VicMoore 755 Posted December 7, 2022 Author Posted December 7, 2022 (edited) CBers, I can add an option to save credentials on your browser. It will try to get it done this week. Vic Edited December 7, 2022 by VicMoore
VicMoore 755 Posted December 7, 2022 Author Posted December 7, 2022 To select all of the shows within a TV series do the following 1) select the TV series 2) select filter and set the filters as follows: 3) click on APPLY 4) this displays all of the TV shows under the selected TV series, including the TV series folder. 5) shift click to select all of the displayed shows 6) to remove the TV series folder from the selected items, just ctl click on it 7) now you have all of the TV shows selected and you can bulk edit them
VicMoore 755 Posted December 7, 2022 Author Posted December 7, 2022 (edited) I had a few moments to program: 1) added the save sign-on requested by CBers 2) improved IPTV streaming for hard to play channels like Pluto TV Vic tool_2.0d.zip Edited December 7, 2022 by VicMoore 2
Junglejim 385 Posted December 8, 2022 Posted December 8, 2022 (edited) On 07/12/2022 at 23:34, VicMoore said: JungleJim, I will look into adding that button back. Tell me what you want it to do. Vic Thanks mate for considering it. As far as what it does (I never used it in previous versions), maybe just keep adding items till your ready to bulk edit them all? Obviously I'm not sure how that would work or if even if it's possible. @Happy2Play provided me with a nice option for selecting certain tvshows (eg: Star Trek) by filtering the library with a search string, then shift select them all for a bulk edit. The "add item" would be useful for selecting different tvshows and bulk adding tags/genres. Cheers. Edit: I just had another idea, what if you add another key combo to just select the tvshow (ctrl+shift+select) instead of going to the metadata editor or drilling down to seasons/episodes? Not sure if it's possible.. just throwing ideas at ya. Edited December 9, 2022 by Junglejim
alessioP 2 Posted December 12, 2022 Posted December 12, 2022 Hi VicMoore, in the past I modified your HTML script to add Italian categories in the parental rating but I'm not familiar with Js so I'm asking your help. Is it possible to add the below list? IT-T , IT-6+ , IT-14+ , IT-18+ Thanks for the help
Super957 24 Posted December 14, 2022 Posted December 14, 2022 (edited) Sry for little clarification... I have a lot of movies (850) with genre 1080p.... So i want delete this generes in all 850 movies.... i try selecting filter with genre 1080p and after select all movie...but to delete all movie genre 1080p in which way i can proceed? I try: select all movies with genre 1080p i go in edit and delete 1080p and save.. but in this way i delete the tag only in one movie (the first) Thank Hispa Edited December 14, 2022 by Super957
VicMoore 755 Posted December 14, 2022 Author Posted December 14, 2022 Hello Allessio, yes I will add them in Vic
VicMoore 755 Posted December 14, 2022 Author Posted December 14, 2022 Super957, I will help you later tonight. Sorry for the delay. Vic 1
Super957 24 Posted December 15, 2022 Posted December 15, 2022 (edited) 22 hours ago, VicMoore said: Super957, I will help you later tonight. Sorry for the delay. Vic PLS refer my previous post...how i can delete all movies (with genre 1080p made by me) selecting all movies with this genre ?? I select all movies with 1080p genre with Shift-Click to select all files ... i try selct bulk but at this point i dont know in which way delete for all selected movis the specific genre "1080p"... Thank Hispa Edited December 15, 2022 by Super957
Roodee 39 Posted December 16, 2022 Posted December 16, 2022 On 12/15/2022 at 3:54 PM, Super957 said: PLS refer my previous post...how i can delete all movies (with genre 1080p made by me) selecting all movies with this genre ?? I select all movies with 1080p genre with Shift-Click to select all files ... i try selct bulk but at this point i dont know in which way delete for all selected movis the specific genre "1080p"... Thank Hispa I am not aware that "the tool" is able delete any media. It can set and unset (delete) certain meta-information of the media, and it can do that in bulk for a selection of media. But Emby itself can delete media. You have tagged all you want to delete with "1080p"? Go to the Emby Dashboard (home page) and click on "Movies" (or whatever you have called your library that contains the media to be deleted). You should see this: Click on Tags. An overview will open with tiles like this with the tag-name underneath: Click it, it will open an overview of all movies with that specific tag. Click in the upper left hand corner of the first movie to set the check mark: Scroll to the last movie and shift-click the last movie. (Hold the Shift-Key and then click the last movie.) All movies should now receive a check mark. Scroll up a bit and a bar with the number of selected movies shows up. The X will deselect them all, the > would play them all. You need to click on the three dots ... From the menu that drops down, select Delete. That should do what you want. Warning: We are talking about bulk-deletion of media. If you have doubts or did not understand the instructions as I gave them, do not proceed! Cheers, Roodee
