VicMoore 755 Posted January 4, 2023 Author Posted January 4, 2023 Shioku, I will fix it tomorrow. Vic
VicMoore 755 Posted January 4, 2023 Author Posted January 4, 2023 Hello Eigeplackter... You are the first to ask for a filter on audio codecs. Tomorrow, I will look into adding this filter. Vic 1
VicMoore 755 Posted January 4, 2023 Author Posted January 4, 2023 Hello LookAtYou... I will look into a filter on custom parental ratings. Vic
VicMoore 755 Posted January 4, 2023 Author Posted January 4, 2023 Hello AlessioP... I totally forgot to add the add IT-T , IT-6+ , IT-14+ , IT-18+ I will do it tomorrow. Vic
VicMoore 755 Posted January 4, 2023 Author Posted January 4, 2023 For the moment I am frozen out of Swagger so I can't look at the Emby API anymore. It's the CORS problem. I can't get an https certificate because my ISP blocks port 80 and 443. I am running on Synology and require these ports to validate that I control my domain name. Vic
VicMoore 755 Posted January 4, 2023 Author Posted January 4, 2023 Shioku, the "has Tags" is fixed. Thanks for pointing out that it was not working. AlessioP, I added the ratings you provided. Please check them out to see if it's correct. Vic tool_2.1.zip
VicMoore 755 Posted January 4, 2023 Author Posted January 4, 2023 Good morning Happy2Play... It's always nice to hear from you. I have not tried out Browser flags. I didn't even know they existed. How would I use them? Vic
AJAYSWebDesign 5 Posted January 4, 2023 Posted January 4, 2023 On 03/01/2023 at 02:35, VicMoore said: Hello Andy... Thank you for the kind words. Yes, it is possible to import bulk meta data. The problem at the moment is that it's a big job and I don't have the time to do it. Perhaps later in the year I can revisit your request. In the meantime, I would like to better understand what you want. If you have time, please tell me how you would like to add bulk meta data and what kind of data do you have in mind. Vic Hi Vic, I've attached an excel file with example of data to upload - (field names may not be 100% accurate - but you'll get my drift)..... EMBY metadata upload example.xlsx
Happy2Play 9811 Posted January 5, 2023 Posted January 5, 2023 10 hours ago, VicMoore said: Good morning Happy2Play... It's always nice to hear from you. I have not tried out Browser flags. I didn't even know they existed. How would I use them? Vic The option exempts the address you add per the image so CORS will not affect that link allowing Swagger to work in that browser. Not requiring a HTTPS connection.
VicMoore 755 Posted January 5, 2023 Author Posted January 5, 2023 Happy2Play, you are so smart -- that worked perfectly...Thanks for teaching me a new trick Vic
VicMoore 755 Posted January 5, 2023 Author Posted January 5, 2023 (edited) Thanks to Happy2play, you can now filter on audio codecs Vic tool_2.1a.zip Edited January 5, 2023 by VicMoore 1 1
Eigeplackter 92 Posted January 5, 2023 Posted January 5, 2023 11 minutes ago, VicMoore said: Thanks to Happy2play, you can now search on audio codecs Vic tool_2.1a.zip 5.46 MB · 0 downloads Thanks for adding the option, but it's not showing any results for me ? Even though there should be content:
VicMoore 755 Posted January 5, 2023 Author Posted January 5, 2023 Thanks Eigeplackter for testing the audio codec filter. I will look into why you are not getting any results ASAP. I don't actually do the filtering. It's done within the Emby server. I must be passing it the wrong information. Vic
Eigeplackter 92 Posted January 5, 2023 Posted January 5, 2023 No rush Vic, appreciate your work and can wait if you ate out of time.
VicMoore 755 Posted January 5, 2023 Author Posted January 5, 2023 Eigeplackter, give this code a try. It works for me. Vic tool_2.1b.zip
Eigeplackter 92 Posted January 5, 2023 Posted January 5, 2023 No sorry to report, no change in beaviour for me. Tried DTS and DTSHD and DTSHD-MA, cuz that's in the actual filename: Additionally the letter index on the right is not working for me, whichever letter I choose, I land at B
VicMoore 755 Posted January 5, 2023 Author Posted January 5, 2023 What is the name of the audio codec given in Emby? Vic
Eigeplackter 92 Posted January 5, 2023 Posted January 5, 2023 1 hour ago, Eigeplackter said: Thanks for adding the option, but it's not showing any results for me ? Even though there should be content: DTS is the output emby is showing me for that file. imho we could go for embedded track or title, would just like to tag all with a correct audio tag, as emby only seems to recognize the codec as DTS Even though there is DTS,DTS-EX,DTS-X,DTSHD-MA,…
VicMoore 755 Posted January 5, 2023 Author Posted January 5, 2023 (edited) Eigeplackter, I added video codec and audio codec to the editor panel for easy reference, so you can see what Emby thinks the codecs are. This should help debugging. Vic tool_2.1d.zip Edited January 6, 2023 by VicMoore 1 1
kezzawd 0 Posted January 6, 2023 Posted January 6, 2023 Can I just say a big thank you - the ability to bulk edit tags is just what I was after to help manage available content for our grand kids - awesome job !
Eigeplackter 92 Posted January 6, 2023 Posted January 6, 2023 8 hours ago, VicMoore said: Eigeplackter, I added video codec and audio codec to the editor panel for easy reference, so you can see what Emby thinks the codecs are. This should help debugging. Vic tool_2.1d.zip 5.46 MB · 0 downloads Yeah so the output in editor says: But no matter which info I add in the codec field: UHD HDR10 Remux GERMAN DTS-HD MA 5.1 GERMAN DTS-HD MA 5.1 (Default) German DTS 5.1 DTS Result is still 0 Movies after applying the filter. I'm regulary using latest Chrome as browser but tried Edge as well. PS: Does it have to match exactly, or should searching for "DTS" be sufficient to get all entries, no matter if DTS-HD or else.
VicMoore 755 Posted January 6, 2023 Author Posted January 6, 2023 Good morning Eigeplackter, I will dig into the code today and try to figure out why it works for me but not you. Do you have a very short video you can send me to test? vic
VicMoore 755 Posted January 6, 2023 Author Posted January 6, 2023 Hello Kezzawd... Thank you for the kind words. Vic
Eigeplackter 92 Posted January 6, 2023 Posted January 6, 2023 29 minutes ago, VicMoore said: Good morning Eigeplackter, I will dig into the code today and try to figure out why it works for me but not you. Do you have a very short video you can send me to test? vic Hey Vic, define "very short"
