bugs and issues are a priority and feature requests will be subject to review. @VicMoorei would actually start a new thread in the plugins area. a format something akin to this chief! https://emby.media/community/index.php?/topic/116062-security-cams-channel-plugin/ we can then add a help and bug link in the Config UI to let people know where to go if they have issues. 2 1
VicMoore 755 Posted March 28, 2023 Author Posted March 28, 2023 The latest plugin code is attached below - please let me know about any bugs or suggestions Vic Emby.Bulky.dll
MBSki 1115 Posted March 28, 2023 Posted March 28, 2023 15 minutes ago, VicMoore said: The latest plugin code is attached below - please let me know about any bugs or suggestions Vic Emby.Bulky.dll 241 kB · 0 downloads I think this is the same dll. It doesn't appear to be fixed and the timestamp is the same.
rbjtech 5341 Posted March 28, 2023 Posted March 28, 2023 Hi @VicMoore- I'm sure Cheese had advised this - but I'd recommend incrementing the build version each time you do a release (even minor). You don't actually need to install it to see the version either I would also start a new thread in the Plugins area for this as suggested by Cheese. 1
VicMoore 755 Posted March 28, 2023 Author Posted March 28, 2023 This is the latest plugin - i changed the version number - let me know if it works vic Emby.Bulky.dll 1
rbjtech 5341 Posted March 28, 2023 Posted March 28, 2023 4 minutes ago, VicMoore said: This is the latest plugin - i changed the version number - let me know if it works vic Emby.Bulky.dll 241 kB · 0 downloads Yep - perfect - this is 0.0.0.9 1
