VicMoore 755 Posted January 15, 2023 Author Posted January 15, 2023 Hello Ninko.. You can filter on "Studio" names with the standard filter. You can filter on frame rate with the new custom filter. Vic
Ninko 78 Posted January 15, 2023 Posted January 15, 2023 @VicMoore, how do you select a folder to tag, instead of an item? Thanks
VicMoore 755 Posted January 15, 2023 Author Posted January 15, 2023 Ninko, press "ctl" then click the folder vic
Ninko 78 Posted January 15, 2023 Posted January 15, 2023 (edited) Ahhh I see. Can it not be done on an Android device then? Also, searching for a tag doesn't seem to pick up a folder having that tag, plus the tag doesn't show up below the folder image like it does under a file image. Thanks Edited January 15, 2023 by Ninko
neik 874 Posted January 15, 2023 Posted January 15, 2023 The progress you make daily is quite impressive. Any chance the subtitle filtering can be added to the custom filter you developed?
VicMoore 755 Posted January 15, 2023 Author Posted January 15, 2023 Hello Neik... I would think so. What do you want to filter? Vic
neik 874 Posted January 15, 2023 Posted January 15, 2023 2 minutes ago, VicMoore said: Hello Neik... I would think so. What do you want to filter? Vic My usecase would be to identify files on specific subtitle language and then tag them.
VicMoore 755 Posted January 15, 2023 Author Posted January 15, 2023 OK, the filter has the info, but its not yet displayed. I will work on it tomorrow. vic 1
Ninko 78 Posted January 15, 2023 Posted January 15, 2023 39 minutes ago, Ninko said: Ahhh I see. Can it not be done on an Android device then? Also, searching for a tag doesn't seem to pick up a folder having that tag, plus the tag doesn't show up below the folder image like it does under a file image. Thanks Did you miss my message @VicMoore? Thanks
VicMoore 755 Posted January 15, 2023 Author Posted January 15, 2023 Sorry for being vague. I got your message. You want to filter on codec language. I will try and do it tomorrow. vic
VicMoore 755 Posted January 15, 2023 Author Posted January 15, 2023 I will also look into the problem with tags that you reported. vic
Ninko 78 Posted January 15, 2023 Posted January 15, 2023 Huh? I think you're referring to someone else here lol.
VicMoore 755 Posted January 15, 2023 Author Posted January 15, 2023 Sorry Ninko. I got names mixed up. I will look into the tag problem ASAP vic 1
VicMoore 755 Posted January 16, 2023 Author Posted January 16, 2023 Good morning Neik.. to filter for the French language go to the custom tool and check the "One or more must match" radio button. then select the operator "contains" and enter "french" (not case sensitive) in the value field. When you click apply the folder will be search for media with French codecs. The code is attached below. I am relying on you to test this feature. Let me know how it goes. For me it worked fine. vic tool_2.4b.zip 1
Guest Posted January 16, 2023 Posted January 16, 2023 Hi @VicMoore - is it possible to find and replace tags in this tool? For instance, if I wanted to find all items in my library (movies and TV) that had the tag "Tag1" and remove "Tag1" and replace it with "Tag2" for all items? Thank you for the continued work you do on this program!
neik 874 Posted January 16, 2023 Posted January 16, 2023 1 hour ago, VicMoore said: I am relying on you to test this feature. Let me know how it goes. For me it worked fine. Thank you, Vic. I will come back to you after having a look at it, maybe today evening.
VicMoore 755 Posted January 16, 2023 Author Posted January 16, 2023 (edited) Hello Eigeplackter... The problem you were having with running out of resources was being caused by the tool sending many requests at one time and overloading the browser. I fixed the problem, but it required a lot of code changes. So test the bulk save and let me know if it works ok. For me it works fine. vic tool_2.5.zip Edited January 16, 2023 by VicMoore 1
VicMoore 755 Posted January 16, 2023 Author Posted January 16, 2023 (edited) hello Notuxnobux... Yes you can replace tags with the bulk editor, but it's done in two steps. First remove the old tag, and then add the new tag. vic Edited January 16, 2023 by VicMoore
mixXxim 2 Posted January 16, 2023 Posted January 16, 2023 Thanks for the new function of the custom filter. I just tested the "lock" "unlock" function. In doing so, I noticed that the number of filtered files above is not updated. With the "lock" "unlock" function, there is only true or false. <,>S,E,C, I don't understand. I would still understand "not equal". Many Thanks
VicMoore 755 Posted January 16, 2023 Author Posted January 16, 2023 mixXxim, you are right that for locks only the equals makes sense. I didn't want to create custom pulldowns for every situation. When the custom filter is proved to be working correctly then I will go back and make the GUI better. Vic 1
VicMoore 755 Posted January 16, 2023 Author Posted January 16, 2023 By the way. Do the locks work as you expected in the custom filter. I didn't test them. vic
mixXxim 2 Posted January 16, 2023 Posted January 16, 2023 Yes, the "lock" "unlock" function works really well. Many Thanks I would like to draw your attention again to the update of the number of filtered files. liebe Grüße mixXxim
Eigeplackter 92 Posted January 16, 2023 Posted January 16, 2023 18 minutes ago, VicMoore said: Hello Eigeplackter... The problem you were having with running out of resources was being caused by the tool sending many requests at one time and overloading the browser. I fixed the problem, but it required a lot of code changes. So test the bulk save and let me know if it works ok. For me it works fine. vic tool_2.5.zip 5.48 MB · 1 download It ran allright, all files handled, at least it didn't report an error. But when i go back to main screen, reload tool, and reenter the BULK-Playlist I find some of the tags still existing: So I made a second run, this time just CBS (capitals) And this one wouldn't end at all (check messages 41k !) Out of a sudden the site refreshed, and the scipt started at 0% again, but caught up pretty quicly, now touching 60%. Why did the 1st run finish with 11k messages and now we are pushing 80k at like 70% ?
VicMoore 755 Posted January 16, 2023 Author Posted January 16, 2023 1 hour ago, mixXxim said: Thanks for the new function of the custom filter. I just tested the "lock" "unlock" function. In doing so, I noticed that the number of filtered files above is not updated. With the "lock" "unlock" function, there is only true or false. <,>S,E,C, I don't understand. I would still understand "not equal". Many Thanks the '7' is giving the number of media items in the 'test' folder. It's not related to the filter search results. Vic
neik 874 Posted January 16, 2023 Posted January 16, 2023 8 hours ago, VicMoore said: Good morning Neik.. to filter for the French language go to the custom tool and check the "One or more must match" radio button. then select the operator "contains" and enter "french" (not case sensitive) in the value field. When you click apply the folder will be search for media with French codecs. The code is attached below. I am relying on you to test this feature. Let me know how it goes. For me it worked fine. vic Hey Vic, I just had a look at this and I was able to filter some of my files. Currently "only" six different "codecs" are being considered/checked but some of my files have the subtitles at position 7 or more, e.g.: - Codec 0: Video - Codec 1: English (DTS-HD) - Codec 2: German (DTS-HD) - Codec 3: English (DTS core - for compatibilty) - Codec 4: German (DTS core - for compatibilty) - Codec 5: German (Forced) - Codec 6: German (SDH) - Codec 7: English (Forced) - Codec 8: English (SDH) .... As you see this can go on and on. Would it be possible to have a filter that goes through all available codecs instead of having to filter one by one as it is now?
