VicMoore 755 Posted January 30, 2023 Author Posted January 30, 2023 Sounds like something went wrong. Try again and this time press F12 to bring up the browser console. Check to see if there is a red error message. Send me a copy of the console. Vic
pmac 143 Posted January 30, 2023 Posted January 30, 2023 39 minutes ago, VicMoore said: Sounds like something went wrong. Try again and this time press F12 to bring up the browser console. Check to see if there is a red error message. Send me a copy of the console. Vic
AJAYSWebDesign 5 Posted January 31, 2023 Posted January 31, 2023 Hi Vic, I contacted you before Christmas regarding an bulk metadata import add-on to your project. I can see you're pretty busy with other changes/upgrades. If you can produce a page like the attached pdf I could then import into excel (including the code) , link up the metadata I want to add then save back in the exact/same format (html or js) which could then be saved using your tool, effectively importing to EMBY..... If you're focused elsewhere, I understand, just thought the attached might not be too difficult/a stretch...... Cheers, Andy EMBY Metadata.pdf
VicMoore 755 Posted January 31, 2023 Author Posted January 31, 2023 Pmac, please replace your copy of "custom_filter.js" with the attached file. This should fix your problem. Please let me know if it works. Vic custom_filter.js
VicMoore 755 Posted January 31, 2023 Author Posted January 31, 2023 AjaysWebDesign... I will look into your request and let you know tomorrow or the next day. Vic
pmac 143 Posted January 31, 2023 Posted January 31, 2023 49 minutes ago, VicMoore said: Pmac, please replace your copy of "custom_filter.js" with the attached file. This should fix your problem. Please let me know if it works. Vic custom_filter.js 29.4 kB · 1 download That fixed it, thanks!
VicMoore 755 Posted January 31, 2023 Author Posted January 31, 2023 The latest code is attached below. Vic tool_3.0.zip
pmac 143 Posted January 31, 2023 Posted January 31, 2023 (edited) @VicMoore, I seem to be running into another issue now; I'm able to filter movies correctly with the custom filter, but when I try to select them with "shift-click" it seems to be selecting all of the movies (including the ones that aren't currently displayed due to the filter), because when I click on bulk edit and apply a tag, it applies the tag to my entire movie library, and not just the movies within the custom filter. Edit: I just tested it again by creating a custom filter that would only display one movie and then "shift-clicked" it. I then clicked "bulk edit" and added a tag. The tag was applied to my entire movie collection, not just the movie that was displayed with the filter applied. Edited January 31, 2023 by pmac
VicMoore 755 Posted January 31, 2023 Author Posted January 31, 2023 (edited) Thanks for pointing this out. I know what the problem is and will fix it tomorrow. The problem is that I didn't put back in some code that I removed a few days ago when I was testing other features. I got busy with other things and just forgot. Vic Edited January 31, 2023 by VicMoore 1
VicMoore 755 Posted January 31, 2023 Author Posted January 31, 2023 Pmac... I fixed the problem... Give it a try and let me know if it works OK. I appreciate you pointing problems out to me. I don't have much time for testing. Vic tool_3.1.zip
Eigeplackter 92 Posted January 31, 2023 Posted January 31, 2023 Hi Vic, just had a test with 3.1 and following 3 feature requests: - Display password as asterisk instead of plain text (If you demontrate something just so people dont see your pw, no need to hash),.Cosmetics. - If I bulk edit lots of new movies, i.e. add FullHD tag, the page reloads without earlier applied filters, idk if intended - When editing single files, you have the option to save, next, previous and cancel. However next is only good if you dont want to edit single entries, as the usage of save will return to prior list, again w/o filters. How about an "save and next" button, that keeps the earlier filtered list ? Explanation: I'm using the Iconic Image Enhancer, and while bulk tagging resolution is easy, the sound format incl. no. of channels, is not, as it only shows DTS, Dolby Digital (Plus) but not the number of channels. Therefore I have to manually add tags to single files, which is a bit cumbersome when you have to reapply filters after every single item.
VicMoore 755 Posted January 31, 2023 Author Posted January 31, 2023 Good morning Eigeplackter... 1) You are right about the save button. I will fix it today so that when you save it doesn't exit if you have multiple files. I will also add a return button. 2) I will make the password field asterisks - great idea 3) please give me more detail on your second idea ("if I bulk edit lots of new movies") 4) The DTS,Dolby Digital (Plus) is what the Emby object provides. I will look again for "Number of Channels" As always, great ideas. I will fix things today Vic
pmac 143 Posted January 31, 2023 Posted January 31, 2023 9 hours ago, VicMoore said: Pmac... I fixed the problem... Give it a try and let me know if it works OK. I appreciate you pointing problems out to me. I don't have much time for testing. Vic tool_3.1.zip 217.79 kB · 1 download Perfect, thanks!
