Happy2Play 9811 Posted December 1, 2022 Posted December 1, 2022 5 minutes ago, taravasya said: Hi, @VicMoore ! Can I use this tool for bulk editing a music metadata, like albums, artists? Thanks! No as Emby will read embedded track metadata and does not write it. Yes it writes a nfo file but currently does not read it. All music should be edited outside of Emby with programs like mp3tag and picard or your favorite tagger.
taravasya 0 Posted December 2, 2022 Posted December 2, 2022 (edited) Thanks. So... If I have read-only library source, I have no way to change it metadata? I understood correctly that Emby cant store metadata in database? Edited December 2, 2022 by taravasya
VicMoore 755 Posted December 2, 2022 Author Posted December 2, 2022 (edited) I fixed: 1) a simple filter problem, 2) a typo in the IPTV stream stop URL., 3) keep buttons from scrolling, and 4) gives you the option to not have background images Vic tool_2.0b.zip Edited December 2, 2022 by VicMoore
Junglejim 385 Posted December 4, 2022 Posted December 4, 2022 On 03/12/2022 at 00:15, VicMoore said: I fixed: 1) a simple filter problem, 2) a typo in the IPTV stream stop URL., 3) keep buttons from scrolling, and 4) gives you the option to not have background images Vic tool_2.0b.zip 5.5 MB · 2 downloads Hi @VicMoore, I can't seem to get the bulk edit for tags working with the latest version. I did a bunch of movies and tvshows a few versions back but no luck with 2.0b. 1
VicMoore 755 Posted December 4, 2022 Author Posted December 4, 2022 Thanks JungleJim for letting me know. I probably broke something while fixing something else. I will fix it this morning. Vic
sliceart 0 Posted December 4, 2022 Posted December 4, 2022 I found this tool when I searched for emby delete tags. Although there is no way to delete all tags directly in batches, fortunately you provided the source code, so I can complete my needs by modifying it. Although I Editing was used instead of batch editing. Thank you very much for the tool
Painkiller88 250 Posted December 4, 2022 Posted December 4, 2022 Hi, Another thing i recorgnized. I tried to bulk add a genre and i selected add to existing genres, but when i click save, the new genre is not added. i am using 2.0b thanks
VicMoore 755 Posted December 5, 2022 Author Posted December 5, 2022 Hello JungleJim... I fix the bug you reported. The code is attached below. The problem was the old fix one bug and create another. I made a change to the post code earlier in the week and that change created the problem with bulk saves that you experienced. Please test the code and let me know if everything is now working as you expected. vic tool_2.0c.zip 1
VicMoore 755 Posted December 5, 2022 Author Posted December 5, 2022 (edited) hello painkiller8818.... tool_2.0c will solve your problem. Vic Edited December 5, 2022 by VicMoore 1
VicMoore 755 Posted December 5, 2022 Author Posted December 5, 2022 Hello Sliceart... If you need help adding to the code please let me know. By the way, you can bulk remove all tags or just one tag. Vic
Junglejim 385 Posted December 5, 2022 Posted December 5, 2022 7 hours ago, VicMoore said: Hello JungleJim... I fix the bug you reported. The code is attached below. The problem was the old fix one bug and create another. I made a change to the post code earlier in the week and that change created the problem with bulk saves that you experienced. Please test the code and let me know if everything is now working as you expected. vic tool_2.0c.zip 5.42 MB · 2 downloads @VicMoore Cheers mate that fixed it. Everything is working as expected. Nice work.
Junglejim 385 Posted December 6, 2022 Posted December 6, 2022 Hi @VicMoore, I've got a question. How do you go about selecting multiple tvshows so you can bulk add tags to them? eg: Select all star trek shows and bulk add the tag "Star Trek" It's easy with movies but I just can't figure how to do it with tvshows. Previously I've shift selected all shows, then deselected the ones I don't need but that can get a bit tedious. I'm probably missing something obvious. Cheers.
Happy2Play 9811 Posted December 6, 2022 Posted December 6, 2022 (edited) @Junglejim Have you tried filtering the library with a search string? Only other way I can think of is ctrl click item then select add item, individually adding them one at a time to create your list. Edited December 6, 2022 by Happy2Play 1
Junglejim 385 Posted December 6, 2022 Posted December 6, 2022 (edited) 15 minutes ago, Happy2Play said: @Junglejim Have you tried filtering the library with a search string? Thanks mate that could work, I didn't think of that. Then I could shift select from there and bulk edit away. Will give it a go. Edit: Yep that's the go.. cheers mate! Edited December 6, 2022 by Junglejim
Junglejim 385 Posted December 6, 2022 Posted December 6, 2022 23 minutes ago, Happy2Play said: Only other way I can think of is ctrl click item then select add item, individually adding them one at a time to create your list. This also could be useful but I don't see the "add item". When I ctrl click a tvshow I get to here. Which seems to be a meta editor for that show?
CBers 7554 Posted December 6, 2022 Posted December 6, 2022 It's a while since I used this tool. I remember there being a way of the tool remembering the login details to your server. Can someone remind me please.
CBers 7554 Posted December 6, 2022 Posted December 6, 2022 Trying to BULK update a bunch of movies with TAGS and GENRES, but it doesn't appear to work. Is this a known issue?
Roodee 39 Posted December 6, 2022 Posted December 6, 2022 14 minutes ago, CBers said: Trying to BULK update a bunch of movies with TAGS and GENRES, but it doesn't appear to work. Is this a known issue? Do you have the latest version? I believe a bug fix went into that version. Also, did you change the little drop down? By default it says "Do not save", which could be your problem. 1
CBers 7554 Posted December 6, 2022 Posted December 6, 2022 8 minutes ago, Roodee said: Also, did you change the little drop down? By default it says "Do not save", which could be your problem. Yes, I changed it to Add to existing TAGS/GENRES. I'm running the latest version in post #1.
Roodee 39 Posted December 6, 2022 Posted December 6, 2022 23 minutes ago, CBers said: I'm running the latest version in post #1. That is version 2.0b with the bug The latest is tool_2.0c.zip, posted on the page before this one (page 39/40 for me). 1
CBers 7554 Posted December 6, 2022 Posted December 6, 2022 Just now, Roodee said: That is version 2.0b with the bug The latest is tool_2.0c.zip, posted on the page before this one (page 39/40 for me). OK, thanks
Happy2Play 9811 Posted December 6, 2022 Posted December 6, 2022 1 hour ago, CBers said: It's a while since I used this tool. I remember there being a way of the tool remembering the login details to your server. Can someone remind me please. Look at the tools.js. 1
Happy2Play 9811 Posted December 6, 2022 Posted December 6, 2022 7 hours ago, Junglejim said: This also could be useful but I don't see the "add item". When I ctrl click a tvshow I get to here. Which seems to be a meta editor for that show? Sorry I was looking at version 33, doesn't look like 2.0c has add item anymore. 1
Junglejim 385 Posted December 7, 2022 Posted December 7, 2022 14 hours ago, Happy2Play said: Sorry I was looking at version 33, doesn't look like 2.0c has add item anymore. Yea no probs, I put my glasses on and had a good look. It would be nice if @VicMoore could bring the "Add Item" button back.
VicMoore 755 Posted December 7, 2022 Author Posted December 7, 2022 JungleJim, I will look into adding that button back. Tell me what you want it to do. Vic 1