Super957 24 Posted December 16, 2022 Posted December 16, 2022 (edited) 2 hours ago, Roodee said: I am not aware that "the tool" is able delete any media. It can set and unset (delete) certain meta-information of the media, and it can do that in bulk for a selection of media. But Emby itself can delete media. You have tagged all you want to delete with "1080p"? Go to the Emby Dashboard (home page) and click on "Movies" (or whatever you have called your library that contains the media to be deleted). You should see this: Click on Tags. An overview will open with tiles like this with the tag-name underneath: Click it, it will open an overview of all movies with that specific tag. Click in the upper left hand corner of the first movie to set the check mark: Scroll to the last movie and shift-click the last movie. (Hold the Shift-Key and then click the last movie.) All movies should now receive a check mark. Scroll up a bit and a bar with the number of selected movies shows up. The X will deselect them all, the > would play them all. You need to click on the three dots ... From the menu that drops down, select Delete. That should do what you want. Warning: We are talking about bulk-deletion of media. If you have doubts or did not understand the instructions as I gave them, do not proceed! Cheers, Roodee Nooo pheraps you dont understand, in this way you delete movies...while i want delete only "genre 1080p" included in this movie Hispa Edited December 16, 2022 by Super957
Roodee 39 Posted December 16, 2022 Posted December 16, 2022 On 12/15/2022 at 3:54 PM, Super957 said: how i can delete all movies (with genre 1080p made by me) 13 minutes ago, Super957 said: in this way you delete movies That's how I understood your question. So, here we go again... Open "the tool". Choose the library you want to "edit", then click Filter: enter the genre to filter by: Click The filter will be applied, you should be able to see a result of 850 movies (as you said). Shift_click on a movie, that will select all 850 movies, then click In the following screen, find this line: Click Add Genre. This will not add a genre. It will open a field in the form to type in a text, and with the drop-down you can choose the action that "the tool" shall then execute with the entered text. Click the drop down and choose "Delete These Genres v". Enter the genre, I assume it is "1080p". So far, no action has been taken, only selection and preparation. To execute the desired action. find the "Save" button and click it. This will take some time, but probably not more than 30 seconds. That should have fixed your problem. Wishing you good luck with this. Cheers, Roodee 1 1
Super957 24 Posted December 16, 2022 Posted December 16, 2022 (edited) I'm very sorry, yes I explained myself badly... Sure you understood now very well and you explained the solution perfectly and clearly. Thank you so much and I wish you a good weekend Edited December 16, 2022 by Super957
VicMoore 755 Posted December 17, 2022 Author Posted December 17, 2022 RooDee you are fantastic. Thanks for the help. Family and Christmas commitments are keeping me busy and away from home. The latest code is attached below. Vic tool_2.0e.zip 1
VicMoore 755 Posted December 22, 2022 Author Posted December 22, 2022 (edited) I corrected the problem with "ctrlKey" selecting folders. Now you can select folders just as in earlier versions. Vic tool_2.0f.zip Edited December 23, 2022 by VicMoore 1
Junglejim 385 Posted December 23, 2022 Posted December 23, 2022 7 hours ago, VicMoore said: I corrected the problem with "ctrlKey" selecting folders. Now you can select folders just as in earlier versions. Vic tool_2.0f.zip 5.43 MB · 1 download Thanks Vic, that works great. 1
EtPvSyno 1 Posted December 25, 2022 Posted December 25, 2022 On 12/7/2022 at 5:52 PM, VicMoore said: I had a few moments to program: 1) added the save sign-on requested by CBers 2) improved IPTV streaming for hard to play channels like Pluto TV Vic tool_2.0d.zip 5.42 MB · 24 downloads Thank You VicMoore ! This will helps a lot for me (I've just tried with a music library - works well !) Etienne
VicMoore 755 Posted December 26, 2022 Author Posted December 26, 2022 Thanks Etienne... I appreciate the kind words Vic
VicMoore 755 Posted December 26, 2022 Author Posted December 26, 2022 The latest code is attached below. I fixed the problem I caused with checkboxes. I fixed one bug and created another. Now both are fixed. Vic tool_2.0g.zip 2
AJAYSWebDesign 5 Posted January 2, 2023 Posted January 2, 2023 Hi Vic, My name is Andy - you helped me before Christmas under my old login AJAYS. I cant access that account - its linked to an old email address that i forgot to update. Anyway - thanks again I've had a bit if a play and for bulk editing it is brilliant. I do however, have a request..... Is there a way to bulk import metadata? I have standard metadata (actors, rating, genre, overview, release date) for well over 500 videos in my library that I'd like to include. Is this possible? Cheers, Andy
VicMoore 755 Posted January 2, 2023 Author Posted January 2, 2023 Hello Andy... Thank you for the kind words. Yes, it is possible to import bulk meta data. The problem at the moment is that it's a big job and I don't have the time to do it. Perhaps later in the year I can revisit your request. In the meantime, I would like to better understand what you want. If you have time, please tell me how you would like to add bulk meta data and what kind of data do you have in mind. Vic
Lookatyou 0 Posted January 3, 2023 Posted January 3, 2023 Hello VicMoore, thanks for the useful tool. I went to use your tool to add parental rating to some of my musics. I have found two features missing for this purpose: "Custom parental rating" as it exists in Emby. Filter/Search by Artist I would appreciate it a lot if you add these features. Thanks.
Shioku 1 Posted January 3, 2023 Posted January 3, 2023 Hi, nice work! is it possible to not only filter for including a Tag but excluding it? Chris
Eigeplackter 92 Posted January 3, 2023 Posted January 3, 2023 (edited) Am I missing the filters for audio codecs / audio in general ? Edited January 3, 2023 by Eigeplackter
Shioku 1 Posted January 3, 2023 Posted January 3, 2023 Hi, the filter for "has tags" seems to be broken in the current version. The one you posted on October 9, 2022 works fine. Chris