VicMoore 755 Posted January 31, 2023 Author Posted January 31, 2023 Pmac, the thanks go to you. You found important things that needed to be fixed. Thanks again, Vic 1
VicMoore 755 Posted January 31, 2023 Author Posted January 31, 2023 Eigeplackter The editor save button function and the password field are fixed. Vic tool_3.2.zip
pmac 143 Posted January 31, 2023 Posted January 31, 2023 @VicMoore, is there a way we could have an option to filter based on whether the item has a tag or not? As in "Has Tag(s) = TRUE / Has Tag(s) = FALSE" I'm trying to add fairly fine-grained organization based on tags, but it would be nice to be able to check whether I've missed any titles, as well as filtering by "Has Tag(s) = FALSE" would allow me to easily find any new items that I may not have got around to tagging yet. Thanks
VicMoore 755 Posted January 31, 2023 Author Posted January 31, 2023 Pmac, you can do that now in the standard filter: Vic 1
pmac 143 Posted January 31, 2023 Posted January 31, 2023 3 minutes ago, VicMoore said: Pmac, you can do that now in the standard filter: Vic Thanks, somehow I'd missed that!
Eigeplackter 92 Posted January 31, 2023 Posted January 31, 2023 (edited) 3 hours ago, VicMoore said: Good morning Eigeplackter... ... 3) please give me more detail on your second idea ("if I bulk edit lots of new movies") 4) The DTS,Dolby Digital (Plus) is what the Emby object provides. I will look again for "Number of Channels" ... Thank you Vic for the quick fix. Save button works fine ! To answer your question: I'm too lazy to tag every single file I backup to disk. so I come back someday, when I'm in the mood, filter for "Date added" and "Descending" and start tagging (magnified): As you can see it's quite easy to bulk edit those 4 movies with tag "FullHD 1080p", and obviously I could tag em with "Dolby" and "DTS". But that's just me, I tag the sound with "DTS x.x" and "Dolby Digital x.x". I doubt this is something you have to fix, it's just that the iconic image enhancer @roakudoes not offer Images depending on channels. But therefore I can now utilize the save button and do it one by one w/o reapplying filters. Thanks again. Edited January 31, 2023 by Eigeplackter
roaku 842 Posted January 31, 2023 Posted January 31, 2023 15 minutes ago, Eigeplackter said: iconic image enhancer @roakudoes not offer Images depending on channels. You should be able to do this with a MediaStream rule and the ChannelLayout property. If you need more help, please ask in the Iconic support thread. 1
pmac 143 Posted January 31, 2023 Posted January 31, 2023 (edited) Thanks again for your work on this tool @VicMoore, I've only used it for a couple of days, but it's already come in very handy for me. I have one request, though I'm not sure exactly how it would be handled in the UI... It would be very helpful to me if there were a way to filter and select (for bulk edit) multiple episodes across my entire TV collection. I'd like to be able to somehow select all EPISODES that contain a certain term in their filename, regardless of which show/season they're from. The tool would need a method of searching an entire library, including inside subfolders (show/season folders) from within the root library folder. Currently, to edit episodes they need to be selected/filtered from within the season folder, which makes it a very slow process if I'd like to apply tags to my entire television library (I'd need to go through each individual season folder, one at a time - add custom filter - edit/add tag to filtered episodes - repeat on next season, and then next show, etc.). I hope I'm being clear enough; it's kind of difficult to describe what I mean exactly. Edit: I know there's a recursive search option, but this option doesn't exist for custom filters. Edited January 31, 2023 by pmac
Ninko 78 Posted January 31, 2023 Posted January 31, 2023 When doing a custom filter on TV shows, framerate says undefined, and nothing happens if I try to filter, for example 30fps? Also, the prev and next buttons don't appear to do anything?
VicMoore 755 Posted February 1, 2023 Author Posted February 1, 2023 Pmac... You can select multiple TV series (use ctl-click because they are folders) and then bulk edit them to add tags. I do this all the time for virtualTV. I select all of the TV series that I want to see on channel 1 and then bulk edit them to add the tag "channel-1". I also do this to remove "played" from all of the series. Vic
pmac 143 Posted February 1, 2023 Posted February 1, 2023 14 hours ago, VicMoore said: Pmac... You can select multiple TV series (use ctl-click because they are folders) and then bulk edit them to add tags. I do this all the time for virtualTV. I select all of the TV series that I want to see on channel 1 and then bulk edit them to add the tag "channel-1". I also do this to remove "played" from all of the series. Vic Can I use this method to apply a custom filter at the episode-level? I don't want to tag series, or seasons - just individual episodes. I'm trying to bulk tag the audio/video codecs on individual episodes.
