VicMoore 755 Posted March 3, 2023 Author Posted March 3, 2023 hello rbjtech... could you help me get started. If I could just get going with a basic plugin, I think I could do everything else. Is it possible to use javascript in a plugin, like its used in nodejs? Or, do I need to learn C#? Vic
rbjtech 5341 Posted March 3, 2023 Posted March 3, 2023 2 minutes ago, VicMoore said: hello rbjtech... could you help me get started. If I could just get going with a basic plugin, I think I could do everything else. Is it possible to use javascript in a plugin, like its used in nodejs? Or, do I need to learn C#? Vic Hi Vic, I'm really not the best person to ask here as I'm just adding to existing code via VS (cloned from Github) - but JS in a plugin is definitely an option. If you are using Emby API's (which I presume you are) then it should translate reasonably well into the Emby Plugin framework. Have a reach out to @Cheesegeezer or @chef is my advice. I've not delved into the new Emby SDK, but cloning a public repo from Cheese or Chef might be a good indication on what's needed. 1
Gascogne 0 Posted March 4, 2023 Posted March 4, 2023 (edited) I can not login to server, but everything is correct with login data. Only response is failed... Ok, my failure, seeminling it is not allowed to be logged in to the emby server too... Edited March 4, 2023 by Gascogne
Eigeplackter 92 Posted March 4, 2023 Posted March 4, 2023 2 hours ago, Gascogne said: I can not login to server, but everything is correct with login data. Only response is failed... Ok, my failure, seeminling it is not allowed to be logged in to the emby server too... Why shoudln't you be allowed to be logged in parallel ? Im right now logged into 7 emby devices with the same user (incl. Emby Tool). Emby Tool counts toward your device limit, but that's kinda hard to reach. Only thing I could think of, would be if that user is limited to 1 stream, mine is set to unlimited iirc thats default.
VicMoore 755 Posted March 4, 2023 Author Posted March 4, 2023 I will be home tomorrow and can answer your posts then. Vic
Lookatyou 0 Posted March 8, 2023 Posted March 8, 2023 Hello @VicMoore You kept doing a great job on this, Would you please add custom rating in bulk edit too? I am managing my music library and i would like to set "Approved" as Custom Rating for the non-explicit ones. Thanks a lot for this
VicMoore 755 Posted March 8, 2023 Author Posted March 8, 2023 Good morning LookAtYou. Yes I will look into adding it this week. Vic
VicMoore 755 Posted March 8, 2023 Author Posted March 8, 2023 Gascogne, were you able to sign on? Vic
rbjtech 5341 Posted March 8, 2023 Posted March 8, 2023 (edited) btw Vic @VicMoore - Quick Tip - use the @ sign before the name and people will get alerted to your response/request - ie @Lookatyou rather than just Lookatyou .. Edited March 8, 2023 by rbjtech
dee101 0 Posted March 8, 2023 Posted March 8, 2023 Hello, @VicMoore, I'm looking to try out your Emby tool, it looks amazing but for some reason my sign in won't take. I have no idea what I'm doing wrong, my username and password is correct and as far as I can see in my settings, the server IP and port is correct. There is no indication as to which one is incorrect. I've retried about 10 times! Help lol Edit: I'm thinking I'm entering the IP wrong, do you include the http:// and the 4-digit port number at the end of it?
VicMoore 755 Posted March 8, 2023 Author Posted March 8, 2023 Hello dee101... I am here to help Before you try to sign on, press the F12 key to bring up the browser console. Then sign on and copy the contents of the console and send it to me. This way I can see what's happening. Keep in mind that the tool is only tested on Edge and Chrome browsers. Vic
VicMoore 755 Posted March 8, 2023 Author Posted March 8, 2023 @rbjtech thanks so much for this tip. I have wondered for some time about how this is done. You have taught me a new trick and that made my day. Vic 2
VicMoore 755 Posted March 8, 2023 Author Posted March 8, 2023 (edited) @dee101you enter the servers ip address without a port. You can also leave off the http://. You enter the port in the text field below the server ip. Vic Edited March 8, 2023 by VicMoore
dee101 0 Posted March 8, 2023 Posted March 8, 2023 1 hour ago, VicMoore said: @dee101you enter the servers ip address without a port. You can also leave off the http://. You enter the port in the text field below the server ip. Vic Ah, that worked! I was adding the http lol. Thank you @VicMoore I look forward to trying this out! Thank you for your help! I'll let you know how I go
VicMoore 755 Posted March 8, 2023 Author Posted March 8, 2023 (edited) @LookatyouTry out the new GUI code attached below. With it "Custom Rating" can be edited in bulk edit. Vic New_GUI_2.zip Edited March 8, 2023 by VicMoore
dee101 0 Posted March 9, 2023 Posted March 9, 2023 It works great! Thank you for this tool! I can now add tags to multiple files. It's probably been requested already but is there a way we can add 5-star ratings to music files? I used that alot in MusicBee and made smart playlists for 4-5 star rated songs. Could you add that or is there is a way to add them some other way? Someone said to use tags instead and number them, but I would prefer something more visual.
dee101 0 Posted March 10, 2023 Posted March 10, 2023 22 hours ago, VicMoore said: @dee101let me think about it... Vic Great. Thanks for considering it
seanbuff 1356 Posted March 10, 2023 Posted March 10, 2023 Hey @VicMoore just wanted to drop you a quick note to say thanks, love your tool it has saved me many hours thanks to the ability to bulk update. Just wanted to make you aware of a minor typo, when it connects as a new device, it is spelled 'Chhrome' in 'tool.js' function upload_signon(url) { let h = new Headers(); h.append('Accept','application/json, text/plain, */*'); h.append('Content-type', 'application/json; charset=UTF-8'); h.append('X-Emby-Authorization', 'MediaBrowser Client="EmbyTool", Device="Chhrome", DeviceId="12121212-1212-1212-12121212121212121", Version="1.0.0.0"'); console.log("=== Sign On = ",url); Keep up the great work!
mixXxim 2 Posted March 10, 2023 Posted March 10, 2023 On 2/10/2023 at 4:18 PM, mixXxim said: Hi @VicMoore Thank you for the explanation. can you please take a look at these wishes, thank you Hi @VicMoore, many thanks for the new gui. Certainly a lot of work. May I draw your attention to my request again
Junglejim 385 Posted March 12, 2023 Posted March 12, 2023 Nice work with the new GUI update Vic.. Good luck with your plugin dev ambitions too.
VicMoore 755 Posted March 12, 2023 Author Posted March 12, 2023 @seanbuffthanks for pointing out this error. I would have never found it. Vic
VicMoore 755 Posted March 12, 2023 Author Posted March 12, 2023 Hello @Junglejim, it's always nice to hear from you. I am working hard on the plugin, and it is a struggle. I am learning C# and lots of Emby things. I don't know if I am up to the task. Vic
VicMoore 755 Posted March 12, 2023 Author Posted March 12, 2023 Hello @mixXxim, I hope to circle back soon and implements more requests. Right now I am saturated with trying to make a plugin. Vic
mixXxim 2 Posted March 13, 2023 Posted March 13, 2023 @VicMoore Thanks, no rush and looking forward to the new plugin from you, great
